Old Apr 17, 2011, 10:35 AM
I AM SOFA KING WE TODD DID
wavekatcher's Avatar
Iceland, Westfjords, safjrur
Joined Mar 2011
changed esc, bec question
Need some help,
I am replacing a 45 amp junk esc (5amp bec), with a Pentium 60amp esc w/ 3amp 5 volt switching UBEC (built in).
I am running Don's 4000+ on a 4s 2200mah, and there are 8 servos in the plane. Any advice would be greatly appreciated.
wavekatcher is online now Find More Posts by wavekatcher
Old Apr 17, 2011, 10:47 AM
Harry H's Avatar
Los Angeles
Joined Oct 2010
I dont know what servos you are using but a 3 amp bec will not cut it. I just replaced another bec last night in one of my planes where I added flaps (2 more servos) with a total of 6 servos. I have the same servos in all my planes (JR 821) and had a CC 10 amp bec in all of them. After a discussion with a CC tech, I decided that 4 servos with the 10 amp was the limit. So I have replaced the 10 amp with the CC 20 Pro with anything over 4 of the servos I use.
Harry
Harry H is offline Find More Posts by Harry H
Old Apr 17, 2011, 10:56 AM
Joined Mar 2011
Thanks Harry.
using cheap stock servos that came w/ the plane. So, a 20 amp Bec should be good? Is it external? Easy to hook up?
How do I disable the internal bec on the esc? Thanks from a noob
Old Apr 17, 2011, 11:08 AM
Joined Mar 2011
Also the servos I am using are micro size 9g.
for the ccpro, you plug it into slot #6 & 7 on the rx. I need to use every slot in the receiver, but maybe I will have to do some mixing w/ the tx?
Old Apr 17, 2011, 11:23 AM
USA, NV, Caliente
Joined Mar 2009
With 8 analog servos, I think the 10a cc bec would on the edge depending on servo size and load. Like Harry said, if they are digitals forget about it and get the pro version.
another option is to divide the load between the on board esc bec and a seperate one. If you are using retracts, this should be done anyway to protect the system against a stalled servo. It would require almore wiring and work, but you have a much more reliable system.
crypto666 is offline Find More Posts by crypto666
Old Apr 17, 2011, 11:32 AM
Joined Mar 2011
What about using a battery pack for the receiver and servos and not have to worry about the bec?
Old Apr 17, 2011, 11:46 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If the additional weight doesn't cause a problem, the separate pack would be fine.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 17, 2011, 11:54 AM
Joined Mar 2011
Thanks everyone for the help! Happy flying
Harry H's Avatar
Los Angeles
Joined Oct 2010
Originally Posted by wavekatcher View Post
Thanks Harry.
It is very easy to hook up, just a little soldering involved. You disable the internal by removing the red wire coming from the esc lead, that will disable it.
Harry
Old Apr 17, 2011, 12:10 PM
Joined Mar 2011
Is it OK to use a Y harness to hook the ccpro to the receiver so I can utilize all my rx slots? The diagram shows the 2 plugs from the bec go into slot 6 & 7. I will need as many slots as I can get. (using an ar7010) Thanks
Old Apr 17, 2011, 12:19 PM
Harry H's Avatar
Los Angeles
Joined Oct 2010
I was just thinking about this myself. I used up all my slots on a plane last night and had to use a y-harness for both flaps and ailerons. I dont like to use a y on the ailerons. I think the standard leads are rated for 5 amps so maybe a high amp y-harness lead would work??
Harry
Old Apr 17, 2011, 12:25 PM
Joined Mar 2011
Thanks Harry, I just ordered a CCpro. Much less weight than running a rx pack. I will call CC and ask if it is ok to Y harness (high volt rated of course)
Old Apr 17, 2011, 12:30 PM
Garry
Tumble weed country Eastern Washington
Joined Aug 2004
I would call Castle Creations and ask them about using Ys on channels 6&7. The people at CC are very helpful with great customer service. I know you can Y a reciever pack and still use a servo on that channel.
crash-rc is offline Find More Posts by crash-rc
Old Apr 17, 2011, 12:56 PM
Harry H's Avatar
Los Angeles
Joined Oct 2010
This is good info. I didnt know you could do this. Thanks
Harry
Old Apr 17, 2011, 01:04 PM
Joined Mar 2011
When doing the solder job, do you use 60/40 solder or ???? Thanks
Discussion Why is a switch mode bec esc cheaper than a regular esc? seair Power Systems 8 Mar 24, 2011 02:14 PM
Discussion ESC/BEC Question smaze17 Electric Ducted Fan Jet Talk 36 Mar 14, 2011 12:14 PM
Discussion CC BEC question ScotY High Performance 9 Mar 08, 2011 02:50 AM
Discussion ESC with BEC and extra BEC together ? ptg Power Systems 7 Mar 07, 2011 12:22 AM
Discussion Quick BEC Question Blue Chip FPV Talk 2 Mar 05, 2011 01:58 PM
