Old Feb 04, 2015, 03:21 AM
ARRISHOBBY is offline
Find More Posts by ARRISHOBBY
Joined Dec 2014
Get one free! ARRIS HDMI to AV Cable with Shutter!
we are looking for free testers and have already shipped 5pcs out, please click this link for detailed information:
Support Cameras: Nikon, Canon, Sony (such as SONY NEX-5, 5N,5R,5T,5TL,6R,7N,7R. Nikon D90,D3X, etc. )
The ARRIS FPV3020 HDMI to AV converter module is specially designed for aerial photography, featuring extremely small volume and super light weight. The shutter release cable makes the module be capable of controlling photo taking and video shooting through directly connecting to a receiver with a 3-position switch, besides, it can also be used to control the video transmission through directly connecting with A/V transmission system. This ARRIS converter module has a built-in Infrared Ray function, can perfectly work with Sony, Canon and Nikon series camereas. All these features make it become almost the universal controller in the market.
1. Both Mini HDMI and micro HDMI can be used, interface changeable.
2. Adopts the latest chip available in the market, be compatible with cameras like Nikon, Canon, Sony and there is no need to buy additional adaptor when using different cameras for customers.
3. The use of soft cable makes the installation become more easy.
4. All the parts are designed separately, customer can change those easily-damaged items conveniently.
5. It can support both photo-shooting and video-taking.
6. Advanced chip and scientific wiresing makes the converter be more light in weight and small in size.
Weight: 10.9g
main board Size : 30*20mm
Plug Size (no wire): mm*16mm*14mm
Soft Wire Length: 190mm
Single Wire: 180mm
How to use:
ARRIS HDMI to AV Cable for Mini HDMI and Micro HDMI Interface (Including Infrared Shutter) (3 min 43 sec)
1. Working Voltage
The ARRIS HDMI to AV cable with shutter does not support high voltage receiver, the supply voltage of the receiver should be 4.8V to 6V. Any supply voltage beyond this may burn the new convert module.
If there is no receiver control signal, the red LED flashes 4 times every second. At this time, the user can check whether you power the receiver, or whether the radio binds with the receiver successfully.
2. Set the HDMI resolution to "Auto"
3.Set the Drive Mode of the camera to "Remote Cdr."
4. Connect the HDMI cable with camera, shutter control wire with the receiver
Connect the wire next to "G V" to video TX. G is the negative pole, V is video.
Connect the wire next to " "with receiver.
5.Put the HDMI converter module in the proper position; make sure the infrared LED is in the effective range of the Camera infrared LED. The infrared LED should be not covered.
Instruction Manual Download
Our website:
Facebook: Hobby-Wing
ARRISHOBBY is offline Find More Posts by ARRISHOBBY
Old Mar 11, 2015, 10:38 AM
headviking is offline
Find More Posts by headviking
Joined Jun 2014
How do I become a tester?
headviking is offline Find More Posts by headviking
Old Mar 11, 2015, 09:42 PM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
Wow..... too bad it doesn't support NTSC all that well. Still if it works to take pics for mapping it's all good! I'd test one.
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Apr 10, 2015, 08:49 AM
truemobile is offline
Find More Posts by truemobile
Singapore, Singapore
Joined Sep 2014
has anybody tested the IR module in bright sunlight?
truemobile is offline Find More Posts by truemobile
Discussion Free ARRIS HDMI to AV Cable with Shutter to Test ARRISHOBBY Multirotor Talk 17 Jun 22, 2015 01:51 AM
Yippee! Get one free! ARRIS 325 High Performance Full Carbon Fiber Blade for 450 helicopter HW_Nancy Electric Heli Talk 24 Jun 03, 2015 09:19 AM
Discussion Free ARRIS Super Light HDMI to AV Cable including the IR Shutter to Test ARRISHOBBY FPV Equipment 5 Feb 06, 2015 04:03 PM
For Sale Kopterworx - Zenmuse GH4 HDMI to AV converter mini + micro HDMI thin cable SeacoastRE Aircraft - Electric - Multirotor (FS/W) 1 Sep 11, 2014 04:00 PM
