Old Apr 18, 2014, 04:04 PM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Jeff
The advantage of twins is that that ducting gets pretty easy (splitters are harder.) I suspect that you'll have enough room in between the ducts for batteries- having done a small Arrow single (and I keep toying with the airplane as a twin...)
Size the airplane to the fans- not the other way around! The challenge with twins is that often the fans that you think should work in the airplane- well, they're too big for the ductwork. I'd recommend staying with 70 mm fans- there are plenty of them, lots of power systems, and a bit less expensive than the 90s.
If you haven't done an EDF before, I recommend getting your feet wet with something less complex than a twin. Balancing and assembling the fan can be something of a knack.
And yes, there's some theory on fan placement- check the Wemotec site. Pretty sure that ideal exhaust length is between 2.5-3x fan diameter but I could be wrong.
Don't get hung up on static thrust- a lot of the inlets we use don't work real well at delivering max static thrust but do fine once the airplane is in the air. Check Ken Williams thread on his F-100.
HTH
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old Apr 19, 2014, 02:03 PM
Kambalunga is offline
Find More Posts by Kambalunga
Kambalunga's Avatar
Deutschland, Hessen, LA
Joined Jan 2009
An Excel sheet for delta COG calculation.
Kambalunga is offline Find More Posts by Kambalunga
Old Apr 22, 2014, 10:06 AM
killickb is offline
Find More Posts by killickb
killickb
killickb's Avatar
The Villages. Florida
Joined Jan 2005
Here is my 106, you can see the line marking my cg just in front of the wheelwell. I have good pitch control at this position.
Not sure where it is with respect to the MAC but the wing is 22 inches long from where the leading edge meets the inlet and the cg is 7.5 inches from that leading edge point. Maybe you can interpolate that to fit your model.
killickb is offline Find More Posts by killickb
Old Apr 24, 2014, 02:10 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Have you flown your -106, yet?
DanSavage is offline Find More Posts by DanSavage
Discussion Flaps on Delta wing Teddy Ong Electric Plane Talk 2 Jan 05, 2013 08:49 AM
Discussion The best way to find the CG and sweep angle of a Delta wing RTF Thumper Foamies (Scratchbuilt) 3 Dec 01, 2011 09:05 AM
Discussion how do i find cg on a delta punkrockd Flying Wings 15 Oct 11, 2006 02:23 PM
how to find CG on a flying wing? EKI16 Parkflyers 8 Jan 02, 2004 05:10 PM
How to estimate CG on a Delta wing leftysdeceiver Electric Plane Talk 4 Oct 07, 2001 08:10 AM
