Old Sep 01, 2014, 06:44 AM
United Kingdom, Wales, Betws-y-Coed
Joined Aug 2014
Help!
Uk foam board
Hi mark here from North Wales uk , I have built a FT22 and powered it with a blue wonder however it will not fly on anything less than full throttle and then slowly ! . Is the foam board in the uk heavier than the USA ? . I have tried removing the paper from the inside but after half an hour soak in methylated spirits wont come off without shredding :-( , what can I do ? Bigger motor ?
markwoody is online now Find More Posts by markwoody
Old Sep 01, 2014, 07:30 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
How about some pictures ?
Prop on the right way round ?
Which motor, kv etc ?
What battery ?
What prop ?
Total flying weight ?
CG correct ?
eflightray is offline Find More Posts by eflightray
Old Sep 01, 2014, 11:35 AM
Joined Aug 2014
Prop is 8x3.8 (on the correct way)
motor is 24g 1500kv Blue Wonder brush less
ESC is 12a LBEC (all 3 bought as kit)
Battery is 3 cell ( tried a 2 cell but couldnt get the CoG )
CoG is spot on where it is on the plans (touch nose heavy if anything)
AUW , no idea , not got accurate scales yet
Built to the flite test plans ,with 5mm foamboard and their recommended motor etc
needs full throttle just to stay in the air ,no way pull vertical ,cant even do a loop !
this is my first RC plane ,first scratch build , i hope to get it going a bit better , dont need fast at this point in learning , but i do want it to be able to hold level flight
maybe i should just build a lighter airframe
Old Sep 01, 2014, 02:04 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Too much weight can be a major problem with the smaller models, especially the lower powered ones, so always try to keep the weight down.
Sorry, can't help a lot, never used the Blue Wonder motor or foam board, (prefer Depron).
Also the battery size/weight can make a difference. For that size of model I would have thought a max 1000mAh 3s, anything bigger is just weight.
You could try a different prop, perhaps a GWS HD 7x6, but if the planes heavy, it may not make much difference.
Build light, enjoy the flight.
Old Sep 01, 2014, 02:09 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
If you are thinking of building another F-22, there are plenty of versions here in this forum.
Just use the 'Search this Thread', (upper right in the Foamies forum), enter F-22, also set it to 'Show Threads'. Plenty of free plans in the forum as well, look under the 'Sticky' threads at the top.
Old Sep 01, 2014, 02:27 PM
Stuck on a rock
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
I run a 1700kV Blue Wonder motor on a 3S800mAh pack and a 7x5 prop. AUW of the 80cm span model is around 280gram and it has unlimited vertical performance.
You don't say what the capacity of your lipo pack is. What RX and servos?
epilot is offline Find More Posts by epilot
Discussion UK only - blue or pink foam for scratchbuilding..... denvoyager Foamies (Scratchbuilt) 23 Sep 07, 2014 09:25 AM
Idea UK EU Foam Board Distribution? thecanadianchris Foamies (Scratchbuilt) 5 Jul 04, 2014 11:19 AM
Discussion Trying to source foam in UK for a fpv49-v3-kfm-4 build godonholiday Foamies (Scratchbuilt) 1 Apr 06, 2014 07:39 AM
Discussion Dollar store foam board in the UK? Bowerz Foamies (Scratchbuilt) 6 Nov 24, 2009 01:56 PM
Discussion UK Foam - anyone tried floormaster foam board from B&Q RJPIoW Foamies (Scratchbuilt) 22 Oct 03, 2008 04:49 PM
