Old Jun 16, 2001, 12:10 AM
razzor7 is offline
Find More Posts by razzor7
Burnsville, MN, USA
Joined Oct 2000
Fiberglass Duct is like Rubber! Help!
I thought I had finished a very nice fiberglass duct for a MiniFan 480, but I started to pre-fit it to the duct, I realized that it's more flexible than a gymnist! I could plug one end and suck on the other and the entire duct would collapse. Does the type of epoxy you use make a difference? I used Great Planes 45 minute finishing resin. Should I try some other brand? If so, which one would you guys recommend? Also, does carbon reinforcement help? Is it practical in the case of a MiniFan 480 on 9 cells and a Kontronik Fun400-36 motor?
- Razz
razzor7 is offline Find More Posts by razzor7
Old Jun 16, 2001, 01:18 AM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
How did you make the duct? Did you make up a sheet then roll and seam it or did you make it on some sort of mold?
What weight of cloth did you use?
Did you thin the resin with anything or did you mix it up and use it as is?
Dan
DanSavage is offline Find More Posts by DanSavage
Old Jun 16, 2001, 08:34 AM
Plane Crazy is offline
Find More Posts by Plane Crazy
Flying Welder Pilot
Plane Crazy's Avatar
Reno, Nevada
Joined Jan 2001
It almost sounds like you used only one layer of cloth. You need two use at least two layers to get the rigidity. 1 1/2 ounce cloth minimum. The other thing would be not waiting long enough for the part to cure. Epoxy usually takes overnight.
I use my storm door window to make sheets of glass by waxing the glass and putting two layers of cloth some resin and squeegee the resin out to the edges. Let it cure and peel it off. Roll it up for some neat duct work.
Plane Crazy is offline Find More Posts by Plane Crazy
Old Jun 16, 2001, 10:27 AM
inedesca is offline
Find More Posts by inedesca
mexico city, mexico
Joined Aug 2000
Better yet.
Make afoam plug for the duct, then cover it with papier-mache (news paper and diluted white glue). Then dissolve the foam with gasoline and voila ulta light and perfect fit.
rgs/eduardo http://www.inedesca.com
inedesca is offline Find More Posts by inedesca
Old Jun 16, 2001, 11:15 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
What inedesca said - but wrap the foamplug with plastic food wrap or cover or with a balloon. Neither stick well to epoxy so removing it is easy.
PlaneCrazy is right on re. your problems I think. Try 3 layers of 2oz cloth or thereabouts and let it cure atleast 24hrs. The epoxy can take a day or two to fully polymerize.
I have just recently moulded some fuselages and after 24hrs they're firm enough to pull out of the mould but they do get stiffer then next 24hrs.
The epoxy I used had stated 24hrs curing time@20degC.
Haldor is offline Find More Posts by Haldor
Old Jun 16, 2001, 01:34 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I just laid up some duct work for the single fan Rafale of EJF. I used hobby shop epoxy (Bob Smith). After cure very much like rubber. I check with our composite people at work (Boeing Aircraft) They stated the best is Saf-T-Poxy from Aviation Spruce and Supply. I was able to get some locally from Aeroloft Designs. Also check with Aerospace Composites. It needs to be a stiffer type of resin system. Good luck!
Bob
bruff is offline Find More Posts by bruff
Old Jun 16, 2001, 05:07 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
I have used both some aero-grade stuff and WestSystems. Both cure nice and stiff but neither reach full stiffness untill 24-48hrs.
Have it cured nice and stiff by now? If not I suspect a faulty mix ratio. I dont know the GP Finishing resin so cannot comment on its suitfullness.
Old Jun 16, 2001, 06:35 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Provided the epoxy cures nice and stiff - yeah, carbon add a lot of rigidity.
Old Jun 16, 2001, 07:22 PM
razzor7 is offline
Burnsville, MN, USA
Joined Oct 2000
Thanks for all the helpful replies!
Dan: I made the duct by taking some waxpaper, and plugging it from both sides with my fans to help the paper retain its shape. I then proceded to use 6 oz. cloth just to get comfortable with the process, and no, I didn't thin it out at all.
Later on in the finished model, I'll probably use two layers of 1.5 oz. cloth, though.
Planecrazy: You are correct, I only used one layer. If I use two or more layers of lighter cloth, should I put both layers on simultaneously, or should wait for the epoxy to cure in the first layer, sand it, and then apply a second layer of 'glass and epoxy?
Haldor: I'll probably end up buying some West Systems epoxy. I don't want to play around and waste both fiberglass and my time with this Great Planes stuff. What I think it's good for, though (the Great Planes resin), is wing seam reinforcement, because wings always flex, and I'd bet you want flexibility in the epoxy if the surface is going to flex equally as much. And no, even up until now, it has not cured stiff; still very flexible. Resin like this could have other useful applications though
Bruff: Thanks for the info. I think this confirms that the type of epoxy can have an effect on the stiffness of the finished product.
Thanks again for the replies,
- Razz
Old Jun 16, 2001, 07:33 PM
Flying Welder Pilot
Reno, Nevada
Joined Jan 2001
Lay up both layers at the same time. And try and pat up any excess epoxy with paper towels. The stiffness of the part is the action of two layers of glass working against each other.
West systems epoxy is excellent but as Haldor said you will have to wait at least 24 to 48 hours for a full cure.
I have used West System epoxy for composite carbon fiber landing gear and it is high quality stuff. Make sure you mix it by wieght 3 parts epoxy to 1 part hardener as per instructions. I use a gram scale with paper cups.
Good Luck
Gordon
Old Jun 16, 2001, 07:34 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Just lay up the layers all at once - wet on wet.
Old Jun 16, 2001, 10:14 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
I've used Bondo Marine Product marine epoxy resin (No. 3202) to mold parts. Dries overnight and cures to make pretty stiff parts. I buy it at my neighborhood Lowe's for $20.
No matter which epoxy you use, make sure that
you mix it thoroughly. (at least a minute or two) If you don't it will turn out rubbery.
Good luck.
Dan
Old Jun 17, 2001, 06:25 PM
sblack is offline
Find More Posts by sblack
Scott Black, Montreal
sblack's Avatar
montreal quebec Canada
Joined Sep 1999
Finishing resin does not have any strength. You have just discovered this the hard way (as I did). Safety Poxy, West, Proset or any of those products are Laminating epoxies used to make layed up parts rather than just providing a good finish. Any of them will work.
There is a considerable pressure drop across a duct and you have to ensure that it won't collapse. It has happened in numerous full scale aircraft too - like the P-80 prototype.
If you want to make a stiff layup, you could take CF tow and wrap it diagonally both ways so that the duct looks like an ugly leg in a sexy CF fishnet stocking (if you get my drift). That would stiffen it up a bunch and it would be easy to do. YOu could wet the CF out with more resin or just CA.
sb
sblack is offline Find More Posts by sblack
Old Jun 17, 2001, 06:47 PM
razzor7 is offline
Burnsville, MN, USA
Joined Oct 2000
Thanks Scott. I'll have to get some carbon fiber too then, huh? Man, this is getting expensive. I'm almost over the $1000 mark!
Regards,
- Razz
Old Jun 18, 2001, 09:25 AM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
A couple of months ago I laid up inlet ducts for my scratchbuilt F9F Panther (still not finished building it! GRRRR). I used West Systems Epoxy and some realy thick cloth I bought from Aerospace Composite Products
, I beleive it was 10 oz cloth. I uses spray on mold release that I found at a local plastic supply store. I tried using the spray on Freekote brand that Aerospace Composite Products carries but it was horrible, it wouldn't wet out evenly on the plug, it just bunched up into little droplets on the surface. I've read about this habit of Freekote in Flying Models magazine also.
I just used the one layer, and as the resin cured I layed on some carbon fiber tow (Dave Brown brand) and put the whole setup in the bathroom and turned on a space heater to raise the tempurature. The next day I popped the parts off of the mold and holy moly I had some light parts that I made myself! That's a good feeling, I tell ya what. The carbon tow really stiffened the parts. I only put it on in two thick bands but maybe next time I'll do Scott's fishnet panty hose idea .
I used the heavy cloth because I didn't want to mess with more than one layer. I also have the 3/1 ratio pumps for the West Systems epoxy, but to be sure I added just a little bit more hardener than the pumps put out, and it seems to have made a difference. I'd use this epoxy before on a blue foam fuselage and it seemed to be kinda rubbery-probably just a bad mix on my part but I did use the pumps. Going by weight would probably be safest. I think a key proceedure is to get the part warm, I feel that makes the part cure better but I could be wrong, it's probably not necessary. Besides, this part was stiff because it was made of 10 oz cloth and not 3 oz cloth.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Corona Flew off on it's own yesterday, like a ghost. Help figure this out please.. fletch Electric Heli Talk 17 Apr 08, 2003 03:51 PM
Landing gear wire...Bends like rubber SpaKack Parkflyers 6 Feb 21, 2003 04:56 AM
Virus 400a flies like a brick (help) Ghostbear Parkflyers 11 May 28, 2002 07:50 AM
Fiberglass Duct Layup Question Tim H. Electric Ducted Fan Jet Talk 3 Jan 27, 2002 09:49 AM
