Old Apr 13, 2013, 01:41 PM
Pass1's Avatar
Saudi Arabia, Makkah Province, Thuwal
Joined Aug 2012
EZOSD not working... what could be wrong?
Hey guys,
I just got the EzOSD, after trying it and getting it to work, it seemed to have stopped wanting to do anything. I haven't even had one flight with it
Something strange happens... when I connect the battery the FC (Naza) turns on but the ezosd and the 5.8 GHz transmitter don't have any signs of life (no leds).
Does anyone have any suggestions?
Thanks!
Pass1 is offline Find More Posts by Pass1
Old Apr 13, 2013, 03:12 PM
The Netherlands, ZH, Gouda
Joined Jun 2011
Check the current sensor of the EzOSD. I think there is a fuseable printline broken. Happened to me also ( had ground problem). The circuit is getting his power from the current sensor pads and from there a tiny printline is going to the rest of the circuit. This one is broken.
You can measure this with Multi meter (resistance). If this one is broken (acting as fuse) you can simple solder small wire over this print line. It will work as new.
jacq1954 is offline Find More Posts by jacq1954
Old Apr 14, 2013, 02:24 AM
Pass1's Avatar
Joined Aug 2012
Hi jacq1954!
Thanks for the info, I actually found the problem... I connected the battery and ESC on the wrong sides... I am joining the idiot's club.
Just went for a quick flight and everything was
Discussion 3D printed rocket, what could go wrong? Indiana_Geoff Life, The Universe, and Politics 14 Mar 10, 2013 04:56 AM
Help! Recorder Could Not be Opened Rog318 Eagle Tree Systems 6 Mar 05, 2013 11:10 PM
what could be wrong? buster7467 Micro Helis 7 Apr 20, 2004 03:27 PM
What could be wrong old p47 Power Systems 8 Aug 09, 2003 02:20 AM
What could be wrong with my ESC? kushal_22 Power Systems 8 Nov 29, 2002 01:08 AM
