Old Jul 03, 2013, 08:19 AM
South Africa, GP, Alberton
Joined May 2007
Question
Which Cutting Bow is better
Hello Gents
I'm looking at building myself a cutting bow, just want to find out what type would be better and what the reason would be.
BDaniell is offline Find More Posts by BDaniell
Old Jul 03, 2013, 08:32 AM
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
i would go with the right one, the PVC pipe one. looks simpler and easier to control+make.
Teddy Ong is offline Find More Posts by Teddy Ong
Old Jul 03, 2013, 08:51 AM
poormansairforce's Avatar
United States, OH, London
Joined Mar 2013
I built mine from a FG driveway marker from Home Depot and some pine blocks with holes drilled through them. Very light and cheap! I notched the outside of the legs to hold the looped and twisted wire.
Description: Name: DSCN3017.JPG
Description: Name: DSCN3015.JPG
Description:
poormansairforce is offline Find More Posts by poormansairforce
Old Jul 03, 2013, 11:50 AM
Canada, BC, Vancouver
Joined Nov 2012
I've tried both, and I prefer your first design. Adjustable tension is really nice, I used a heavy cotton cord/rope for the tensioner and it works the best. I use this with 175lb SS leader wire for the hot wire. Other option is to have springy arms on it to hold the wire in tension. Most wires do stretch when heated, so keeping tension on them is important to having a straight wire cut.
CarlN is offline Find More Posts by CarlN
Old Jul 03, 2013, 02:06 PM
Canada
Joined Nov 2000
Stainless steel as in braided fishing leader OR control line wires, stretches MUCH less than Nichrome wire.
Bare is offline Find More Posts by Bare
Old Jul 03, 2013, 07:43 PM
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Yes! Use Nichrome only if you feel the need to use an expensive and inferior product.
Whiskers is offline Find More Posts by Whiskers
Old Jul 03, 2013, 07:47 PM
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
I have used the first design and it works for me. I have a rubber bungee keeping tension on the stainless steel single strand leader material. The rubber bungee does not need to be adjusted as it will take up the slack.
High Flyin' is offline Find More Posts by High Flyin'
Old Jul 04, 2013, 01:31 AM
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Originally Posted by BDaniell View Post
Hello Gents
I had great luck with a coping saw... I took out the saw blade and just wrapped the nichrome wire (30 gauge?) around the mounts. Tightening it up gave me plenty of tension on the wire.
marhar is offline Find More Posts by marhar
Old Jul 04, 2013, 07:03 AM
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
Why not the second one? i realise you have to do the tension right the first time, since it's not so easily adjustable, but the mechanics will be simpler?
Old Jul 04, 2013, 07:48 AM
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Here’s the bow we’ve used successfully for many years now... cut everything from wings to fuselages, paddle boards, and even the 10’ foam slabs for my current Foamie trailer build (the rolling Hanger)
It works ...
gpw is offline Find More Posts by gpw
Old Jul 04, 2013, 07:56 AM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
For a given stiffness the wood type with the twisted string tensioner will be much lighter.
Low weight will make it easier to feel the actual cutting forces.
One change I would suggest is to only have the hinge/pivot on one side. The bow will be more stable this way.
http://www.rcgroups.com/forums/showt...61#post1475377
(Old post, I still have the same bow. It was probably 10 years old back then!)
pmackenzie is online now Find More Posts by pmackenzie
Old Jul 04, 2013, 08:03 AM
Slipping the Surly Bonds
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Attachment 5925340Attachment 5925341Attachment 5925339
Nice!
Would you post some dimensions and angles?
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Jul 04, 2013, 11:20 AM
Joined Mar 2013
Originally Posted by dz1sfb View Post
Nice!
Ken
Not 100% sure but it looks close to 15 degrees on the legs. There is 24" between the 3/4" pine blocks and it will cut 27" wide. The legs project down 8" from the long FG segment. The FG just press fits into holes I drilled all the way through the pine on a drill press with a fence. Its one driveway marker cut into three pieces, if you need more length use one for the long segment and if you use a thicker block you can use two pieces for more force on the wire. It would work best if you crimped loops with fishing leader crimps. I have a 3 part video series on my hotwire table setup with a hotwire scroll saw attachment using templates. It also includes a 7 wire bow so I can cut 2" foamboard into six 6mm foam sheets or part out 6 planes at a time!
My hot wire table: part 1 (10 min 1 sec)
Old Jul 05, 2013, 08:54 AM
Jab69's Avatar
Joined Sep 2009
Hi
I would go fort the first bow.Would just let the one leg move and use a spring to keep the tension.I let mine hang from the roof off a counter balance( bucket with weights in). When I make vertical cuts I control the cutting speed by taking weights out the bucket.
Jab69 is offline Find More Posts by Jab69
Old Jul 05, 2013, 12:58 PM
Registered DLG addict
NighthawkF-117's Avatar
Minnesota
Joined Jan 2009
I prefer the first design. I use Inconel wire for mine. Have cut about 15 wings on the same wire with no breaks. Also doesn't stretch when hot.
Stuff here,
http://www.cstsales.com/tekoa_hot_wire.html
NighthawkF-117 is offline Find More Posts by NighthawkF-117
Discussion Which wire from power supply to bow? jtprouty CAD/CAM 1 Feb 05, 2013 05:54 PM
Discussion which controller is better ! mohamednon Multirotor Electronics 20 Jan 21, 2013 05:23 AM
Help! GPS choice which is better? JaredReabow Cross Country Soaring 2 Jan 14, 2013 08:13 PM
Help! GPS choice which is better? JaredReabow UAV - Unmanned Aerial Vehicles 0 Jan 14, 2013 04:41 PM
Discussion Which Dual redandecy UBEC is better ? sharonx Power Systems 0 Jan 11, 2013 12:56 PM
