Old Yesterday, 08:22 PM
Arducopter Developer
R_Lefebvre's Avatar
Joined Oct 2010
30 minutes flights with 5-10 kg payloads, maybe more.
R_Lefebvre is offline Find More Posts by R_Lefebvre
Old Yesterday, 09:05 PM
Official Stupid Question Asker
TheQuestor's Avatar
United States, TX, San Juan
Joined Mar 2013
Originally Posted by R_Lefebvre View Post
Another breakthrough. As far as I know, this is the first use of Arducopter on a gas powered helicopter. This opens up a world of possibilities:
That thing sounds like my weedwhacker. Is that a little 2 stroke engine?
TheQuestor is online now Find More Posts by TheQuestor
Latest blog entry: QTipToo.8 Part 5
Old Yesterday, 09:18 PM
Franklin, TN
Joined Jul 2005
Originally Posted by TheQuestor View Post
I use the S.Bus to CPPM converter
http://www.alofthobbies.com/frsky-sbus-converter.html
To connect my RX using S.Bus to my APMS using CPPM
it is 8 channels this way but you can use 8 channels PWM on the RX as well to do other things
I have my S.bus set for channels 1-8 and then PWM 9-16
So my APM gets 8 channels with a single wire cPPM and my gear and gimbal can use the other 8 channels not through the APM if that makes any sense.
I just setup both of my APM quads with this and its great to only have one wire from RX to APM. Very clean and as was stated I now have 8 more channels off the RX for other stuff if I need it.
twilliams is online now Find More Posts by twilliams
Old Yesterday, 09:21 PM
R_Lefebvre's Avatar
Joined Oct 2010
It's a Zenoah G29RC, basicallly a little weedwacker engine, yet. Pretty common in gasser helis. They don't have fantastic power/weight, but are very reliable.
Old Yesterday, 09:45 PM
TheQuestor's Avatar
Joined Mar 2013
Good god that is expensive! It's odd how it looks like just about every engine for weedwackers and blowers and what not. But I guess it would be far more reliable than electric motors and everything needed to keep them spinning
Old Yesterday, 11:15 PM
R_Lefebvre's Avatar
Joined Oct 2010
As I understand it, it really is just taken out of a weedwacker, or chainsaw. They just sell it prepped for hobby use. Reliability compared to electric motors, I guess we'll see. Brushless motors should be very reliable, but they seem like they're not in practice.
Old Yesterday, 11:30 PM
TheQuestor's Avatar
Joined Mar 2013
Is the gas feed pressurized? I would think flying inverted would starve the carb and down it would come.
Old Today, 03:15 AM
Australia, SA, Adelaide
Joined Aug 2012
Just a Walbro carby (or copy) which includes an engine pressure driven fuel pump..
mpjf01 is offline Find More Posts by mpjf01
Old Today, 04:00 AM
jab
Unregistered User
Joined Aug 2007
The principle of electric motors means they ARE very reliable. It's just that the RC marked is saturated by low grade cheap motors and electronics made by inexperienced factory workers and no QA.
One of my other interests is electric bicycles. And my daily workhorse bike that I use for commuting to work has now done more then 20.000km. The bike has literally been rebuilt many times as parts wear out, but never a motor problem.
jab is online now Find More Posts by jab
Old Today, 05:42 AM
R_Lefebvre's Avatar
Joined Oct 2010
Yep, it's not a problem. Guys do acrobatics with these machines.
jab: Yep, that's why I said "should" be reliable. The only part that should be subject to wear and failure is the bearings, which should last a long, long time. Part of the problem with multirotors is, I think, trying to pack too much power into a small motor, with undersized shafts and bearings.
But that being said, the biggest problem really is just poor manufacturing. They're cranking these things out on worn out CNC machines that can't cut a round bore, so the bearings die prematurely. And/or, using cheap bearings. Poor winding techniques, etc.
I have the new KDE motors on my quad, and they should be very reliable indeed.
But, we also have a problem with ESC's. That is probably due to again, poor manufacturing, but also amateurish design and software. For one thing, a lot of problems are caused by using a time-analog control signal in a very electrically noisy environment. This is what is causing problems for everybody in the larger motor sizes.
Anyway, one guy has already given me the guilt trip on my video. People have to keep in mind, that even if I "fly electric", I have to run a generator on the ground to charge the batteries. So I'm still burning gas. The gas heli just skips a step.
Old Today, 05:52 AM
United States, NC, Charlotte
Joined Jan 2007
Walbro was carb of choice for all my gasers. When I was a tool and die maker AND we made STUFF in USA, I made dies for Walbro carbs, and many others like Stromberg, Carter and Holly. Walbro had tightest QC of all. I bet they are made off shore now!
Tim
w4yn is online now Find More Posts by w4yn
Old Today, 05:55 AM
Joined Jan 2007
[QUOTE=jab;29487257]The principle of electric motors means they ARE very reliable. It's just that the RC marked is saturated by low grade cheap motors and electronics made by inexperienced factory workers and no QA.
The 3 phase motors we use today are fantastic to the brushed motors we used in 90's. The small micro birds that still use brushed motors are plagued with early motor failures!
Tim
Old Today, 07:36 AM
R_Lefebvre's Avatar
Joined Oct 2010
Yep, most brushless motors are definitely better than brushed motors back in the day. Well... no more headaches with brushes. But I never had bad bearings back then. Now you get that due to poor machining. I've got a bunch of NTM motors that are junk.
For Sale ArduPilot Mega 2.0 + Accessiories (PRICE REDUCED!) tresani Aircraft - General - Radio Equipment (FS/W) 1 May 18, 2014 10:19 PM
For Sale ArduPilot OSD MinimOSD and other items for ArduPilot Mega Ecibob Aircraft - Electric - Multirotor (FS/W) 5 Jan 17, 2013 10:59 AM
Sold Ardupilot Mega APM 2.0, SONAR, MinimOSD, Telemetry, Quad PDB kingiggy262 Aircraft - Electric - Multirotor (FS/W) 3 Sep 18, 2012 02:13 PM
For Sale Ardupilot Mega APM V1/900 MHz Xbee/Bixler Chassis - $300 shipped justjason Aircraft - Electric - Multirotor (FS/W) 2 Jul 13, 2012 01:22 PM
Wanted Trade: My Ardupilot Mega (APM) for a Hover Fly Pro Adidas4275 Aircraft - Electric - Multirotor (FS/W) 2 Nov 21, 2011 08:26 PM
