Old Sep 19, 2003, 01:54 PM
Joined Sep 2003
Tantrum with B20 15L 4:1 ?
I have Hacker B20 15L+G motor.
If I setup Tantrum with B20 15L+G motor,
Is Good ?
How much is it power.
very very powerful ?
How think about my plane.
Lee Huyng zoo is offline Find More Posts by Lee Huyng zoo
Old Sep 19, 2003, 02:46 PM
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
That is a little more motor than you need, but it will fly very very well. You'll have ton's of power and will rarely need full throttle(assuming correct prop choice). What kind of battery pack do you have in mind?
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Sep 19, 2003, 06:20 PM
Joined Sep 2003
Thank you , Jim
Replay my Threads.
Because I have only B20 L15L+g motor.
I have now e-tech 2S 1200, castle 25A
Is that enough for unlimited Vetical Climb.
If that is not, What kind of battery will good ?
Old Sep 19, 2003, 06:26 PM
Joined Aug 2000
I'd go with at least 2S2P on the ET-1200's, or 2S or 3S TP2100's. I'd think that 2S might be too little voltage. Perhaps someone who has actually tried out 2S will chime in.
-Jim
Old Sep 19, 2003, 06:40 PM
Joined Sep 2003
Excuse me.
Can I Vetical climb with B20 L15+G , 2s(7.4v) E-t 1200 .
Old Sep 19, 2003, 08:49 PM
Lurker
Longmont, Colorado
Joined Nov 2000
Lee,
Yes you can but your batteries will not last long. Your motor will draw too many amps from that battery configuration.
If you have E-Tec you need at least a 2S2P or 3S2P to run that motor. If you are using the Thunder Power a 2S1P will be ok. I also assume that the new 20c kokams would also work.
KonstantKrash is offline Find More Posts by KonstantKrash
Old Sep 19, 2003, 08:56 PM
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
You can probably make a 2 cell etec 1200 pack go vertical with that motor, but you definetly wont be using the motor to its full potential. The etecs max currnet is much lower that the hackers max current. I would start with a 10x5 apc and see if the batterys get really warm.
You can use this program to test differnt set ups. http://brantuas.com/ezcalc/dma.asp
Its probably not perfetly accurate, but it will give you a place to start.
fwilly is offline Find More Posts by fwilly
Old Sep 19, 2003, 09:07 PM
boaman's Avatar
Joined Nov 2002
go to mountain models watch video you will love it
boaman is offline Find More Posts by boaman
Old Sep 20, 2003, 02:45 AM
Joined Sep 2003
Thank you !!!
everyone who reply my threads .
your relpy is very very helpful for me.
Be happy...... Thank you !
Hacker B20 15L 4:1 with maxon planetary gearbox for $50!!!!! Shortman Aircraft - Electric - Airplanes (FS/W) 4 Jun 20, 2004 06:10 AM
B20 15L 4:1 with CC 25 for sale/trade Dan Halverson Aircraft - Fuel - Airplanes (FS/W) 4 Oct 28, 2003 08:37 PM
what prop for miniflash with b20 15l 4:1 & TP21003s pack RCZohn Power Systems 3 Sep 21, 2003 10:13 PM
FS: Hacker B20 15L 4:1 with Hacker 30 amp esc Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 3 Sep 08, 2003 09:33 PM
How about a product review of the HACKER B20-15L +4:1 Gear Box! JonB Electric Plane Talk 1 Nov 19, 2001 09:36 PM
