Old May 28, 2013, 02:13 PM
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Arthobby Odyssey 2,7 M Special
Just got this beauty,
Ordered it in Poland and it arived after 12 days.
Came in dobbel cardbord box in good shape with GLS.
Looking great.
I will make it with flaps and ailerons, and with dihedral and no ears.
But only time for a short sneek peek today
Arthobby Odessey 2,7 unboxing (1 min 54 sec)
More will come
Cheers
S
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old May 28, 2013, 07:01 PM
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
I never make my sailplanes with ears.... Your English is far better than my Danish.... but I don't know what you mean.
(actually, I know only one word in Danish.... øl)
LVsoaring is offline Find More Posts by LVsoaring
Old May 28, 2013, 08:57 PM
I just want to fly.
sapok's Avatar
United States, CO, Thornton
Joined Jan 2002
I'll be starting my odyssey pretty soon. Have a tigra 1.4 to build first. Gonna bee keeping an eye on this thread.
sapok is offline Find More Posts by sapok
Old May 29, 2013, 12:03 AM
Joined May 2010
I mean dobbel or tribbel dihedral.
Old May 29, 2013, 12:50 AM
I'd Rather Be Flying
RCBlackSheep's Avatar
Stockton CA
Joined Feb 2009
I noticed you wasted no time getting those instructions and other paper stuff out of the way to see that beautiful wood. The fuse looks a tad larger than the Thermic's fuse. I like that extra room. Those wings are a thing of beauty....
RCBlackSheep is offline Find More Posts by RCBlackSheep
Old May 29, 2013, 02:54 PM
Joined May 2010
The days work, not much, Also rc club flying day.
Yes Black S, the fuselage is around 15 cm longer than the Thermic, and much more room in the front.
I think I will use a 3 cell 850 mha lipo.
Regards
S
Old May 29, 2013, 03:26 PM
Giorgos Stratakis
Stratigio's Avatar
Athens Greece
Joined Jun 2008
Subscribed too...
Stratigio is offline Find More Posts by Stratigio
Old May 29, 2013, 03:29 PM
Giorgos Stratakis
Stratigio's Avatar
Athens Greece
Joined Jun 2008
Even if it seems that you're in the speed-mode on this one, SDen.
Old May 29, 2013, 09:16 PM
ieyasu's Avatar
USA, CO, Fort Collins
Joined Sep 2010
Oooh. I've eyed this one hard recently. I'm glad to see Art Hobby planes get more exposure here of late, and especially this one
ieyasu is offline Find More Posts by ieyasu
Old May 30, 2013, 12:57 AM
Stockton CA
Joined Feb 2009
I'm using a 750mAh 3S lipo in my Thermic and it barely fits but I can fly all weekend on it. I may not wait til Arthobby has another Thermic available and just go bigger. I like what I see so far.
Old May 30, 2013, 12:51 PM
Joined May 2010
Today I made the 4 holes in the wing for the servos, and glued the center wing joyning with fiberglass.
Fit the servos in the fuselage and made the towcoupling, and mounted the tail boom and rudder.
And put on the horns, and made holes in the backend for the bowden cabel.
Yesterday I tryed the trick to spray the wing with 1/1 alcohol and water, this raises the wood and after a little sanding the wing is realy smooth, and ready for cellolose lak.
S
Old May 30, 2013, 02:31 PM
ieyasu's Avatar
Joined Sep 2010
Is there any particular reason you put the tow poin on the side of the nose? Or do you have one on each side? I can only recall seeing them on the very front of the nose before...
Old May 30, 2013, 03:24 PM
Joined May 2010
1 You dont feel it is on the side of the fuselage when towing.
2 You do not have to drill through the cg lead to make room for a nose coupling.
3 This type does not require much force to release.
5 Easy to make.
6 you could put it at the bottom, but then you must turn the glider upside down every time you engage.
7 It is much easier to connect to the line, than a normal nose coupling.
8. this will fit even in a small glider.
9. Cheap.
I have more than 40 gliders, only 2 with coupling in the nose.
Cheers
S
Old May 30, 2013, 03:43 PM
I just want to fly.
sapok's Avatar
Joined Jan 2002
5 Easy to make.
9. Cheap.
Cheers
S
Learn something new every day.
Old May 30, 2013, 10:34 PM
Stockton CA
Joined Feb 2009
Take a look at Speedster's video of his Thermic being towed with the tow hook on the side. It works very well and I couldn't see any adverse affects of it done that way. A pretty slick idea if you ask me.
http://www.rcgroups.com/forums/showp...1&postcount=21
Build Log Thermic 2.5M R.E.S. from ArtHobby Stratigio Thermal 234 Jul 27, 2014 03:55 PM
Sold Relist: Arthobby Thermic 2.5m RES BDK74 Aircraft - Sailplanes (FS/W) 1 Apr 22, 2013 09:57 PM
Sold Enigma DLG ,Arthobby 2.5m TreeFlyer Aircraft - Sailplanes (FS/W) 1 Feb 15, 2013 02:35 PM
For Sale JR610UL NIB 2 610 M RX's for sale special deal Eric Giorgiantonio Aircraft - General - Radio Equipment (FS/W) 5 May 21, 2008 05:43 PM
Help with a problem - Arthobby Serenity 2.5 M gingin Slope 23 May 27, 2005 02:19 PM
