Old Oct 09, 2012, 10:25 AM
DONT PANIC! :)
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
Question
epoxy or gorilla glue?
dudes i need advice before i build my flyfly mirage. yes i know theres a thread however im pretty sure someone here knows what is needed to put this model together...
what i have on hand right now is
epoxy
gorilla glue
foam safe CA (i doubt i should use)
im open to suggestions.
flyfly mirage EPS
out of stock is offline Find More Posts by out of stock
Old Oct 09, 2012, 12:17 PM
DONT PANIC! :)
Joined Jan 2012
i think ill go ape shh lol
Old Oct 09, 2012, 12:45 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Agreed, GG used sparingly. I also use a fine mist spray of water, and wipe any excess off that bubble out.
eflightray is offline Find More Posts by eflightray
Old Oct 09, 2012, 01:03 PM
DONT PANIC! :)
Joined Jan 2012
thanks for your kind response.
Old Oct 09, 2012, 04:41 PM
United States, TX, Leander
Joined Sep 2003
I've used a very fine line of GG on a stubborn canopy that wouldnt stay down. Solved that problem once and for all.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Oct 10, 2012, 08:37 AM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
GG or equivalent is the cats meow for sheeting foam core wings.
Ken
kenh3497 is online now Find More Posts by kenh3497
Old Oct 10, 2012, 09:26 AM
Joined Sep 2003
Oh Yeah! Works great for that. I used Elmers ProBond to do some sheeting years back. Works the same GG. But you have to watch it until it quits foaming and keep wiping it off. Its tough to sand next to foam core without damaging the foam.
Edwin
Old Oct 11, 2012, 01:57 AM
Joined Oct 2011
how do you get enough pressure to use gorilla glue? If the stuff isn't clamped really hard, you just get a brittle foam that's about as strong as popcorn.
Bill Mercer is offline Find More Posts by Bill Mercer
Old Oct 11, 2012, 08:03 AM
Joined Sep 2003
This is true. I spaced clamps every 1/2" apart the full length of the glue joint. Fortunately for me, on that side of the window is the door. With the door open, I had plenty of room. The window frame I glued to was only 1/8" wide. RC-56 worked fine on the other side but it was 1/4" wide, more area to bite.
Edwin
Alert Do not use Gorilla Epoxy on EPP or ELapor!! wootenelli Electric Plane Talk 13 Apr 30, 2012 08:12 PM
Discussion Epoxy Vs Gorilla glue? hidaven Electric Plane Talk 14 Oct 21, 2010 09:57 PM
Question !!!!gorilla glue or epoxy !!!!!!! MI crazy bob Racing Boats - Internal Combustion 2 Aug 17, 2009 06:13 PM
Discussion gorilla glue vs ?goop, or titebond, or epoxy grfcon Slope 10 Jan 22, 2009 11:16 PM
Question Can you put epoxy or Gorilla Glue over foam-safe CA? Spackles94 Electric Plane Talk 5 Aug 12, 2007 05:58 AM
