Old May 10, 2013, 11:31 AM
USA, MI, Portage
Joined Sep 2003
Replacement Power for Brushed system
I have a old MRC Thunder Streak that comes with dual RS540s running to a gear box for a 1.5 to1 gear reduction. It is supposed to use 2 7.2v NiCad packs to power and has the micro switches to turn the motors on or off. I want to replace the power and motor system with a single brushless motor and a esc.
Any suggestions on what I should be looking at. I am not real familiar with the BL motor rating or sizing. In the instructions it says that with the stock power/drive it should go around 25mph. Bumping that up some would be part of the conversion. I don`t know what size prop is included as the manual does not say. How do you measure the prop?
skylane42 is offline Find More Posts by skylane42
Old May 11, 2013, 06:06 AM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Skylane,
Some pictures of the interior, showing how much room is available and some shots of the transom and side, to show the type of drive built in would help to make sensible suggestions.
Keep in mind ABS gets brittle over time if it hasn't been covered in paint.
Any excess motorisation will reduce it to rubble when you hit something in the water (or the shore)...
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old May 12, 2013, 09:38 AM
tenshock's Avatar
Joined Nov 2012
Agree with Jan... Some pictures will be helpfull to give you correct suggestion.
tenshock is offline Find More Posts by tenshock
Old May 12, 2013, 09:48 AM
USA, MI, Portage
Joined Sep 2003
Here are some pics of finished boat I found on net. The boat is 28 inches long. the 2 battery packs required for the boat sit in front of the gearbox flat longwise.
Old May 12, 2013, 03:27 PM
Sneek, Netherlands.
Joined May 2004
Hi Skylane,
Having seen the pictures, I seriously doubt if this design is suitable for upgrading to brushless power.
The steering outdrive isn't up to handling more power.
The rigid shaft limits the possibilities of adjusting the propangle.
All trailing edges are round (due to the vacuum forming) and need to be filled and sharpened to avoid the hull sucking itself onto the surface.
Due to the inner tray you don't have access to the bottom innards, making reinforcements rather difficult.
Upgrading an ABS hull requires beefing up the running surfaces and the transom, changing the rigid shaft to a flexshaft/strut combo with a seperate (offset) rudder.
Basically it's major surgery and quite a lot of work.
The choice is yours...
Regards, Jan.
Old May 12, 2013, 08:04 PM
USA, MI, Portage
Joined Sep 2003
Thanks for your opinion... I think I will take your advice and just go stock with it and just have some fun. I was looking at going BL because I could use Lipo for power but looks like I will be hunting some Nimh packs. Problem is the old school packs are more expensive than new lipo packs are... go figure.
Thanks again.
Old May 13, 2013, 05:17 AM
Sneek, Netherlands.
Joined May 2004
Hi Skylane,
You can use Lipo's to power brushed motors without any problems.
Just use a Lipo saver/buzzer to detect when the lipo's are getting depleted, to avoid damage to your packs.
Chances are the boat will run better/longer due to the lower weight of the Lipo packs.
Regards, Jan.
Old May 17, 2013, 08:37 AM
Gordonsville,Virginia
Joined Nov 2009
Just time your runs and you should not have any trouble .
highflyerbill is offline Find More Posts by highflyerbill
Discussion Very useful part for those looking to upgrade brushed power setups supercubcv Electric Plane Talk 1 May 04, 2013 04:33 AM
Discussion Brushed power system help appa609 Power Systems 6 Jan 08, 2013 11:40 PM
Corona power system: Jeti 300H ESC, 7 x 2400 Nicad, brushed motor, 2 sets brushes JoeR Aircraft - Electric - Airplanes (FS/W) 4 Dec 09, 2003 06:03 AM
brushed power system for a 40sized profile lagcisco Sport Planes 7 Oct 01, 2003 04:31 AM
Replacement for Wattage 370 power system simingx Power Systems 2 Dec 24, 2002 04:08 PM
