Old Aug 20, 2015, 08:53 AM
EdSoars is offline
Find More Posts by EdSoars
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
Idea
Yard sign wing
It's election time in our town and I have 100 unused 18x24inch coro signs in my garage. They really need to find a better use than pimping politicians, and what better use is than in a slope wing?
I'm thinking a 36" span plank should work, and could fit on one sign.
I'll post sketches as they come but would appreciate any suggestions!
EdSoars is offline Find More Posts by EdSoars
Old Aug 21, 2015, 05:37 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
mount EDF on top
space 1 is offline Find More Posts by space 1
Old Aug 21, 2015, 05:57 AM
EdSoars is offline
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
Got one. Right size. Unused. Hmmm.
Old Aug 23, 2015, 10:46 PM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
There's a forum here called "S.P.A.D." or Simple Plastic Airplane Designs.
The material often used is the corrugated plastic sign stuff. I call it "Coroplast" but other names exist, "Correx" is one.
The Slope forum has some threads about making PSS gliders from the stuff. Many good hints and tips.
dayhead is offline Find More Posts by dayhead
Old Aug 24, 2015, 10:01 AM
EdSoars is offline
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
Dayhead: I'm not finding the S.P.A.D. forum or thread. Got a link?
The South African build videos are excellent... I'm on my way.
Thanks for the leads.
Old Aug 24, 2015, 02:01 PM
space 1 is offline
USA
Joined Apr 2007
edf
you could do this
Old Aug 24, 2015, 02:09 PM
EdSoars is offline
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
Don't need no grass cut. The boys in South Africa have it down.
So far, this will be a 48" span swept wing, like a combat wing but higher aspect ratio. The trick will be designing the airfoil and getting the right twist built in.
Old Aug 25, 2015, 09:54 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
You may be able to do a fold over style wing and then sort of "warp" it to get a shear at the rear joint then secure it.
The other option is make the elevons wider at the tip than at the root and with the up trim they need the tip airfoil will then have the washout and different tip airfoil you want.
It also sounds like you have more than enough to experiment with different ideas....
Here's a link to the SPAD forum here on RCG...
http://www.rcgroups.com/spad-simple-...e-designs-176/
BMatthews is offline Find More Posts by BMatthews
Old Aug 25, 2015, 11:36 AM
dayhead is offline
SlingWinger
And here is a thread of 175 pages and counting showing how to make aeronautics out of yard signs, from the slopeheads:
http://www.rcgroups.com/forums/showthread.php?t=1445391
Old Aug 30, 2015, 04:22 AM
EdSoars is offline
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
These are all made from 2 mm corro. Yard signs arey4 mm. The thick stuff won't bend over a radius less than the length of a football field so I'll find other uses for the signs. Maybe military - industrial?
Old Aug 30, 2015, 10:48 AM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Have you tried heating the coro in your oven? Polystyrene gets soft at a fairly low temperature. 170 F is where it starts to get gooy so something well below that should let you bend it around some more useful radius.
nmasters is offline Find More Posts by nmasters
Old Aug 30, 2015, 10:58 AM
EdSoars is offline
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
I was just thinking about heat! Great minds...
I'll check on temps for forming polystyrine and see whether a heat-shrink iron could soften it enough to shape the sheets over a simple form.
That 4 mm stuff is so strong that the spar strength would be minimal.
Discussion learning the signs of the wing derk Nurflügel 12 Aug 26, 2015 08:58 PM
Sold fpv yard sale incl. dragon link, bare wing airframe fpvguy FPV Equipment (FS/W) 2 Oct 23, 2014 11:55 AM
Discussion Signs, signs, everywhere are signs...... 62pilot Life, The Universe, and Politics 9 Sep 19, 2012 08:30 PM
My new and improved yard sign patrickegan Life, The Universe, and Politics 36 Oct 23, 2004 03:03 PM
Yard Bee wing astra Electric Plane Talk 2 May 20, 2003 11:19 AM
