Old Dec 12, 2011, 06:33 PM
pmdevlin is offline
Find More Posts by pmdevlin
pmdevlin's Avatar
Wirral, UK
Joined Jan 2007
Hydra 120 timing help pls!
Hello,
I have a hydra 120 in a large fast electric boat. I am about to fit a Scorpion HK-4025 Motor, running on 6 lipo cells, having read the tech spec on the motor, its timing is set at 5 degrees, its not adjustable. Can someone please explaing the timing settings on the esc, what should I have it on, want fast, but not a doomsday setting as the boat is heavy (6.5kg) all ply construction, eagle tree data has it just under 25mph with the gear ratio and prop it runs on,
thanks
pmdevlin is offline Find More Posts by pmdevlin
Old Dec 13, 2011, 07:35 AM
RS Rogers is offline
Find More Posts by RS Rogers
RS Rogers's Avatar
Clyde N.C.
Joined Oct 2003
Hi
The HK being a helicopter version - we run that motor usually with a PWM setting of 8khz & the Timing set to Low with very good success.
Hope this helps.
Steve
RS Rogers is offline Find More Posts by RS Rogers
Old Dec 13, 2011, 09:06 AM
Bernie Wolfard is offline
Find More Posts by Bernie Wolfard
Castle's Chaos Corner
Bernie Wolfard's Avatar
Olathe, KS (next to the Castle)
Joined Jun 2001
Actually, Hydra ESCS do not have adjustable switching rates and cannot be set to run an outrunner optimally. Like it or not, we simple do not feel outrunners are appropriate for boats and do not support them. We have gone around on this and this will not change. Boats should have higher Kv motors and the high torque/low Kv of outrunners are simply not appropriate for them. This does not mean that people do not use outrunners in boats, it simple means Castle Creations does not support them in this applications.
Bernie
Bernie Wolfard is offline Find More Posts by Bernie Wolfard
Old Dec 13, 2011, 10:06 AM
RS Rogers's Avatar
Clyde N.C.
Joined Oct 2003
I should have expressed when I said "we" in my previous post that was heli pilots using the HK series of motors in Helis with controllers for that application. Bernie is correct that PWM is not a choice on the Hydra controllers.
The larger Scorpion outrunners are being used A LOT boats & I havent heard of any ill effects from the boaters I know that are using them. I've actually heard good things. Not that they may not exist but I personally havent heard of any.
Check the boating forums & I am sure there is info to be found.
Steve
Old Dec 13, 2011, 05:40 PM
pmdevlin is offline
pmdevlin's Avatar
Wirral, UK
Joined Jan 2007
Hi Bernie, so you know the application, I use the Hydra as I doubt anything else that is plug and go, can handle this, amp draw with align heli motors typically is 80 plus. The hyrda provides bullet proof performance, very smooth take off, with low speed capabilities, and slow reverse, something that scale boaters dont think exist!
I am about to fit the scorpion, which was recommended after significant testing with data logging, developing which prop gives the best play off between run time/heat/efficiency and speed.
Having tested higher kv motors, the lower kv is required for the torque, its a 6.5kg boat so needs the grunt to get it going. As a comparison, a 1250kv motor need a gear ratio of 1.25:1 to achieve satisfactory results, with a lower kv motor I can get the ratio to almost 1:1, its belt driven, so you do actually support these unusual applications by having such a good esc!, its just I dont understand the timing, I am still on stock settings, anything you can suggest to try would be appreciated
I cannot say how good this esc is, now 3 yrs old, never had any problems, but been through plenty of motors!
RC Huntsman 28 (4 min 1 sec)
Sold 2 hydra 120 esc,castle creation stuartb Boats (FS/W) 3 Feb 24, 2012 09:05 AM
Discussion Connecting PC to Hydra 120 ewodul Castle Creations 6 Sep 27, 2011 09:49 AM
Discussion 120 hydra timing, what does it do? pmdevlin Castle Creations 2 Aug 07, 2011 05:38 PM
Discussion hydra 120 set up please help! pmdevlin Castle Creations 7 Nov 17, 2009 10:13 AM
For Sale NIB Castle Hydra 120 ESC - $120 Potter Boats (FS/W) 4 Jul 13, 2009 04:10 PM
