Old Aug 16, 2015, 08:39 AM
rk256 is offline
Find More Posts by rk256
United States, VA, Herndon
Joined Jul 2012
Question
HELP Sport Cub s FPV problems
I am trying FPV for the very first time and I bought the components for DIY.
List of components that I bought:
1. Range Video Tx5802m 5v
2. Rc832 from range video
3. Surveilzone 600tvl camera
4. Pololu 3.3v step down regulator
5. Quanum V2
I soldered the TX,camera and it worked perfectly directly with a 1s battery. My main goal was to use this in sport cub s and hence I wanted to use the 1 battery to power both the plane and the TX. So I used the extra connector from the esc to power up the TX.
The video drops almost immediately after I give some throttle. I saw many people experiencing the same and they suggested using a voltage regulator ( like 3.3v pololu). So I ordered one and hooked it up but I still face the same problem even after using the regulator.
Any Idea what I may be doing wrong ?
RK
rk256 is offline Find More Posts by rk256
Old Aug 16, 2015, 10:29 AM
Exaturbo is offline
Find More Posts by Exaturbo
Australia, NSW, Sydney
Joined Jan 2012
I know someone who had similar problems when trying fpv with this plane.
He ended up using a second 1S pack to power just the fpv camera and tx.
Jason.
Exaturbo is offline Find More Posts by Exaturbo
Old Aug 16, 2015, 11:59 AM
rk256 is offline
Joined Jul 2012
Thanks Jason. I believe that is the only way. I am afraid the added weight might be too much for the small sport cub but let me see how it flies with 2 batteries.
Old Aug 16, 2015, 01:54 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
that or use higher C rated and/or capacity packs, so that the throttle application doesnt cause such a large voltage drop. For a given amp draw, a higher C rating and/or a higher capacity will mean the voltage stays higher.
dacaur is offline Find More Posts by dacaur
Old Aug 16, 2015, 07:17 PM
rk256 is offline
Joined Jul 2012
I just made a test with separate battery and it looks like the planes ESC or motors is interfering with the Video TX. The signal drops only when the tx is near the plane.
I just installed the wire antenna that came with the video TX. Will a circular polarized antenna or any other antenna resolve this problem ?
Old Aug 16, 2015, 09:34 PM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
No.
Move the vtx away from the tx. I had to do this to 2 of my micro FPV planes to reduce interference after trying everything else.
I have images of where I re-locaed my 1.2 antenna in my ad:
http://www.rcgroups.com/forums/showthread.php?t=2459852
voxel is offline Find More Posts by voxel
Old Aug 17, 2015, 08:13 AM
rk256 is offline
Joined Jul 2012
Ah. Thanks Voxel. I tried moving the transmitter all the way to the back, actually under the fuselage and it kinda worked. I guess now I need to get longer cables and re-solder everything.
For Sale Hobbyzone Sport Cub S - 1s beginner 1.2Ghz FPV plane voxel Aircraft - Electric - Airplanes (FS/W) 0 Jul 16, 2015 12:34 AM
Discussion First FPV Plane (Sport Cub S vs FPV UMX Radian) John234 FPV Aircraft 9 Jun 17, 2015 08:41 PM
Discussion Sport Cub S - What is the problem? Hin3K Micro Ready-to-Fly 5 Jun 07, 2015 11:57 AM
Discussion Problem with Sport Cub S jobinseattle Electric Plane Talk 42 Feb 01, 2015 07:20 PM
Discussion brushless with safe help??? sport cub s jh1985 Micro Ready-to-Fly 1 Oct 19, 2014 10:39 AM
