Old Aug 03, 2012, 11:52 PM
Champlin, MN
Joined Feb 2010
Value Hobby Quadcopters?
I recently bought the mqx and I've decided I am going to build a bigger quad. I do want to eventually mount a camera.
I've got a control board and power distribution board coming from hobbyking:
http://www.hobbyking.com/hobbyking/s...dProduct=24723
I found this:
http://www.valuehobby.com/multicopte...unt-combo.html
Has anyone had any experience with this frame? I'm trying to decide which motors for it.
Their G450:
http://www.valuehobby.com/power-syst...or-kv1200.html
or
Their G400:
http://www.valuehobby.com/power-syst...ess-motor.html
I've got 4 x 30 amp ESCs and a bunch of servo lead extensions in the parts bin that should work. I should add that I'm new to quads, but not new to RC. I'm pretty experienced with scratchbuilding planes, and building helis from kits so the physical building part doesn't worry me at all. The board looks easy enough to configure via the LCD?
Any advice on the board or the frame/motors would be appreciated!
ferch is offline Find More Posts by ferch
Old Aug 04, 2012, 10:52 AM
Champlin, MN
Joined Feb 2010
Which of these two motors would be better for a 550 sized quad:
or
Both are 1200kv
Old Aug 04, 2012, 11:52 AM
Emress
sirbow2's Avatar
United States, SD, Rapid City
Joined Nov 2011
Niether you need 900kv -> 1100kv lower would be best. Maybe some 20-22l with 10x4.7 or a 1100kv motor with 9in props.
sirbow2 is offline Find More Posts by sirbow2
Old Aug 04, 2012, 01:42 PM
DeSoto MO
Joined May 2003
1200kv is fine with an 8x4.5 prop.
http://www.valuehobby.com/power-syst...ess-motor.html looks like a clone of the NTM Prop drives and is a motor I plan on trying for myself.
Nick_P is offline Find More Posts by Nick_P
Old Aug 04, 2012, 01:47 PM
Emress
sirbow2's Avatar
Joined Nov 2011
what i meant wsa that would be a higher kv which means a smaller prop and this is a 550mm quad which means he has 225mm/10in or so arms. i was thinking the props are too small?
Old Aug 04, 2012, 02:06 PM
DeSoto MO
Joined May 2003
I can only say from experience that 8x4.5 is not to small for 550mm. I currently run 1200kv on 8" props and it propels a 530mm quad at 1300g without problem. I am not saying this is the best combo, however it is a viable one.
Old Aug 05, 2012, 06:02 PM
Champlin, MN
Joined Feb 2010
I'm not opposed to ordering the motors from another site. Any suggestions for motors availabe online for around $20-$25 each?
Old Aug 05, 2012, 08:25 PM
United States, MD, Annapolis
Joined Jun 2011
I think it is better in general to run lower Kv motors with larger props, at least its more efficient. Then you have the option of using higher voltage lipo's if you want. For example this motor http://www.hobbyking.com/hobbyking/s...50kv_140w.html at 4S would be an option, probably with a 10 inch prop. I use 9 x 5 props on my 920Kv DJI motors at 4S and it is a perfect combo. And they are only 12 amp motors.
rampa202 is offline Find More Posts by rampa202
Old Aug 06, 2012, 04:26 PM
Champlin, MN
Joined Feb 2010
Based on some motor recommendations on this thread:
http://www.rcgroups.com/forums/showthread.php?t=1662630
I went with this motor:
http://www.valuehobby.com/power-syst...30-1100kv.html
The frames are similar sizes and the motors are similar. I ordered some 10x4.5 props for it. When I get them I'll put them on a watt meter and make sure I'm within spec - the dealer lists the motors with 11x5.5 props so I doubt I'll have any over-amping issues. If anything, I'll be running them well under their max and may end up upgrading to larger props down the road.
I'll ask the question again since nobody seemed to respond last time. What do you all think about this controller board:
Does anyone have any experience with the board? I'm not afraid of messing with programming a more complex board, but this one looked to be as "plug and play" as you can get, so for my first quad I figured it might be worth a shot.
Old Aug 06, 2012, 04:32 PM
Mortimer's Avatar
Joined Apr 2010
You might search.
129 pages about it here : http://www.rcgroups.com/forums/showthread.php?t=1675613
Mortimer is offline Find More Posts by Mortimer
Latest blog entry: 5V Power Supply
Old Aug 06, 2012, 05:13 PM
DeSoto MO
Joined May 2003
That is a fairly large motor and is probably better suited running a 9 inch prop. I am curious why you chose this motor. It is not mentioned in the thread you listed and is widely different from all of the other recommendations in this thread.
Unless you are carrying large payloads, a 76g 300watt motor seems over kill to me, even on a 550mm frame. You do realize that value hobby has the 28mm 400 size 50g motors in a 850kv rating that may work better with the props you ordered.
Old Aug 06, 2012, 05:30 PM
Champlin, MN
Joined Feb 2010
Thanks for the feedback. I saw in the other thread they mentioned NTM3530 1100KV - the 480 I ended up ordering looked similar. I saw the 400 sized motor on their site and though that 850kv would be too slow and the 1200kv would be too fast. The threads I've read all seemed to say you'd want motors in the 950-1100kv range. There's just so much info here on RCgroups it's hard to filter the useful info from the useless stuff.
Once they come in and I get it built I'll report back and let you all know if it's overkill. Worst case I guess I order some smaller motors and use those in the future for a bigger frame.
Old Aug 06, 2012, 05:52 PM
Mortimer's Avatar
Joined Apr 2010
Advanced Search > Search Titles Only > Show Results as Threads
This will usually quickly fulfil to your questionning.
Old Aug 06, 2012, 06:06 PM
Emress
sirbow2's Avatar
Joined Nov 2011
or i like to search ong google: keywords site:rcgroups.com
Old Aug 06, 2012, 06:15 PM
IamNabil's Avatar
United States, VT, Burlington
Joined Mar 2012
Too bad there isn't a thank button! Thank you to both of you.
IamNabil is offline Find More Posts by IamNabil
Cool Value Hobby Sabre 47 STANG KILLA SS 3D Flying 29 Aug 26, 2013 04:10 PM
For Sale NIB Cermark/value hobby 49" Yak 54 Vince_TT Aircraft - Electric - Airplanes (FS/W) 2 Jul 26, 2012 08:40 PM
Sold Value hobby c4240 1100kv NEW $20 3drcparts Aircraft - Electric - Power Systems (FS/W) 1 Jul 26, 2012 11:56 AM
Discussion Value Hobby 39" Yak-54 Experience mt_100 3D Flying 0 Jul 09, 2012 09:45 PM
Discussion New XAircraft X650 Value-4 Value-8 QuadCopter infmetry Multirotor Talk 0 Jul 14, 2011 01:45 AM
