Old Jul 20, 2015, 02:33 AM
bird warrior is offline
Find More Posts by bird warrior
bird warrior
United States, CA, SF
Joined Jul 2015
Wich servos
Which cyclic digital metal servos.i have been researching a little bit on the khs servos they are red and aluminum.i kind of went my bird to have some eye candy color.any reply and tell me what servos to get plus on a budget.
bird warrior is offline Find More Posts by bird warrior
Old Jul 20, 2015, 06:23 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
KST (is that what you meant?) are hard to beat on bang for buck, yes they are red any aluminium but colour isn't usually the most important consideration.
Hobbyking also do their 'RotorStar' servos some of which are just re-label of KST. They are gold and aluminium colour if that appeals more? Hobbyking also do re brands of some KST servos under the Turnigy name with blue and aluminium case (TGY-BLS815MG for instance).
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jul 20, 2015, 07:16 AM
getsuyoubi is offline
Find More Posts by getsuyoubi
United States, NY, New York
Joined Sep 2013
What's your experience with helis? I'm getting increasingly worried the more of your questions I read. Picking servos by their color is just plain wrong. You want quality components in a 700 size heli (actually, in any heli), and certainly in a scale bird where even a light crash can destroy the fuselage. A 700 size heli can kill you, or an innocent bystander, and this actually has happened a couple of times already.
getsuyoubi is offline Find More Posts by getsuyoubi
Old Jul 20, 2015, 11:59 AM
bird warrior
Joined Jul 2015
Yes I undetsand I appreciate the feedback .
Old Jul 21, 2015, 02:36 AM
Atomic Skull is online now
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
The KST brushless aren't really worth getting in the Turnigy version because you can get the branded version for almost the same price if you buy a full set and know where to look. On the other hand the coreless (TGY-725 and TGY-525) are much less than the branded version.
I did a teardown thread on the TGY-725MG and it looks like they didn't take any shortcuts on assembly, all the wiring is properly glued down at the solder joints.
http://www.rcgroups.com/forums/showthread.php?t=2451674
I'm using a set of these in my Innova 700 (I'm using a Promodeler brushless rudder servo not the KST rudder servo) and so far they seem great.
Atomic Skull is online now Find More Posts by Atomic Skull
Old Jul 21, 2015, 11:41 AM
airboss/oc is offline
Find More Posts by airboss/oc
California Style
airboss/oc's Avatar
United States, CA, El Mirage
Joined May 2007
servos are VERY important as is the Rx and its power supply. I use only MKS servos in all my high end and performance RC aircraft
airboss/oc is offline Find More Posts by airboss/oc
Old Jul 21, 2015, 03:31 PM
jombo is offline
Find More Posts by jombo
AMA# 548800
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
For my big birds like the goblin770 they use standard servos ,so does the 570 . anything that's fast and high torque will do fine and not break the bank . its those stupid micro and mini servos you pay an arm or a leg for , because they must use a shrink ray to make them smaller or something
jombo is offline Find More Posts by jombo
Old Jul 22, 2015, 12:21 AM
bird warrior
Joined Jul 2015
appreciate
thanks so much, again , ilove this forum, and my fellow hobby family.
Old Jul 22, 2015, 10:27 AM
California Style
airboss/oc's Avatar
Joined May 2007
use the good stuff and it will reward you with reliability and durability.
Old Jul 22, 2015, 12:58 PM
Joined Dec 2011
$35-$40 seems to be the cutoff point for reliable standard sized servos. Any cheaper and they start having to cut too many corners in the design.
Old Jul 22, 2015, 03:06 PM
jombo is offline
AMA# 548800
jombo's Avatar
Joined Dec 2007
My standard servos are the titanium ones from hobby king , or whatever those red ones are . Around 35.00 each and draw mucho power and will melt before failing , ask me how i know
I dont think they have them any more , great tail servo and overkill for the cyclic
Old Jul 22, 2015, 03:44 PM
California Style
airboss/oc's Avatar
Joined May 2007
HK servos that melt you get what you pay for
Old Jul 22, 2015, 04:30 PM
jombo is offline
AMA# 548800
jombo's Avatar
Joined Dec 2007
Ummm, i did . I had the blade holder on and was setting up the tail servo . The FBL cyclic servos were doing their thing and trying to level the blades , but the blades were bound and couldn't move . You try that with any servo , they will melt and burn. mine still work , with a hole that melted through the bottom
Old Jul 22, 2015, 06:00 PM
bird warrior
Joined Jul 2015
ugh
yes i better get the good ones ,it makes sense, i am saving my beer money lol.
Old Jul 22, 2015, 07:13 PM
Flying Pitcher is offline
Find More Posts by Flying Pitcher
I'm breaking-in helis.
Flying Pitcher's Avatar
Greenland, Qaasuitsup
Joined Apr 2013
....mine still work , with a hole that melted through the bottom
if anyone is asking for reliability...this is it
Flying Pitcher is offline Find More Posts by Flying Pitcher
Discussion Servo Arms -WICH ONES- victorfriessen Radios 3 Jul 20, 2015 02:38 AM
Discussion Sunnysky x2212-9 vs Emax 2216 810kv , wich is the best? Mineirodf Multirotor Power Systems 8 Jul 01, 2015 01:32 AM
Discussion Wich is best 2x2S serial or 2x4S parallel? Helnet Batteries and Chargers 1 Jun 28, 2015 09:33 PM
Discussion Anyone good with servos? tell me wich servo this is BowerR64 Radios 4 Sep 24, 2007 07:34 PM
Q on wich servo ramw5p Parkflyers 2 Dec 18, 2001 02:56 PM
