Old Aug 23, 2014, 11:25 AM
Kauai
Joined Jan 2011
Now that's a gear box!!!
Kauaiguy is offline Find More Posts by Kauaiguy
Old Aug 23, 2014, 11:34 AM
heli_haven's Avatar
United States, SC, Moncks Corner
Joined Mar 2012
Even with all the steel gears and bearings, it's still way lighter than the dual belt drive, and a lot more compact...and takes nowhere near the input to turn it...
heli_haven is offline Find More Posts by heli_haven
Old Aug 23, 2014, 11:43 AM
Kauai
Joined Jan 2011
That's what I thought would be the case!Ive been a believer for quite awhile .Looks like you should run ultra light oil and not very much so not to waste power on oil friction.
Old Aug 23, 2014, 03:04 PM
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
Agreed, this is where the Diamond Lube comes into play. Lowest frictional numbers ever recorded.
Btw, Troy sent me some new grip pins for my Triabolo. Guys, they were just amazing. So much better than the stockers. Thanks Troy!
Luvmyhelis is online now Find More Posts by Luvmyhelis
Old Aug 24, 2014, 07:34 PM
AMA# 548800
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
If you just want lube , use the motorcycle chain sticky lube . It's sealed and won't ever leave the gears
jombo is offline Find More Posts by jombo
Old Aug 24, 2014, 08:18 PM
Australia, VIC, Melbourne
Joined Feb 2010
Now that's just art!
How much does it weigh? Do you have expected power handing numbers?
desertstalker is offline Find More Posts by desertstalker
Old Aug 24, 2014, 09:09 PM
heli_haven's Avatar
Joined Mar 2012
Right now it weighs 290 grams with the end cap to mount the motor..alot of Jenny Craiging still left to do...but still less than the belted primary reduction unit and main pulley setup on my 600 I made..
I have no earthly idea how much power it'll handle...way more than I'll ever be able to throw at it I imagine...
Old Aug 25, 2014, 11:39 AM
Coaxial to CP? *shrugs*
ShaneXman's Avatar
United States, CA, Laguna Niguel
Joined Nov 2011
*lurks*
-Shane
ShaneXman is offline Find More Posts by ShaneXman
Old Aug 25, 2014, 10:24 PM
Kauai
Joined Jan 2011
Aerodynamic Quad
Here's a picture of my latest speed quad (frame weight 265g), just a bit lighter then your gear box.
Old Aug 26, 2014, 06:26 PM
Atomic Skull's Avatar
Joined Dec 2011
I wonder if you could make one of these with plastic gears to lower production costs?
Atomic Skull is offline Find More Posts by Atomic Skull
Old Aug 26, 2014, 11:40 PM
Joined Feb 2010
I would think it possible, there is plenty of tooth engagement. Making some of the gears from nylon would also remove or reduce the need to lubricate.
Old Aug 27, 2014, 06:28 AM
heli_haven's Avatar
Joined Mar 2012
Originally Posted by ShaneXman View Post
*lurks*
-Shane
SHANE! Back from vacation?
Old Aug 27, 2014, 06:34 AM
heli_haven's Avatar
Joined Mar 2012
The biggest expense are the ring gears...never seen those in plastic or nylon? Plus being all steel this thing is damn near bullet proof..... *eventually* it'll be in a heli swinging 1200mm blades...Just time consuming making it all..I made a new outer casing over the weekend...needed another 5mm in length to accommodate the end cap for the output end.
Old Aug 27, 2014, 02:10 PM
United States, MO, KCMO
Joined Nov 2013
1200mm blades
Wow! Been lurking watching this build. How long is this machine gonna be? Raised tail? thanks for shareing!
wingman tony is offline Find More Posts by wingman tony
Old Aug 27, 2014, 02:15 PM
ShaneXman's Avatar
Joined Nov 2011
Yup! Been busy with some home improvement projects, but I'm hoping things will lighten up in the not so distant future so I can get back into the heli game.
How's the big job coming?
-Shane
Alert Builder's workshop- Wed. 2/26/14 @ 7pm golliher Stone Mountain RC Flyers 18 Mar 03, 2014 04:18 PM
Discussion IMAC Workshop - Come try it!! Dean Bird Competition Aerobatics 4 Jan 19, 2014 06:37 PM
Careful! Be careful what you wish for, moved to Builders workshope kenh3497 Scale Fuel Planes 0 Nov 09, 2013 04:04 PM
Discussion Take Workshop Safety Serious Chophop Life, The Universe, and Politics 17 Oct 04, 2013 09:08 AM
