Old Jan 18, 2005, 10:30 AM
S Thomas Ontario Canada n5r-5e1
Joined Jan 2005
Need help
Want to convert Goldburg senior falcon arf to electric .. What motor speed control battery do i need for good peformance
Robert Fleming is offline Find More Posts by Robert Fleming
Old Jan 18, 2005, 10:36 AM
Account closed
Joined Oct 2002
Welcome to RCGROUPS (E-ZONE) !!!!
What kind of performance are you looking for? How much do you want to spend?
Carlos
guapoman2000 is offline Find More Posts by guapoman2000
Old Jan 20, 2005, 02:32 AM
We come in peace.
Synth's Avatar
Canada, BC, Penticton
Joined Feb 2003
I think that bird would be a good candidate for an AXI 2820-10.
Synth is offline Find More Posts by Synth
Old Jan 20, 2005, 09:20 AM
Ron Daniels's Avatar
Kitchener, Ontario, Canada
Joined Jan 2001
Hi Bob!
Welcome to Ezone. It's good to hear from you!
The AXI 2820-10 mentioned above is what I have in that Chipmunk I showed you a year or so back. It swings the same propellor as your Cobalt 05G, but at about 6-700 more RPM, on 10 cells.
Assuming about a 5 lb AUW, the 05G would be being pushed pretty hard to give good sport performance. Running flat out just to maintain maneuvering speed is very hard on components. It is better to over-power, and fly throttled back.
I would want at least 500W, for good performance on a semi-symmetrical, high-performance sport plane. I use about 120 W/lb (input) in my V1, about 170 in my Super Chipmunk, and about 190 in my Sea Fury. The V1 is significantly faster than my first Tempest Mk V electric (the one you saw in London), and the other two will climb vertically to rediculous heights. On 1700's, the latter two fly so far throttled back that both have a duration in the 6-8 minute range.
The V1 and Sea Fury can be seen in video coverage of this year's Mid Am Lunch demo, here on E-zone.
For the Sr Falcon, I might consider something a little larger, for strong performance. Maybe the new AXI 2826,or the next size up of direct drive brushless. The new Astro 25 geared brushless would give stunning performance, with the right cell count and prop.
You'll want a controller in the 45A + range, unless you are running 18 or more cells.
If going with Nickel cells, the "latest" for duration:weight at higher currents, like you will be drawing, are the GP 2000/2200, and the Sanyo 1950 FAUP. I also like the CP series NiCd's, but I find the 1300's start to have trouble pushing out the current above 35 A or so. The 1700's seem to handle up to 50A without losing much power.
Ron Daniels is offline Find More Posts by Ron Daniels
Old Jan 21, 2005, 10:03 AM
Joined Jan 2005
money s not a problem
Carlos
moneys not the problem Bob
Old Jan 21, 2005, 10:06 AM
Joined Jan 2005
[QUOTE=Synth Hog]I think that bird would be a good candidate for an AXI 2820-10.[/QUOTE
Went with axi 2826 45 amp speed control What battery is best
Old Jan 21, 2005, 02:39 PM
We come in peace.
Synth's Avatar
Joined Feb 2003
Can't help there as I have no experiance with the larger AXI.
The faup are good cells and will supply plenty of go.
I need help sourcing a GWS A-10 slowflyer Electric Plane Talk 11 Mar 02, 2010 07:24 PM
I need help with motor timing. jtthebiggafigga Electric Plane Talk 3 Jun 09, 2001 11:12 PM
Need help cleaning CA off of Ultracote Ken Lapointe Electric Plane Talk 3 May 21, 2001 06:23 AM
Need help with 400 for park flyer Cpietro Electric Plane Talk 2 May 21, 2001 01:35 AM
Painting Fiberglass (need help) Steve_S Electric Plane Talk 5 May 10, 2001 01:23 AM
