Old Nov 05, 2008, 08:30 PM
jetfan20 is offline
Find More Posts by jetfan20
orlando florida
Joined Jun 2005
Battery Help
I need a little help on Li Po's
I'm building an A-10 15-18lbs Flying weight including batteries, I will be using 2 hoaye 4.5" fans with 2 KB45-17XL capable of handling 36v and using 2 Hobby Wing 100a HV ESC. I Plan on using 8s to each motor 16s total. My question is this I have come accross some LiPo's with different discharge rates and capacity. I need help on what do you guys think would be the best way to go with my setup. Here are my choices:
14.8v 3300mah 25c
14.8v 3700mah 22c
14.8v 2200mah 25c
2 of these batt. to each motor would give me some serious mah & volts but would it be safe to do the higher mah setup, which is only a $10 more than the 3300 mah setup for a set of 4 or should I play it safe and stick with the 3300 or 2200mah batteries. I'm leaning toward the 3700mah to get good flight times without coming even close to low discharging. Any and all help will be greatly appreciated.
jetfan20 is offline Find More Posts by jetfan20
Old Nov 05, 2008, 08:50 PM
mobird is offline
Find More Posts by mobird
Canada, NS, Truro
Joined Aug 2004
Between the 3700's and the 3300's there's only a fraction different in the max contiuous current, 1.something amps. The 3700's should hold their voltage a bit longer if they are true 3700. They will be slightly heavier so it's swings and roundabouts. What is your WOT (max) current? I shouldn't think the 2200's will handle it anyway.
Cheers,
Charles.
mobird is offline Find More Posts by mobird
Old Nov 06, 2008, 02:27 AM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
I don't think any of them will be enough.....anything more than 65 amps will kill the batteries.
skyhawk is offline Find More Posts by skyhawk
Old Nov 06, 2008, 05:56 AM
jetfan20 is offline
orlando florida
Joined Jun 2005
What woould you recommend for batteries? These fans & motor combo are putting out about 6lbs of thrust on 8S, for my plane that would be times 2. Would that be enough thrust for the size plane, I want a nice flying Jet not a Sky rocket. Please let me know.
Old Nov 06, 2008, 09:57 AM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
What amps are you drawing? There's no way to answer definitively unless we know what you'll be asking the batteries to do. One thing is sure: If a pack claims 25C, only use it for 18-20C if you want it to last more than a few flights.
If I were doing this project, I'd be using 100A packs at a minimum, (and calculating the 100 amps based on 18-20C. (Like 5000 mah rated for 25C)
kelberts is offline Find More Posts by kelberts
Battery Help Ni-Cd / NiMH /Li-Ion Bat Highflyer Parkflyers 11 Jan 02, 2002 10:52 AM
Zagi Battery Help Please ETKing Foamies (Kits) 2 Dec 21, 2001 03:47 AM
Battery help needed....... ARE Electric Plane Talk 5 Jul 27, 2001 12:57 AM
Need A New Battery! Help! AirVenture Beginner Training Area (Aircraft-Electric) 11 Jul 14, 2001 01:12 PM
Battery Help jdwall Parkflyers 5 Jun 24, 2001 11:45 PM
