Old Mar 27, 2005, 11:01 AM
BEaumont Texas
Joined Sep 2004
Tango 45-8 with magnet thrown?
Test hovering my Hawk Sport E-conversion in pod and boom congiuration before final fitment into the 222 Fuselage..Running it with a 6S3P lipo and a Jazz 55-10-32 esc @ 80% . Picked it up into a hover and then set it down to adjust the gyro subtrim, spooled it back up and just when it ramped up to stable RPM ...POW!I thought my tail torque tube snapped or something because the tail blades came to a stop and folded them up.. When the mains spun down I tried to turn the rotor head by hand and it was bound.. Loosened the pinion and everything it free...Removed the motor and the shaft is locked up... I know some of the Tangos were notorious for throwing the magnets and I evidently got one...Good thing I was just spooling it up or this could have cost me a Heli....
Haldor, MotorMike>>>What do I do now????
Rick
Thavillan is offline Find More Posts by Thavillan
Old Mar 27, 2005, 12:37 PM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
You send it in to Kontronik Germany, should be warranty repair regardless of age as you'd be at max 20k rpm - well within the rpm range of the older Tango. The newer Tango have ~30k rpm limit.
-Haldor
Haldor is offline Find More Posts by Haldor
Old Mar 27, 2005, 12:49 PM
BEaumont Texas
Joined Sep 2004
What is the address to send it to and what info do I need to include with it?
Rick
Old Mar 27, 2005, 01:05 PM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Hi Rick.
Use:
KONTRONIK GmbH
Etzwiesenstraße 35/1
D-72108 Rottenburg-Hailfingen
Germany
Include details of your setup and contact info/return address.
Turnaround is within 48hrs after recieving the motor.
Old Mar 27, 2005, 02:02 PM
BEaumont Texas
Joined Sep 2004
Good deal, will be boxed up and ready to ship tomorrow..
Rick
Old Mar 28, 2005, 09:53 PM
BEaumont Texas
Joined Sep 2004
Tango is on it's way to Germany VIA Global Priority
Rick
Old Apr 06, 2005, 05:24 PM
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
uh oh!! I was going to ask a simple question till I saw this. My Tango 45-08 started cogging all of a sudden. I thought at forst maybe something got ingested into the huge holes in the back and stuck to the magnet causeing a slight gravity effect. i's not the bearings or anything either and everything else seems alright. I only spooled it up once in my 750 fan on 7S, but a funny magnet is starting to make sense. In the 40 second test I also kiled my Castle ESC, is it possible the mag cause alot of sudden resistance, or wold it simply fall off in power?
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Apr 07, 2005, 12:03 AM
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
A dragging/jammed magnet would cause a huge increase in current. So that is prolly what fried the controller. If you wanna sell the tango real cheap, let me know
DavidB. is offline Find More Posts by DavidB.
Old Apr 07, 2005, 12:17 AM
Joined Aug 2002
lol dont blame you for trying! But I'll send it in and get it fixed then see if it holds, if it does it again I'll make you a deal! hehe But the more I think about it it makes sense, and i wasnt cranking the ESC more than I have in the past, and the run was very short. And the motor actually hesitated before the ESC thats what made me look to the light on the ESC, thats when it burned. Still cant be sure though
Barry
Old Apr 07, 2005, 12:18 AM
Joined Aug 2002
And I take it these are not Kevlar or epoxy wrapped.
Barry
Old Apr 07, 2005, 09:35 AM
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
I would hope they are kevlar wrapped. Aveox used to use a very thin stainless steel tube to hold the magnets in, but kevlar row is by far the best.
Old Apr 07, 2005, 09:59 AM
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Unless they have changes lately the Tango is not Kevlar wrapped--the air gap is too little for much material.
FYI carbon is generally a better material for wrapping as it actually becomes tighter as it gets hot--also it has much better strength as it gets hot. The down side to carbon is that it is difficult to get in a small cross section that is easy to handle.
Steve
sneu is offline Find More Posts by sneu
Old Apr 07, 2005, 10:12 AM
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
I would have thought carbon wouldn't have the toughness for this application, but I've been proven wrong. Also, I can't believe they would be worrying about that tiny difference in airgap. I kevlar wrapped one of my rotors, and it decreased the airgap distance by maybe .007in. With a standard motor I could see this causing a problem, but when the total airgap is multiple mm's, I would think the extra insurance would be worth it.
Old Apr 08, 2005, 03:28 AM
Joined Aug 2002
didnt look like it was
Old Apr 08, 2005, 03:44 AM
Deutschland, Baden-Württemberg, Ebersbach an der Fils
Joined Dec 2001
I do not know one Tango of the newer series (3 years around now) which has thrown it's magnets. Kevlar wrapped is not necessary if you have the correct glue. We let them produce specially for the Tango. We have the limit at 30000 RPM for customers and enough reserve from the max. limit. The problem with the old glue was, that when it gets warm then cold and so on....the old glue is broken.
Motormike is offline Find More Posts by Motormike
Wanted Look to trade Neu 1912-1y for Tango 45-8 alexsand17 Aircraft - Electric - Power Systems (FS/W) 0 Apr 27, 2007 05:10 PM
Discussion Tango 45-08 with hacker 77 esc? TomC Electric Heli Talk 2 Dec 02, 2006 02:29 PM
Problem with starting a Tango 45-08 with a Jazz 32-10-55 nicco Kontronik 9 Jan 10, 2005 04:42 AM
Another Tango 45-8 throw the magnets Stig C Power Systems 13 Nov 19, 2003 11:37 AM
Tango 45-08 & Beat 40-8-24 rscamp Electric Heli Talk 18 Feb 20, 2002 05:52 AM
