Old Oct 16, 2014, 11:29 AM
Jamesnns is offline
Find More Posts by Jamesnns
Joined Oct 2014
JXD 3981, need motor replacement.
I bought the JXD 391 Space Trek Galaxy 391 4.5CH 2.4GHz RTF RC Quadcopter
and in less then 1 hour flight time one motor has broken. I would like to buy replacements.
Looking at the motor, its stamped ?? N50-3124, then what appears to be a date underneath that. I cannot make out the first two numbers/letters (indicated by (??) or the date. The last two digits of the date appear to be 14
Any help acquiring these motors would be helpful as Ive search here and the Web to no avail for over an hour or so.
Thanks.
James
Jamesnns is offline Find More Posts by Jamesnns
Old Oct 16, 2014, 12:20 PM
SeByDocKy is online now
Find More Posts by SeByDocKy
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Thanks.
James
Some WLtoys V262 should be a good candidate for replacement. They are also N50
SeByDocKy is online now Find More Posts by SeByDocKy
Old Oct 17, 2014, 08:23 AM
Jamesnns is offline
Joined Oct 2014
I saw those. It looks like the gear on the spindle is too high...the one I have the gear is fairly flush with the motor itself.
Ill try contacting WL toys.
Image here
http://www.jamesnevins.com/4b70b290.jpg
Old Oct 17, 2014, 09:45 AM
Jamesnns is offline
Joined Oct 2014
Does anybody know of the gear on the spindle on the motor is adjustable in height?
If so, I could buy 4 of them and rteplace them all. Im prob sure that the rpms are going to be different
Old Oct 25, 2014, 12:10 PM
Jamesnns is offline
Joined Oct 2014
I got the N50 motors....all seemed well until flight. It wouldnt lift.
Upon closer inspection the gear on the old motor has 7 sprockets, the new n50 (v262) motor has 9.
Now I have a stripped gear as well...with no parts anywhere to be found.
In the garbage it goes.
Discussion Quick help needed; JXD-392 /388 any problems? LittleFish Mini Multirotors 4 Oct 27, 2014 11:27 PM
Wanted i need a replacement motor for st360 hk quad copter heli46 Aircraft - Electric - Multirotor (FS/W) 3 Sep 16, 2014 10:26 PM
Help! Need a replacement motor Bubblehead21 Power Systems 3 Jan 05, 2014 07:55 PM
Question Alternative replacement blades for my JXD 340? BliND123 Coaxial Helicopters 0 Jun 29, 2011 07:17 PM
Discussion tail rotor replacement on JXD wagonracer Coaxial Helicopters 0 Dec 02, 2010 06:12 PM
