Old Nov 05, 2004, 12:24 PM
CD Motor Supplies
Houston, TX, United States
Joined Aug 2004
T-Rex blades on Shogun??
I read on some forum somewhere that you could use Shogun blades on the T-Rex. Read somewhere else that the T-Rex blades are more durable than the Shogun too.
Why can't you use T-Rex blades on the Shogun?
Prices at Modefosheli.com:
T-Rex main blades $13.80
Shogun main blades $23.99
Just a thought.
jamesdh is offline Find More Posts by jamesdh
Old Nov 05, 2004, 12:45 PM
NJ
Joined Nov 2004
James,
Yes you could easily mount the Trex blades on a Shogun. The Trex blades are: more flexible(like corona blades) that's what lets them take a beating. However two negatives are that the blades weigh almost 2x the Shogun's blades and because they flex the disc(rotor) is not as rigid. Now the rigidity may not be an issue for you if you are not into aerobatics/3D, so if you are just hovering and sport flying give 'em a try. One last thing to keep in mind is the motor temp. The added load on the drive train(due to the increased weight of the blades) will put a higher strain on your motor. Make sure you use a heatsink on the motor and I would check the temp a few time during the first couple of flights. I hope this helps!
Regards,
Anthony
Art-Tistic is offline Find More Posts by Art-Tistic
Old Nov 05, 2004, 06:10 PM
DeSoto MO
Joined May 2003
Dont get the ABS Trex blades, get a set of the 315mm woodies. They are half the weight of the ABS blades plus increased rotor disk.
Nick_P is online now Find More Posts by Nick_P
Old Nov 05, 2004, 10:38 PM
TeamTP,Minicopter,Spartan
misskimo's Avatar
Mississippi 31 years , Now Kotzebue , Alaska 12
Joined Apr 2001
hey
like everyone said , the T-rex blades are made for learning . I dont think you can do this with any other blade
misskimo is offline Find More Posts by misskimo
Old Nov 07, 2004, 09:27 PM
CD Motor Supplies
Joined Aug 2004
Thanks everyone.
I had no idea they were so flexible.
Didn't see the T-Rex woodies. Are they better / as good as / worse than the Like90 blades?
Thanks again
Old Nov 08, 2004, 12:35 AM
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Saw some of the woodies today for the rex. I really liked them but not read much about the flying qualities yet.
Fred Bronk is offline Find More Posts by Fred Bronk
Carbon Align T-rex blades on Shogun luis104 Mini Helis 14 Dec 06, 2005 02:07 AM
Help! T-Rex blades on Zoom/Shogun helibore Mini Helis 4 May 02, 2005 08:45 AM
Question T-rex canopy on shogun zipphreak Mini Helis 2 Mar 28, 2005 10:19 AM
T-rex Blades on a Shogun - I did HoverDown3K Mini Helis 15 Feb 11, 2005 11:26 PM
t-rex blades on a Dragonfly gmaz7 Mini Helis 2 Feb 11, 2005 10:08 PM
