Old Oct 25, 2005, 08:16 AM
Joined Oct 2005
eco 8, which lipol pack?
Hi chaps, newbie here,
i have an ECO and haven't flown it yet as i don't have a decent battery pack for it, i'm after a lipol pack for it (i have a lipol charger)
the setup i have is a standard speed controller and standard motor ( NON brushless)
will a lipol pack be ok with this setup? and what sort will i need?
i see on ebay theres some 3400mah 11.1.v 3 cell (3S1P) will that be ok?
thanks for your help
Paul j
paulj69 is offline Find More Posts by paulj69
Old Oct 25, 2005, 02:44 PM
UH-60 Blackhawk Mechanic
helifrek's Avatar
United States, TN, Clarksville
Joined Feb 2004
Hi Paul, glad to see another eco-8 flyer. first of all you need to know about how many amps your eco-8 pulls? if your not doing anything aerobatic I would say 40 is a safe estimate. the battery you get has to be able to put out enough amps for the heli. to figure this out you multiply the C rating of the battery by the Mah rating. so you have a 3400 mah battery pack, this equals 3.4 amps, multiply by the C rating, since you haven't provided the C rating it's impossible to tell but I will guess 10. so the battery could put out 34 amps continuosly, that would probably fly your eco provided it is light and your not hard on it. I would go with something like a 3S2P or 3S3P. if your going to do aerobatics you might want to look into a 4S pack, I run a 4400mah 4S2P pack and it has a 8C rating, so it puts out 35.2 amps and has a burst rating of 15C so it can put out 66amps for a short period of time. so it's not hard to figure out once you get the hang of it. good luck and keep us posted.
Brandon
helifrek is offline Find More Posts by helifrek
Latest blog entry: 3D printing!
Old Oct 25, 2005, 08:09 PM
Powered by ThunderPower
Chachin's Avatar
United States, FL, Cocoa
Joined Sep 2001
Hello Paul and welcome to E-Zone.
From my short RC car experience, I would not be surprised if your brushed motor is rated for 6-7 cells. Anymore than that and it will die quickly, burn out. An 11.1 LiPo pack would be the equivalent of 9 cell NiCd which will probably kill the motor. Please check the specs, or tell us what brushed motor you are using.
On the other hand if you go with a decent brushless setup you won't have to worry about burning out the motor on 3 or 4S, you'll have longer flight times, more power, zero maintenance, etc.. etc.. But it will cost a little more upfront, but cheaper in the long run.
Good luck!
Chachin..
Chachin is offline Find More Posts by Chachin
Old Oct 25, 2005, 08:21 PM
High Roller designer
Impact's Avatar
Londonderry NH
Joined Mar 2005
Yup, I agree with chachin one brushless is much cheaper than 5 or 6 brushed 540's not to mention power, run time and no maintenance.....Impact
Impact is offline Find More Posts by Impact
Which Pack for ECO 8? simonbryant Electric Heli Talk 3 Aug 17, 2005 12:16 AM
Anybody using a 3s Lipo in their Eco 8? Which one? 50feet Electric Heli Talk 8 Jun 08, 2005 10:13 AM
Which pinion do I need for my ECO 8?? SKYWARN Power Systems 1 Jan 15, 2003 03:20 PM
Which FM Receiver for ECO 8???? rchrookie Electric Heli Talk 2 Nov 15, 2001 11:48 PM
Buying ECO 8, which gear? rgt Electric Heli Talk 1 Sep 27, 2001 09:47 PM
