Old Apr 29, 2013, 09:21 PM
macentyre is offline
Find More Posts by macentyre
United States, CA, Big Bear
Joined Feb 2013
Will a 30A ESC ruin a 40a ESC motor?
Hey guys,
Quick question.....I just hooked up a new motor on my Bixler 2. I put a new parkzone 2200kv that requires a 40a esc....I accidentally hooked it up to my 30a esc and turned up the throttle and it made some weird noises and tried to turn....I just then realized I had the wrong esc....did I do any damage to the motor by doing this?
Picking up a 40a tomorrow.....any insight is appreciated.
macentyre is offline Find More Posts by macentyre
Old Apr 29, 2013, 11:38 PM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
shouldn't damage it.
SadSack is offline Find More Posts by SadSack
Old Apr 30, 2013, 02:24 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
No damage to the motor. It could damage the ESC if you tried to run it at full power and that was more than it could take.
BTW this forum is really about building your own electronic circuits...you really wanted the Power Systems forum http://www.rcgroups.com/power-systems-13/
Steve
slipstick is online now Find More Posts by slipstick
Old May 04, 2013, 03:34 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
I doubt about this draw, I would rather suspect ESC timing.
You simply can't draw so much power with a 6" prop, simple physics laws.
renatoa is offline Find More Posts by renatoa
Old May 04, 2013, 02:29 PM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Originally Posted by macentyre View Post
... I put a new parkzone 2200kv that requires a 40a esc....I accidentally hooked it up to my 30a esc and turned up the throttle and it made some weird noises and tried to turn....I just then realized I had the wrong esc....did I do any damage to the motor by doing this?....
Strictly speaking, a motor doesn't require any particular ESC rating -- it's the prop you put on the motor, and the battery volts you connect it to, that determine how many amps it's going to draw
However, if your motor is specced to take 35A, then it's prudent to use an ESC which has a bit to spare, such as a 40A. And then put a prop on that will make it draw 35A at full throttle.
Putting a smaller ESC on will do no harm to the motor though, as others have mentioned, it risks burning out the ESC if your motor/prop combo is actually drawing more than 30A. Your problem of the motor making weird noises and not starting suggests either incorrect ESC timing, as suggested in post #4, or a bad connection somewhere between ESC and motor -- could be one or more of the bullet connectors with a bad solder job, or a broken or badly-soldered wire in the ESC or the motor.
abenn is online now Find More Posts by abenn
Old May 07, 2013, 11:01 PM
Joined Feb 2013
THanks guys!
Alert Found possible point of failure in these Chinese ESC's (F-20A, F-30A, F-40A, etc) serrated Multirotor Talk 17 Mar 05, 2013 08:17 AM
For Sale KDA Motor/ESC blowout 20-50S/20-26M/20-22L 40A 30A 18A daign Aircraft - Electric - Multirotor (FS/W) 8 Oct 23, 2012 03:03 PM
Found Looking for 1100 t0 1200kv motor & 30a to 40a esc rhampton Aircraft - General - Miscellaneous (FS/W) 2 Oct 11, 2012 04:49 PM
Found Looking for 1100 to 1200kv motor & 30a to 40a esc rhampton Aircraft - Electric - Power Systems (FS/W) 12 Oct 09, 2012 07:16 PM
WTB: ESC for Brush motor 30A-40A with BEC Cas123 Aircraft - Electric - Airplanes (FS/W) 1 Jul 12, 2004 12:05 AM
