Old Mar 24, 2011, 04:26 PM
Beaumont tx
drain lipos?
What's the best way to drain LIPOS to 50% for storage?
howell
gwinhh is offline Find More Posts by gwinhh
Old Mar 24, 2011, 04:37 PM
Joined Feb 2011
get a 30$ charger that has a storage program?
or use a lipo tester and something that pulls A (motor...lamp...)
and discharge to 3.7v
V_Okto is offline Find More Posts by V_Okto
Old Mar 24, 2011, 05:24 PM
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Have a few short flights before you go home
like2fly! is offline Find More Posts by like2fly!
Old Mar 24, 2011, 05:44 PM
United States, NJ, Frenchtown
Joined Mar 2003
MANUAL discharging is VERY RISKY for some of us. We forget to check every...each... cell every minute to make sure it does not go under the 50 % point. Long term under 50% does shorten the life of the battery. That is a real good number to use.
Some of us DO forget it is still being discharged if we get a call or visitor. ME !
FMA cell pros are very good fully automatic units.
cyclops2 is online now Find More Posts by cyclops2
Old Mar 24, 2011, 05:46 PM
Joined Mar 2003
Remembered.
I went to sleep & woke up next morning. Left it on charge all night.
FMA COMPLETLY shut off all the charging. SWEET.
Old Mar 25, 2011, 10:18 AM
Beaumont tx
howell
Old Mar 25, 2011, 07:32 PM
tacx's Avatar
United States, MI, Macomb
Joined Apr 2009
I have a charger that will do the discharge for me but it takes awhile to complete. I will never leave a charger unattended even if I am discharging. So, I will some times plug my batts into a automotive light bulb. I then set a timer, that is load enough for me to hear, for about 10 mins. Check the batt with a multi tester. If it needs more time just reset the timer.
tacx is online now Find More Posts by tacx
Old Mar 25, 2011, 07:45 PM
Joined Apr 2007
So if youre not going to fly for couple days you guys discharge to 3.7?
How many days we talking?
What if youre gonna fly early in the morning. Do you charge the night before or just wake up extra early and put the batt on the charger?
wopachop is offline Find More Posts by wopachop
Old Mar 26, 2011, 03:37 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
Everything I've read suggests that the reason for storing a LiPo at 3.85v is to reduce the risk of it self-discharging to below 3.0v or some lower value. So far as I can see, if you can be sure it's not going to go below 3.0v, you can benefit by storing it at lower than 3.85v.
Since I time my flights I know I've got at least 20% remaining at the end of a flight, so I just leave my packs like that until I need them again, assuming I'll be using them within two or three weeks. I've just checked one of my 6S packs that I flew last Sunday and, as it happens, it's currently at 3.83v per cell. Last week I checked a 4S pack that I charged to storage voltage last August, and it's still showing 3.85v per cell, so self-discharge doesn't seem to be a major problem -- at least, not with good named brands of cells (FlightPower and ThunderPower in my case).
I charge as near flying time as I can, but often that's the night before.
abenn is offline Find More Posts by abenn
Discussion Blade SR DX6i Lipo Battery Drain? afitz87 Mini Helis 9 Sep 22, 2010 01:20 PM
Discussion Blade SR DX6i Lipo Battery Drain? afitz87 Micro Helis 0 Sep 16, 2010 08:44 AM
Discussion Help Servo drain? badgerballs Power Systems 2 Sep 16, 2010 07:48 AM
Discussion Vintage thermal snifflers (varios): high battery drain or low drain? arukum17 Batteries and Chargers 0 Nov 05, 2007 05:19 AM
Discussion Lipos getting soft, high drain? michael503 Power Systems 1 Aug 27, 2007 11:31 PM
