View Poll Results: Will the deployment of the flaps cause the plane to
nose up 5 41.67%
dive 4 33.33%
experience no change in pitch 2 16.67%
explode 1 8.33%
Multiple Choice Poll. Voters: 12. You may not vote on this poll
Closed Thread
Old Feb 01, 2014, 02:20 PM
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Poll
Pitch neutral flaps
In the FootLoose Floater build, will the deployment of the flaps affect the pitch? Here's your chance to prove yourself ( or your luck ) before the maiden on Monday......no I'm not voting, but you should. check the box and Vote !
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Feb 03, 2014, 12:27 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Nose down as (mostly) the flaps are behind the cg.
vincent123 is online now Find More Posts by vincent123
Latest blog entry: FZ5: design phase
Old Feb 03, 2014, 12:34 PM
less is more
Knoll53's Avatar
Joined Sep 2006
But Vincent, don't those flaps also affect the airfoil directly in front of them, thus changing the lift of area of the wing in front of the CG?
Kent
Latest blog entry: Nosey
Old Feb 03, 2014, 01:11 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
The flaps I have on some flying wings show nose down event.
Are your flaps behind the cg?
Old Feb 03, 2014, 01:16 PM
less is more
Knoll53's Avatar
Joined Sep 2006
That's the $64,000 question......don't know.
Kent
Old Feb 03, 2014, 01:39 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
You don't know where your cg is located?
I saw you footloose hanging on the ceiling, so I m sure you know it
Old Feb 03, 2014, 01:44 PM
less is more
Knoll53's Avatar
Joined Sep 2006
The CG is at 12.25" from the nose, but the big question is whether or not the flaps and the airfoil that they modify are behind the CG.
Gotta go.....Kent
Old Feb 03, 2014, 01:48 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Could very well be that with your planform and flap location, your flaps will be neutral.
Old Feb 03, 2014, 02:49 PM
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Sooner or later all the science and guesswork ends, experience does what it can; and then the aircraft tells us what really happens. Isn't this fun?
HerkS is online now Find More Posts by HerkS
Old Feb 03, 2014, 05:24 PM
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
I think no matter what you'll either need some up or down aileron trim. I've never ever flown any kind of an airplane whether it is a model or full scale that does not need some kind of trim with flap deflection. The amount of trim changes with speed, obviously.
Curtis
PS I did not vote as there is not a correct option, IMHO.
Curtis Suter is online now Find More Posts by Curtis Suter
Old Feb 04, 2014, 02:39 AM
miniphase's Avatar
Kent, UK
Joined Nov 2004
It looks to me as if there is more flapped area ahead of the centre of lift (than behind it), so I would expect there to be a pitch up when you deploy the flaps.
Very much looking forward to seeing the maiden Kent...good luck!
miniphase is offline Find More Posts by miniphase
Old Feb 04, 2014, 09:05 AM
less is more
Knoll53's Avatar
Joined Sep 2006
Thanks for all of the responses. So it is clear to me, that I could have been a "little more clear" in writing the poll question. I think that I got more complaints than votes. The only accurate answer would have been "all of the above" which was not offered........(what fun would that be?)
To ask the question accurately probably would have been a page long. I guess what I was thinking was glide path change as it affects landings.
BTW, the flaps are pretty much neutral pitch with a little nose up. I hope to get a video of very slow flight with a slow flap deployment to show the effect.
Kent
Closed Thread
Discussion Can 'excessive' flaps cause pitch sensitivity? CNY_Dave Electric Warbirds 15 Nov 07, 2013 12:04 PM
Discussion Trex600E DFC tail pitch assy neutral position KTM250 Large Electric Helis 2 Sep 12, 2013 09:09 PM
Question Neutral speed stability still gives launch pitch-up? danstrider Hand Launch 27 Sep 04, 2012 09:11 AM
Question Determining flap neutral position? becsta Multi Task F3X 5 Jan 19, 2010 04:29 PM
Schulze Slim18BE propblem - neutral not neutral! JensJakob68 Electric Plane Talk 3 Dec 15, 2001 05:38 AM
