Old Dec 06, 2012, 02:09 PM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Skymaster slowly being repaired ...
Back about a year ago - my Skymaster Biplane
did a vertical straight into tarmac ... basically elevator servo failed when inverted ...
The GRP fuselage and top wing were shattered ....
Some filler, F/G tape and resin ... put the fuselage back to reasonable ...
I then put it all aside while I concentrated on other models etc. I also needed to replace the 15cc RCGF engine that was smashed ...
Finally a new engine arrived and I decided to have another go at repairs ... this time to see about that top wing.
I scarfed the halves together with doubling pieces and various additions ... I cut out replacement rib parts from depron to keep weight down ... as I wanted to repair without pulling it apart too much ...
Depron doublers added to the broken ribs ...
Final sheeting up will stiffen it all up and provide a good wing again.
The fuselage then came in for resetting of cabanes etc :
Replaced the wire u/c with alloy ....
Feeling quite pleased with myself !!
Nigel
solentlife is online now Find More Posts by solentlife
Old Dec 06, 2012, 02:21 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That is very impressive. It is looking really good. I think you have done a pretty good job fixing it back up too.
earlwb is online now Find More Posts by earlwb
Old Dec 06, 2012, 08:24 PM
kenh3497 is offline
Find More Posts by kenh3497
Live long and fly high
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
So far, so good! Keep after it and it will be finished before you know it!
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Dec 07, 2012, 09:38 AM
solentlife's Avatar
Joined Jan 2010
Only problem is work gets in the way !! I don't work at home area ... I travel around the world on assignments - so I get pulled away from my models.
One of the biggest headaches with this repair is the fitting of new firewall and the ignition system. Where the fueslage front has been rebuilt - the firewall needs careful cutting in to sit right. I cannot use the fuselage front itself as I cannot guarantee it's alignment for down and right ... so will have to measure from the tail to multiple points.
The Ignition box I mounted external just in front of U/C - but never liked it there ... so will see about how to mount inside and have the spark lead exit to connect. It needs such a big hole to pass through !!
For anyone interested - the windshield I fitted is cut from a 2 litre Plastic Beer bottle !! It's a real problem that I have to empty the contents before I can get my canopys !!
Hopefully shouldn't be too long before she's in sky again ... already have new servos in her !
Nigel
Old Yeller (gws P-51d) Being Repaired! guapoman2000 Parkflyers 78 Mar 07, 2013 11:24 PM
Discussion Motor Repair-Can this be repaired? sdclark Electric Motor Design and Construction 9 Sep 27, 2007 07:24 PM
How Many Times Can Foam Be Repaired? wats Foamies (Kits) 9 Sep 06, 2002 10:13 AM
