Old Jun 04, 2014, 12:47 AM
Joined Jan 2009
Saito alcohol burner
I know there have been lots of discussions about alcohol burners, but I am looking for some detailed info regarding the Saito alcohol burner. I am planning to duplicate one, but I don't know how the orifice is arranged inside the larger tube.
Does it point straight down, or does it point forward?
Is there a needle valve to control air flow at the back of the larger tube?
I've been able to figure out how the rest of the burner is assembled from various pictures and drawings, but I've never seen down the burner tube.
Thanks for any help!
dwalker999 is offline Find More Posts by dwalker999
Old Jun 05, 2014, 08:29 AM
-kno3-'s Avatar
Romania, Bucuresti, Bucharest
Joined Mar 2008
Hello,
The jet nozzle faces forward (in the direction the flame comes out, as all standard gas jets do). The large valve on top regulates the alcohol flow. There is no special control for the air flow. There is also a small screw at the back of the main burner tube, whose exact function I couldn't ascertain. I tried turning it while it burned but nothing seemed to change. It could be just a hole for cleaning the jet nozzle (?).
-kno3- is offline Find More Posts by -kno3-
Old Jun 05, 2014, 03:51 PM
Joined Jan 2009
Originally Posted by -kno3- View Post
Hello,
The jet nozzle faces forward...
Thanks for the reply!
So there is a pipe on the top connected to the tank with a wick inside and a shut off valve at the end. Below this pipe is the burner pipe, and I can't see how it is connected to the top pipe. Is it a 'T' connection?
Old Jun 12, 2014, 02:29 PM
-kno3-'s Avatar
Joined Mar 2008
Sorry for the late reply. The shut off valve connects to the lower burner pipe. It is drilled through.
Old Oct 02, 2014, 09:15 AM
Joined Oct 2014
Hello everybody! can you find out what exactly you fill in the burner? 96% alcohol or vodka can be?
I became the owner of a set of Saito Boiler BT 1 L and Steam Enginе T1DRL. Thank you.
Urfin2014 is offline Find More Posts by Urfin2014
Old Oct 05, 2014, 07:10 AM
-kno3-'s Avatar
Joined Mar 2008
High grade alcohol.
Old Oct 05, 2014, 09:39 AM
Semi-Official Tinkerer
Subdave's Avatar
Rochester NY
Joined Mar 2005
I use what is referred to as denatured alcohol.
They sell it in any hardware or home improvement store in the USA.
It has an additive in it that makes it undrinkable.
I guess you could run on vodka if the proof was high enough.
But the denatured is cheaper, at least around here. . Dave.
Subdave is online now Find More Posts by Subdave
Old Oct 06, 2014, 05:10 AM
Joined Oct 2014
Thank you guys for the answer! I've realized that you need a good clean alcohol. About denaturin already read on the forum. Until he found in his stores. We simply find medetsinsky alcohol or ethyl. Vodka will not work.
For Sale Saito T2DR W/ B2F BOILER AND BURNER applegeekz Boats (FS/W) 1 Dec 20, 2013 02:49 AM
Sold SAITO T-2 DR Steam Engine + XB-2F Burner/Boiler scottpdotnet Boats (FS/W) 0 Jun 25, 2011 10:22 PM
Sold Saito B2F Boiler and burner New In Box subdude17349 Boats (FS/W) 2 Nov 17, 2010 09:50 AM
For Sale Saito T-2 steam engine & XB-2F boiler/burner kenroeh Boats (FS/W) 2 Dec 15, 2009 07:23 PM
Yippee! Saito 125 Gasoline Burner!!!! Brian Mitchell Engines 6 Oct 11, 2008 06:14 PM
