Old Mar 18, 2014, 09:22 PM
Seahawks
Palm Desert Heli's Avatar
United States, CA, Palm Desert
Joined Jan 2014
DX6i install throttle ratchet strip? Helps?
Install DX6i throttle ratchet strip? Does it help? I find I change throttle position while making rudder inputs. I had a wltoys heli and the TX had a built in ratchet. It seemed easier to keep a steady throttle.
Palm Desert Heli is offline Find More Posts by Palm Desert Heli
Old Mar 19, 2014, 03:40 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
I removed the ratchet from my Futaba set when I got into helis because I found the steps between one ratchet position and the next were too coarse for good control of the cyclic. One notch would have me climbing, and the next one had me sinking, I could never find a good compromise.
Removing the ratchet made all the difference, and I've got used to it (didn't even think twice about it) with my fixed-wing models too.
abenn is offline Find More Posts by abenn
Old Mar 19, 2014, 04:50 AM
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
I've flown helis with and without notches. Never seemed to make much difference.
arbilab is offline Find More Posts by arbilab
Old Mar 19, 2014, 02:40 PM
My other addiction!
norcalheli's Avatar
Marysville, Ca., US
Joined Jan 2007
Like abenn said, you find you are almost always "between" notches. Either too little or too much, or you have to try and hold it on the "tip" of the notch. Better to increase the tension on the throttle a little, so that it doesn't move as easy when you apply rudder. If you're flying CP you will always be adjusting throttle/Collective anyway, especially as you start banking turns.
norcalheli is offline Find More Posts by norcalheli
Old Mar 19, 2014, 04:38 PM
holtneil's Avatar
United Kingdom, England, Central Bedfordshire
Joined Dec 2012
+1 to that cp heli need constant throttle pitch changes , best to learn with out a ratchet , when i started i have the same problem , you will master it mate trust me it will come right
holtneil is offline Find More Posts by holtneil
Old Mar 19, 2014, 05:23 PM
Seahawks
Joined Jan 2014
Better to increase the tension on the throttle a little....OK.
Great info. Cheers!!
Found DX6i/DX7 Ratchet Strip Suko Aircraft - General - Radio Equipment (FS/W) 2 Jan 20, 2014 11:43 AM
Found DX7s Throttle Ratchet Strip(Wanted) jeb6684 Aircraft - General - Radio Equipment (FS/W) 2 Aug 01, 2013 02:21 AM
Found WTB- Air Ratchet Strip for Spektrum DX6I tinker31 Aircraft - General - Radio Equipment (FS/W) 1 Jul 05, 2012 08:06 AM
Wanted DX6i Air Ratchet Strip Vito Aircraft - General - Radio Equipment (FS/W) 0 Jan 09, 2012 05:17 PM
Found DX7 Throttle Ratchet Smooth Metal Strip wizzinbya Aircraft - General - Radio Equipment (FS/W) 5 Feb 20, 2010 10:54 AM
