Old Mar 17, 2015, 11:30 AM
webbeing is offline
Find More Posts by webbeing
Joined Mar 2015
1 or 2 esc for dual fans set up?
Hello,
To insure same RPM in a dual fans config, do I need to use 1 ESC (assume it supports the load) in a twin fans set-up?
Also, do I need counter rotating fans too?
A great many thanks!
webbeing is offline Find More Posts by webbeing
Old Mar 17, 2015, 12:13 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
2 ESC's
Chris True is offline Find More Posts by Chris True
Old Mar 17, 2015, 06:31 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
If you run both ESCs with the same settings and have one battery, you should have the same performance.
Generally you will not notice any benefit from counter rotating fans unless you are building a 3D flier and plan on hovering in one place.
4stripes is offline Find More Posts by 4stripes
Old Mar 18, 2015, 07:04 AM
Boogie_ is offline
Find More Posts by Boogie_
Da' Cajun
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
What type of airframe?
Boogie_ is offline Find More Posts by Boogie_
Old Mar 18, 2015, 10:59 AM
webbeing is offline
Joined Mar 2015
It's an F15 foamie. Thanks,
Old Mar 19, 2015, 07:25 AM
Boogie_ is offline
Da' Cajun
Boogie_'s Avatar
Joined Jun 2009
Originally Posted by webbeing View Post
Hello,
No need to have the fans running the same rpm. Especially on a twin jet like an F-15.
You would never notice any ill flight characteristics even if the rpm imbalance was upwards of 1000 rpm (or more).
Counter rotating fans are not needed.
Old Mar 19, 2015, 10:50 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
I will add, using 1 brushless ESC with 2 motors will at best not work, at worst it will fry something.
If the motors get even slightly out of sync (and unless they are on the same shaft they will) the ESC will not have a clue what is going on.
desertstalker is offline Find More Posts by desertstalker
Old Mar 20, 2015, 06:57 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
I have built and flown at least eight (8) twin EDF planes, all powered by 70 mm fans, twin ESC's and a single battery. The total number of flights put on these planes has to be well over a thousand.
All of the ESC's were of the el cheapo, no name brand type, but always purchased in sets of two. That way, hopefully, they were as similar as possible. Both fans ran in the same direction.
The power systems worked well with no problems. The speed controls used a "Y" wire to the receiver and each had a choke coil. No modifications were made to the wiring.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Found 1/8 Tekin or castle motor/esc set up Independentjrc Cars - Trucks and Parts (FS/W) 1 Apr 23, 2014 06:54 AM
For Sale LX A-10 Power set up; Fans, motors, ESC, BEC Lancr735 Aircraft - Electric - Power Systems (FS/W) 1 Jan 11, 2014 04:55 PM
Sold Taft Hobby 11 Blade 8s plug and play set-up Motor/fan/esc taildragger21 Aircraft - Electric - Jets (FS/W) 0 Dec 17, 2013 10:15 PM
Help! BL and esc set up for 1 or 2 cell dougmontgomery Scratchbuilt Indoor and Micro Models 0 Feb 27, 2010 08:20 PM
Dual ESC Set-up for Micro-heli blu-thang Micro Helis 6 Sep 09, 2005 08:44 PM
