Old Sep 09, 2011, 09:44 PM
Kevinfred is offline
Find More Posts by Kevinfred
United States, IN, Fort Wayne
Joined Oct 2008
Been watching MANY planes go down...
... and I was wondering about this (I'm sure already thought of) idea.
In the last 3 weeks I've probably watched 7 to 8 thousand dollars of aircraft crash, and that's just with a few guys at the park.
My thought is this. Why not have under the rear of the plane a small explosive charge. Maybe about the size of a C battery with a parachute in it. It wouldn't have to weigh much, or really cost much. When you lose control or have a failure, flip a switch blowing the chute out the back.
Obviously you wouldn't put one on a foamy or a $200 plane, but these $500+ planes could be saved!!
Why hasn't this been done? Please don't make fun of me, I'm new and curious..
Kevinfred is offline Find More Posts by Kevinfred
Old Sep 09, 2011, 09:54 PM
jimklein is offline
Find More Posts by jimklein
Minneapolis Mn
Joined Jan 2003
Honestly - most R/C I've seen go down is lack of judgement on the pilot side or failure to check out the craft before flight. - not sure how adding another switch would help as pilots I've seen think they are in control when they are not.
Pure comment - my thought is that this is revenge from video games and movies and a mentality of always flying on the boundries of your experiance.
(sorry my age is kicking in)
jimklein is offline Find More Posts by jimklein
Old Sep 09, 2011, 10:08 PM
ZSimon is offline
Find More Posts by ZSimon
Canada, ON, Mississauga
Joined May 2011
I have also heard it is due to certain crafts having their entire fuselage made out of Satellite receivers
Joking.
Such a system would be quite easy I believe.
Essentially you would be reading the LED from the Rx and when it goes red you would trigger a current completion at the ammonia charge.. Done
ZSimon is offline Find More Posts by ZSimon
Old Sep 09, 2011, 10:12 PM
Joined Oct 2008
The lack of judgement I totally agree... but yesterday this happened....
"Crap... Guys.... I have no control" ---- "No elevator!!!!"
we all watched as this plane flew on and slowly dipped only to crash (actually close to people) in a baseball diamond a few hundred yards away. Then in would have worked and saved a $1000 plane. But you're right many cases it wouldn't. I also think it'd give guys like me a LITTLE more confidence to fly the "next step" plane...
Old Sep 09, 2011, 10:16 PM
ZSimon is offline
Joined May 2011
In this hobby, you have to remember 'You get what you pay for' & 'Value it!!'
As someone mentioned,
don't go putting a OrangeRx clone Futaba FASST in a 700$ plane.
read manufacturer specs, don't be scared to ask questions. Manufacturers WILL reply to you with very nice info and specs.
if a system is working for you, just stick with it!
ALWAYS check servo horns and peripherals for wear.
Old Sep 09, 2011, 10:29 PM
Philipp is offline
Find More Posts by Philipp
Philipp's Avatar
Grand Prairie, Texas, USA
Joined Mar 2000
"don't go putting a OrangeRx clone Futaba FASST in a 700$ plane."
Why not? Do they have a bad reputation?
Sure, you may feel better with the $100+ Futaba receiver, but I have not seen or heard of problems with the Orange ones.
Philipp is offline Find More Posts by Philipp
Old Sep 09, 2011, 11:48 PM
Ranandar is offline
Find More Posts by Ranandar
Ranandar's Avatar
Kentucky
Joined Dec 2008
Everybody crashes, no matter what color their receiver is.
Here is a FS parachute save...
Real Aircraft Loses Wing, Lands Safely (Under Canopy) (1 min 34 sec)
Ranandar is offline Find More Posts by Ranandar
Old Sep 10, 2011, 12:01 AM
ZSimon is offline
Joined May 2011
FrSky FASST compatible receiver vs Genuine Futaba receiver test #1 (1 min 16 sec)
OrangeRX/FrSky have some issue with multiple freq types in the same area.
edit: I should also put that OrangeRx maxes at 1.2kM ~ while original Futaba Rx is maxing at sometimes 3.8~4.3kM
Old Sep 10, 2011, 12:02 AM
Darker4308 is offline
Find More Posts by Darker4308
Darker4308's Avatar
It has been done on an RC quad copter before at least. Just so you know.
6 Foot Chute Test 11-1-2008 - Stacey Clark (0 min 53 sec)
For some aircraft it isn't a terrible idea, but the systems you have to build to do it are fairly complex. Failure in sport is normally too fast to react to, so I really only see it as functional for the FPV crowd or maybe some of the scale guys.
When I say complex ... what I mean is that you have to set up a charge, or a servo to release the chute. With model rockets it's a little different because the charge that sets off the chute is included in the engine and it just goes off when the fuel runs out.
Darker4308 is offline Find More Posts by Darker4308
Old Sep 10, 2011, 12:08 AM
ZSimon is offline
Joined May 2011
I wonder if you can marry the function to some kind of RSSI?
Old Sep 10, 2011, 12:15 AM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
I have 30 some odd planes and I fly a lot. I have only ever had one crash that wasn't due to pilot error. What you want do do is possible but it's the loose nut behind the sticks that is at fault most of the time.
Hance is offline Find More Posts by Hance
Old Sep 10, 2011, 12:38 AM
mickydee is offline
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi,
I think the problem would be that most crashes happen too fast to have enough time to react and flip the switch, push the button, etc. Usually you have just enough time to say, "Oh ^%$#!!!! before it's too late........
Mickydee
mickydee is offline Find More Posts by mickydee
Old Sep 10, 2011, 01:11 AM
RobC(UK) is offline
Find More Posts by RobC(UK)
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
Originally Posted by ZSimon View Post
http://www.youtube.com/watch?v=HXCzsEEEnGA
So how many people fly with 2 transmitters in their plane and continually reboot their Tx until the system fails?
I noted this problem when the Orange FAAST receivers fist came out, but I have never had a problem with them in normal use. On a busy day at my club there can be several 2.4 GHz in use, in close proximity to my planes when I power up and I have never had an issue.
RobC(UK) is offline Find More Posts by RobC(UK)
Old Sep 10, 2011, 02:32 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
But, would it have worked in that situation? He didn't have control, so presumably his radio wasn't working and he wouldn't have been able to trigger the chute.
abenn is offline Find More Posts by abenn
Old Sep 10, 2011, 02:54 AM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
The times I would have needed this is when headed down 20' off the ground after an elevator horn pulled. Or when my aileron failed full up 20' off the ground. AR6100 brownout a few times.
With helis, you have the throttle hold, but on planes it's like WT waggle stick, don't remember about the channel 11 toggle because it never happens.
I agree there is a market for it, but there is the weight & unknown aspect if it will work anyway. It seems that it would be just for fly-aways flying level on larger aircraft that may fail next week or 5 years from now.
eagle777 is offline Find More Posts by eagle777
Discussion Been watching alot of videos of our heli's in crashes. The energy built-up is amazing Danoman812 Micro Helis 4 Mar 16, 2010 10:37 PM
Discussion Has Gore Vidal been watching Glenn Beck? patrickegan Life, The Universe, and Politics 19 Sep 30, 2009 07:16 PM
Discussion Anyone been watching 'Generation Kill' ? T.D. Life, The Universe, and Politics 18 Jul 27, 2008 10:12 PM
Rain Rain Go Away, I got too many Bi-Planes to fly RocketRonbo Club Talk 37 Feb 01, 2005 05:54 PM
