Old Jul 14, 2011, 09:36 PM
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
D/R Combo Switch on DX8?
I have the triple rates on ELE set to 30, 60, and 125 on the 3 position D/R ELE switch. I have the same rates set up for RUD and AIL 3 position switches.
On my DX6i, there was a D/R Combo Switch option that would change all three control surfaces at once to the pre-programmed rates so that I didn't have to choose the specific surface's switch while flying.
But I can't seem to find this option on the DX8. I looked in the menu and hunted through the options on the TX. Does anyone know how to do this?
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Jul 15, 2011, 02:33 AM
Central California
Joined Dec 2006
Once you set the rate on the selected surface go down to the bottom and select which switch you want it assigned to.
Not too hard to figure out.
aerocal is offline Find More Posts by aerocal
Old Jul 15, 2011, 08:13 AM
Epoxy & CA Investor
Joined May 2010
perhaps you didn't understand. I already have the surfaces assigned to their switches. Now i'm looking for a combo switch where i can control all three control surface throws at once.
Old Jul 15, 2011, 08:26 AM
RPatrick's Avatar
Hurst, Texas USA
Joined Jan 2002
Aerocal is correct.
At the bottom there is an entry for which switch you want to use to toggle between the different rate settings. It does not have to match the label. What you need to do is to select the same switch for rudder rates, aileron rates, and elevator rates.
For example, on mine I use the Elev D/R switch to change the rates for Elevator, Aileron, and Rudder at the same time.
RPatrick is offline Find More Posts by RPatrick
Old Jul 15, 2011, 08:52 AM
Epoxy & CA Investor
Joined May 2010
RPatrick - ah. That makes sense. I don't know why I didn't think of doing that. Thanks!
Old Jul 15, 2011, 12:02 PM
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
But it is a less functional solution than the DX6i where you retain individual and can add grouped control.....
Toppers is online now Find More Posts by Toppers
Old Jul 15, 2011, 03:59 PM
Epoxy & CA Investor
Joined May 2010
exactly. This is why i couldn't find it at first on the DX8. I agree the DX6i is a better solution.
Old Jul 16, 2011, 12:32 AM
Central California
Joined Dec 2006
No,it is far more functional than the DX6i by a long shot
Old Jul 18, 2011, 06:30 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
I agree with Aerocal, haven't taken out my Dx6i in a bit but when you activate the D/R combi and then select which D/R switch then of course all does all 3 surfaces
The DX8 way in selecting the switch for each surfaces, you can select the same switch for all 3 (COMBI) or just 2 and have the third surface on another switch.
It may be very simple on the DX6i but thats all it is SIMPLE. Its a much more affective way of doing it on the DX8.
freechip is online now Find More Posts by freechip
Old Jul 18, 2011, 07:18 AM
Halifax, NS
Joined Sep 2009
Just to clarify this a bit, you cannot have both individual and grouped control for the same surface on the DX6i. When you activate D/R Combi on the DX6i the individual switches no longer work.
karlpenney is offline Find More Posts by karlpenney
Discussion D/R on Controller thepittengineer Car Talk 2 Jul 06, 2011 06:54 AM
Discussion I.R. L.E.D. on/off switch and flasher Demo iflyrc1012 Night Flying 0 May 08, 2011 08:24 AM
Question Turnigy 9ch (v2) D/R & Expo on one switch? BKMorpheus Radios 2 Apr 01, 2011 01:49 PM
Multipule D/R on 3 position L switch dvetter Radios 2 Apr 03, 2004 10:08 AM
