Old Oct 08, 2012, 02:22 PM
United Kingdom, England, Leominster
Joined Dec 2011
flying at dusk...why the lift?
For my last video I flew the radian a couple of times at sundown..So why did I get good lift and a long flight. It had been sunny ish in the day but the sun was going down and temp dropping. I thought lift and thermals were stronger midday? dumb question no1
dumb question 2
I did several flight and the one with the gopro on seemed longer and more bouyant than with the camera off???
mmm sorry if it's really obvious.
alex
alexsally is offline Find More Posts by alexsally
Old Oct 08, 2012, 11:01 PM
United States, CA, Lemoore
Joined Nov 2008
Evening air is often described as being "buoyant", not sure if I've ever come across an actual scientific explanation to the phenomenon. You could look in the soaring or dlg section.
Svede is offline Find More Posts by Svede
Latest blog entry: Sea Bull maidened
Old Oct 09, 2012, 12:03 PM
United States, MD, Salisbury
Joined Jul 2011
I would bet it was increased 'density'. As a kitesurfer, in mid-summer I wish for the Fall when the air is cooler, more dense ..and more powerful for a given wind speed. I would guess in your area, it cools quickly when the Sun gets low in the sky.
Svede is probably correct; the Glider guys would know. Cheers.
Jim
wetstuff is offline Find More Posts by wetstuff
Old Oct 09, 2012, 01:33 PM
Joined Dec 2011
Thanks guys. I got a lot to learn on this glider stuff :-)
Maybe I should hang about the glider forum :-)
Alex
Old Oct 09, 2012, 01:54 PM
Near Austin
Joined Dec 2001
You pretty much described what the situation was that helps create lift.
It was a sunny day, so the ground heated up pretty good and holds heat for a while.
Sun went down and the ambient air became cooler and denser.
The ground still being warm heats the air near the surface and causes a thermal.
The more difference there is in temperature (ground vs. air) the more the effect is.
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Oct 10, 2012, 07:13 AM
I fly with my little eye
Swanlander's Avatar
Lancashire, England
Joined Jul 2005
I have experienced a similar phenomenon; when evening flying at our flat field site in settled weather we would often encounter a 15 to 20 minute period of sustained lift.
This was, we understand, generated by the change in local wind as the evening coastal breeze picks up, pushing cold (heavy) air inland and lifting the warm (lighter) air above it as it moves. A bit like a moving slope.
The camera weight issue might be associated with this. If the airspeed is optimised for minimum sink (no ballast) you drift downwind. Pushing forward on the elevator to maintain station will reduce the efficiency. If the camera is fitted, assuming no dramatic increase in Cd, you may be flying in the max range band. (longest glide) Which is why sailplanes carry water ballast for upwind legs of cross country flights.
Not sure if this is 100% correct, but as you say, loads to learn; surf the web, explore the soaring knowledge base and put me right.
Swanlander is offline Find More Posts by Swanlander
Video Flying at dusk shorty_ger Electric Plane Talk 3 Aug 29, 2010 01:35 PM
Video CX2 Flying at Dusk bullseye91020 Electric Heli Talk 1 Jul 28, 2008 11:27 PM
Discussion snow flying at dusk tic High Performance 10 Dec 29, 2005 02:31 PM
