Old Oct 13, 2012, 12:34 PM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
When is it empty?
Hey guys , if I have a 2200mAh battery ... how many mA can I use before the lipo is empty?
octane81 is offline Find More Posts by octane81
Old Oct 13, 2012, 02:03 PM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
If it is a LiPoy then when 80% of capacity has been used. 2200 X .8 = 1,760 mAh at which time the no load voltage should be approx. 3.7 to 3.75V per cell after around a 5 to 10 minutes rest.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Oct 13, 2012, 02:12 PM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
The reason im asking , is because i cant get my head around this test i did today.
As you see, OSD and watt meter show about same mAh used, and notice the voltage , 10.1v so its more or less VERY empty... 3.36v per cell.
What I dont understand is , why is a 2200mAh lipo empty after only ~1540mAh?
This is a good healthy NanoTech with a total IR of under 10.
iCharger put back 2048mAh in "Fast charge mode" confirming the battery was very empty.
Old Oct 13, 2012, 02:45 PM
Southern Pride
Sadly some instruments are not very accurate. Same goes for some chargers. There is a thread around here somewhere who shows some chargers being 10 to 20% of in their mAh in reading. One charger I tested years ago was accurate up to a certain point but past that point it was off by a power of 10X. I never believe any charger,data logger etc. until after I have ran numerious bench test on them.
Charles
Old Oct 13, 2012, 02:52 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
What was the load during discharge, full power or partial throttle?
Measuring at part throttle will involve averaging the current pulses, and perhaps both the OSD and the watt meter don't do a good job of that.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Oct 13, 2012, 03:01 PM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Pat MacKenzie
Part throttle , about 5 amps ... wot is 18amps .. hmmm
Old Oct 13, 2012, 03:14 PM
pmackenzie's Avatar
Joined Dec 2002
I would blame the averaging then.
Old Oct 13, 2012, 03:17 PM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Would you mind explaining what that is , and how it affects the the measurement?
Old Oct 13, 2012, 03:29 PM
pmackenzie's Avatar
Joined Dec 2002
At part throttle the current is fed to the motor in pulses.
It is not straightforward to measure and convert that pulsing current into a good representative of the "average" value as the battery sees it.
You could try repeating the test at full throttle, but with a smaller prop to limit the current.
Old Oct 14, 2012, 09:17 AM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Ok did a new test , full throttle with a smaller prop ... 8 amps max draw ... result is still the same ... current sensor and watt meter show ~1600mah .. and charger put back 2185mah...
im confused ... is BOTH current sensor AND watt meter wrong? or is charger wrong? i really drained the battery , and 2185mah put back in a 2200mah sounds about right .. was under 10v.
Charger is a iCharger , so its a well known brand ..any ideas?
Old Oct 14, 2012, 09:54 AM
pmackenzie's Avatar
Joined Dec 2002
Try putting the wattmeter in line during charge?
Discussion CEN aquajet dies when gas tank is half empty, not enough backpressure? killervette666 Racing Boats - Internal Combustion 6 Jun 27, 2012 12:45 AM
Discussion NEWBIE TTN hard to start or only start when gas tank is empty. mc02uk2002 Motorcycles 6 Oct 30, 2008 01:40 AM
Discussion A123 Balance when full or empty? flattop Batteries and Chargers 3 Sep 11, 2007 08:41 AM
When is a LiPo pack "empty"? CooHead Parkflyers 14 Apr 03, 2005 07:42 AM
TP 1320MAH gen 2 WHEN IS IT EMPTY? hingus2000 Micro Helis 8 Oct 23, 2004 05:55 AM
