Old Jan 07, 2011, 08:57 AM
Joined Jan 2011
Set of New control boards soon available on e-bay and rov-asia.com
In the next week there will be a new set of control boards available. I will be looking forward to any questions you might have
Transmitter, Receiver, Light Control and Power Board with leak sensor and Alarm Circuit and two 3 Watt LEDs
Description: Name: AluminiumBase3D.jpg
Description: Name: Connection_DiagramRealBoard.jpg
Description:
This set of electronic boards includes a topside transmitter PCB, bottom side receiver PCB, light control PCB, Power distribution board for the ROV, leak sensor PCB, PVC base, Two 3 watt LED lights and topside piezo elictric sound module for giving indication of a water leak inside the ROV.
Description:
Transmitter PCB
Description:
The top side transmitter PCB is measures 45.7 mm x 89mm and is powered by 12 Volt DC 500 mA. It can control
1. 4 Thrusters. Two aft, one lateral and one vertical. Can control both DC brushless and DC brushed motors with external circuit upto 1KW motors.
2. Two servo units for Pan and Tilt functions for
camera viewing angle control.
4. Light dimmer control.
3. Leak alarm.
The inputs of the transmitter board are connected with a 10 K Ohm potentiometer or a joystick.
Receiver PCB
Description:
The receiver PCB is 33.0 mm x 35.5 mm and receives information from the transmitter PCB and then outputs a signal into R/C PWM format to control the following.
1. Four ESC units (not supplied) that are used to control
DC brushless motors.
2. Light dimmer control board used either for control of
LEDs or 2 x 12 Volt halogen 75W bulbs.
3. Two Servo units (not supplied) which control pan and tilt
unit for the control of the viewing angle of camera.
4. Leak sensor board.
The receiver only provides the PWM signal and not the power for these external Functions. The sevo functions for pan and tilt are the only two functions that can take power from the receiver.
Light Control PCB
Description:
The light control board PCB is 33.0 mm x 35.5 mm receives the PWM signal from the receiver board and can either control LEDs or two 75 Watts halogen bulbs. The light control board also has a fuse to protect the circuit.
Leak Sensor Board
Description:
The leak sensor board is a very simple board that detects a leak of water into the ROV an protects the receiver board.
The Power Disruibution and Fuse PCB
Description:
The Power distribution board distributes 12Volts DC to all the functions of the ROV and protects boards with a SMD fuse. Depending on the ESC controllers, lights used and servos used use will depent on the value of these fuses.
rovasia is offline Find More Posts by rovasia
Old Jan 07, 2011, 08:22 PM
Joined Jan 2011
Now the cost of the boards have been worked out.
Included in the ROV Board set is a full manual so you can easly set up your ROV whether this is a hobby ROV or proffesional one these boards can do both. The boards can transmit data to an ROV up to 1,800 mtrs.
The Set includes,
1. Full set of manuals.
2. Boards that are already settup to provide full functions for thrusters,board for two sets of lights, two servo outputs for Pan and tilt, Leak Sensor. Also documentation is provided to show the circuit of how to integrate joystick correctly.
3. One Transmitter board.
4. One Receiver board.
5. One Light controller board capable of powering two 50 Watt Halogen lights or two High power LED arrays.
6. Two Leak sensors.
7. Trim Pot circuit boards for settup of Pan and tilt.
8. Power control board.
The Price of the full set will be US$ 150.00 plus US$ 10.00 for shipping.
For People that have alread got the boards
Transmitter board - US$ 65.00
Receiver Board with Power board including base - US$ 75.00
Light controller board - US$ 45.00
Leak sensor board FREE.
Receiver board, Power board, Light controller board and Leak sensor board - US$ 100
Any Questions Please do not hesitate to ask,
Take care.
Old Jan 08, 2011, 04:44 AM
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Looks good and at that price it's a good way to go rather than trying to DIY control boards so this may help bring people into the hobby that otherwise maybe put off by electronics.
Question on the thruster control, is the control signal to the esc standard rc PWM? and can it control reversible brushless esc like those used in rc cars to give forward/reverse operation of thruster?
Rob
robe_uk is offline Find More Posts by robe_uk
Old Jan 08, 2011, 05:19 AM
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
What is required for the control input to the transmitter board, and what is required for the tether cable.
cheers
Nick
nick_75au is online now Find More Posts by nick_75au
Old Jan 08, 2011, 06:27 AM
Joined Jan 2011
Answers to your questions
The boards uses RC PWM and can control both DC brushed and DC brushless with ESC controller or alternative controller. All you need to settup is the full forward/ full reverse and centre point of the controller. I have alread used them in the c-cat ROV controlling 1 KW thrusters. They also have a rotate function that automaticaly does the turn port and starboard (left/right) smoothly using op-am circuitry.
The transmitter can either be potentiometers or a 12V input joystick as used with commercial ROV's with center point adjustments and can easily be bought in RS. The joystick can have also the forward/rev, lateral left and right and also the turn left/right, two other pot will be needed for the lights and depth. Also required would be a joystick for the Pan and tilt for the cammera.
Old Jan 08, 2011, 06:32 AM
Joined Jan 2011
The tether is upto you what you want. If you look at my site which is being updated now will also have a proffesional ROV both built and in Kit parts for Hobbiests and proffesionals alike. This can be used in the private sector or for industry at half the cost of other ROV/s available.
My site is rov-asia.com
Old Jan 08, 2011, 03:10 PM
R.O.V. Man
hargard's Avatar
Devon UK
Joined Jan 2006
Hi
I have the Mk1 type of board from this company and they work very well.
I cannot fault the boards.
A question .. Can I use one of these receiver boards with my existing transmitter board.??
Regards Antony(UK)
hargard is offline Find More Posts by hargard
Old Jan 08, 2011, 04:02 PM
Joined Dec 2006
Hi, what tether is avaliable and what prices you have?
regards,
joe
joco000 is offline Find More Posts by joco000
Old Jan 09, 2011, 04:29 AM
Joined Jan 2011
Here are the links to youtube to show the boards in action,
ROV Receiver board setup -
ROV Receiver board settup from rov-asia.com (1 min 53 sec)
Communication system for ROV -
Communication system for ROV from rov-asia.com (1 min 45 sec)
ESC Setup using control boards -
ESC settup of ROV boards from rov-asia.com (2 min 39 sec)
ROV Motor demo -
ROV Motor demo from rov-asia.com (1 min 48 sec)
ROV potentiometer example -
ROV potentiometer example using control boards from rov-asia.com (0 min 54 sec)
ROV Light Board -
LightBoard from rov-asia.com (0 min 36 sec)
ROV Light controller example -
Light example for the rov-asia control boards (1 min 12 sec)
ROV Leak board settup -
leak (1 min 11 sec)
Any questions please ask,
Gordon.
Old Jan 09, 2011, 06:58 AM
Joined Jan 2011
available tethers
Joe,
I will speak to you about two 130 - 140 mtr proffesional umbilical cables that are available from the philipines the are about US$700 not including shipping. Also I will give a direct e-mail on this as I do not want percent,
Take care,
Gordon.
Old Jan 09, 2011, 02:25 PM
Joined Nov 2005
Gordon,
These look great. Thanks for sharing them, and I look forward to seeing them in use. Excellent control option - and great price, too.
Nate
N8fromVA is offline Find More Posts by N8fromVA
Old Jan 10, 2011, 02:00 AM
Joined Jan 2011
The New ROV Boards are now for sale on E-bay.
The ROV boards are now for sale on E-Bay item number 300513671349
Take care,
Gordon.
Old Jan 10, 2011, 12:57 PM
Joined Jan 2011
Take care,
Gordon.
Hi,
Is included in the ROV controller and the schematic and source code? I would like to add your own sensors. e.g. Compass.
Greetings Holger
holgi03 is offline Find More Posts by holgi03
Old Jan 10, 2011, 01:31 PM
Joined Jan 2011
Question about compass
These boards do not have this function. However if you wish this function why do you not use another twister pair and you can by two Atmega chips and have all the functions you wish. These boards are proven and have over 3,000 hrs without breakdown on a professional rov system with a depth rating of 500 mtrs.
Old Jan 10, 2011, 04:28 PM
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Regards Antony(UK)
Think Gordon missed your question Antony.
Also on the back of Holger's question do you have any plans to add the function of sending external data from the rov to the surface via your board, and also what about auto-depth control?
New Product New ROV control System Available shortly on E-bay and rov-asia.com rovasia Robotics 0 Jan 07, 2011 08:18 AM
New Product New awsome pdf plans available soon! tomtom4867 Foamies (Scratchbuilt) 0 Dec 17, 2010 02:37 PM
Discussion New! Bantam Charger Parallel Balancing boards now available RC Accessory Batteries and Chargers 3 Oct 22, 2010 07:05 PM
Off Site Radical RC Das mini-bipe for sale on e-bay fly2mike Aircraft - Electric - Airplanes (FS/W) 11 Oct 12, 2010 12:23 AM
Sold Kontronik motor 600-17 set for Logo 10, 16 or Eco 8/16 on E-bay litespeed Aircraft - Electric - Helis (FS/W) 0 Mar 12, 2006 07:56 AM
