Old Oct 21, 2014, 09:51 AM
Grich's Avatar
Joined May 2002
[QUOTE=theKM;29739018]...you could run small 2S and 3S planes, and connect an X10 to the motor pack which doesn't drive any servos. Drive your servos off the Nano or a second Nano/X10 bound as slave with normal power... voila! motor pack telemetry
So now there is a need for an X10 with only receiver pins and power pads, no servo pins!
Grich is offline Find More Posts by Grich
Old Oct 21, 2014, 10:38 AM
Passion
Joined Sep 2009
As you sugest you now need 2 x Nano and a X10 or even 2 in a small 2s or 3s plane. Apart from the expence, space is a problem. And a lot of wires.
Swen is offline Find More Posts by Swen
Old Oct 21, 2014, 11:07 AM
Grich's Avatar
Joined May 2002
The two nonos were just what could be done, an idea. for small planes all u would be adding is an X10 board only attached to the nano and two small wires for voltage monitoring.
Old Oct 21, 2014, 11:20 AM
Passion
Joined Sep 2009
In that case I could imagine I am Donald Trump and then I am rich. Just an idea.
Old Oct 21, 2014, 03:57 PM
Fly inverted, it's more fun.
tholmes345's Avatar
Joined Apr 2006
Originally Posted by tholmes345 View Post
I feel the answer is buried in here somewhere, but I cannot fine it, so.... Does the x10+ and a nano provide Rx voltage feedback to Tx without adding another device? Mine is a Hitec A9.
Thanks to whoever has the answer.
Tom
And I still don't have an answer that I understand. I guess I have to ask a convoluted question to get a straight answer. A simple yes or no would be helpful.
I should have said also that my A9s each have an XPS module.
tholmes345 is offline Find More Posts by tholmes345
Old Oct 21, 2014, 06:37 PM
Rangers Lead the Way
Joined Mar 2010
The answer is no. The Nanos do not, and will not, support this. If you want to get RX voltage on the A9, you have to use an RFU, or one of the older "full size" receivers. And if it is main pack voltage you want on an EP setup, as is provided by the Hitec Optimas, you will have to add a telemetry system for that.
TTRotary is online now Find More Posts by TTRotary
Old Oct 21, 2014, 08:44 PM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
[QUOTE=Grich;29740353]
dremel!
theKM is offline Find More Posts by theKM
Old Oct 22, 2014, 06:06 AM
tholmes345's Avatar
Joined Apr 2006
Thank you.
Question X10+ Expander with Nano - customer comments please... JimDrew Xtreme Power Systems 48 Sep 22, 2013 09:54 PM
Discussion Channel expander question Engineer Bill Xtreme Power Systems 9 Jun 24, 2013 05:08 PM
Sold Parkzone X10 6 channel transmitter Tampatexan Aircraft - General - Radio Equipment (FS/W) 0 Jun 10, 2012 07:15 AM
Sold Berg 5 channel receiver w/ 4 channel expander Fizzy Aircraft - General - Radio Equipment (FS/W) 0 Oct 02, 2008 05:52 PM
