Old Nov 22, 2012, 08:25 PM
sandydr is offline
Find More Posts by sandydr
Need a bigger runway
sandydr's Avatar
Dominican Republic, Puerto Plata, Cabarete
Joined Mar 2008
Great Planes Ultimate Bipe 40
Hi Guys
Doing my first kit build with this plane. I purchased it about 4 years ago and it has just sat there doing nothing as it looked quite complicated. Have also realized that doing kit builds is actually more expensive (unless you have all the tools) than doing an ARF. Have nearly finished the build, with the exception of opening the cowl for the motor and covering the plane. I will be flying this off floats. I am confused as to which way to go with the engine. I have a Magnum xl52 (2T), Magnum xl70(4T) and a NGH 9cc (gas). Which one should I go with to ensure I get it off the water and get some oomph from it?
Thanks, Sandy
sandydr is offline Find More Posts by sandydr
Old Nov 22, 2012, 10:04 PM
cherokeenut is offline
Find More Posts by cherokeenut
United States, CO, Dacono
Joined Nov 2010
Go with the Magnum 70 and a 12-6 prop.
cherokeenut is offline Find More Posts by cherokeenut
Old Nov 23, 2012, 01:45 PM
sandydr is offline
sandydr's Avatar
Joined Mar 2008
Thanks for the input. Any particular reason why? This is my first 4-stroke and it does sound a lot nicer, however I can't find any power / RPM's for either motor.
Regards, Sandy
Old Nov 23, 2012, 02:22 PM
Joined Nov 2010
Well my personal thing is that I just think a two stroke (or worse a motor) on a bipe is just wrong, but besides that a good 4 stroke will pull it hard without over working and it will run about 1/3 less in expensive nitro fuel.
Old Nov 23, 2012, 02:44 PM
sandydr is offline
sandydr's Avatar
Joined Mar 2008
Thanks Cherokee, I had no idea that the 4 stroke used that much less fuel. With nitro locally costing about $US50 per gallon, it is a good motivation. Will go with that option. Regards, Sandy
Old Nov 23, 2012, 09:55 PM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
Wow I thought I had it bad at $25 a gallon. Lots of guys pay $10-$15 dollars a gallon normal price.
Kyler1 is offline Find More Posts by Kyler1
Old Nov 23, 2012, 10:07 PM
EscapeFlyer is offline
Find More Posts by EscapeFlyer
CPA# 39
EscapeFlyer's Avatar
United States, MN, Brooklyn Center
Joined May 2009
+1
Brian
EscapeFlyer is offline Find More Posts by EscapeFlyer
Old Nov 23, 2012, 11:04 PM
sandydr is offline
sandydr's Avatar
Joined Mar 2008
I currently live in the Dominican Republic, only 1 hobby shop on the island.... So the only options is sea-freight (45 day lead time) or the hobby shop. Being from England and hating having cold feet, I can balance up the cost of thermal underwear against the additional cost of buying nitro....
Sold Great Planes Ultimate Bipe w/ 3.2 First Place Engine clandestoy Aircraft - Fuel - Airplanes (FS/W) 0 Oct 22, 2012 01:47 PM
Sold Great Planes Ultimate Bipe w/ 3.2 First Place Engine clandestoy Aircraft - Fuel - Airplanes (FS/W) 0 Jul 23, 2012 09:13 PM
Discussion Best engine for great planes ultimate bipe 40 barkleyarff Engines 1 Feb 09, 2008 01:14 PM
Great Planes Ultimate Bipe-40 diver don Sport Planes 19 Jun 15, 2005 02:33 PM
Advice for Great planes Ultimate Bipe .40 size Ogre Power Systems 1 May 16, 2005 11:10 PM
