Old Aug 14, 2012, 12:09 PM
danford1 is offline
Find More Posts by danford1
Innovator
danford1's Avatar
United States, MI, White Lake
Joined May 2011
Let's list the slowest of the slow flyers.
I'm interested in building the slowest slow flyer I can out of foam (Depron, EPP, Dollar Tree, FFF etc).
I've already built a Nuttball, Drenalyn, Scorpio, Smart Dart, full size Carpricorn and a mini Capricorn plus a couple home made concoctions. I also have an Ember 2.
The slowest of the above list is the Drenalyn and Ember 2. My full size Capricorn flies slow too but is too big for my yard.
I should define slow flyer. I AM NOT looking for a tri-rotor, quad rotor, heli, or pure hover machine. I want a slow flying plane I can fly around my yard with no or little wind. The Ember 2 is a bit small. I want something that is a proven design, is very light and flies Slooowww. High Alpha is OK as long as it can turn quick to avoid trees and things. I have to fly low as there are tree branches all over.
For motors I have a 5g, 10g, 24g and up to a Turnigy 3530. I have batteries from 1s 70 mah to 3S 2200. With just about everything in between :-)
I know bigger planes can be slower. So for this thread let's put a size cap on at 36". That leaves up from say 6" to 36" a huge range for this task.
To add another rule, if you recommend a plane for the list, do it because you own it, built it or flew it. I don't really care about "I saw this guy fly a plane his cousin had that he borrowed from a neighbor. It was the slowest thing I ever saw" . That won't work here.
Proven designs that you have experience with only.
This could be fun.
Start listing planes and links to the builds if you can.
Danford1
danford1 is offline Find More Posts by danford1
Old Aug 14, 2012, 02:23 PM
klausi0 is offline
Find More Posts by klausi0
klausi0's Avatar
Germany
Joined Dec 2009
This was my slowest slowflyer. The wing construction is from Christians slowly (thread: http://www.rcgroups.com/forums/showthread.php?t=1686460 ) but the wing is made of 1,5mm depron. The fuselage is a triangle made of 3mm depron.
Very Slowly Teil 3 (3 min 16 sec)
Motor 5g turnigy
Lipo 2s 350mAh
Klaus
klausi0 is offline Find More Posts by klausi0
Old Aug 14, 2012, 02:53 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
Nightstone just made a real nice delta that is very stable flying high alpha with a KFm1 airfoil .
.http://www.rcgroups.com/forums/showt...4#post22424564
balsa or carbon is offline Find More Posts by balsa or carbon
Old Aug 14, 2012, 04:11 PM
vinnieg is offline
Find More Posts by vinnieg
vinnieg's Avatar
United States, NJ, Edgewater
Joined Feb 2012
the BYOB is very slow. I've made 2 of them so far. Keep the AUW around 110 grams use a 5x3 prop on a 2S. It flies at walking pace and floats well too.
http://www.rcgroups.com/forums/showthread.php?t=1046798
vinnieg is offline Find More Posts by vinnieg
Old Aug 14, 2012, 06:39 PM
Dave Barrow is offline
Find More Posts by Dave Barrow
Dave Barrow's Avatar
United States, KY, Covington
Joined Feb 2003
Gene Bond's 4S Bipe is a good slow and or aerobatic/3D flyer. I've had a lot of fun with mine (23" WS). Very maneuverable with those big Ailerons, Elevator and Rudder. The 23" and also 30" plans thread here:
http://www.rcgroups.com/forums/showthread.php?t=452577
For a very simple build Gens's BluStick was a hoot. 23"WS with conventional or V tail. GWS IPS DX-A and 7 x 300 NiMh's. I still have it. Would be a real floater made with 3mm Depron tail surfaces and brushless/ lipo. Hmmm.....need to update mine.
http://www.rcgroups.com/forums/showthread.php?t=33760
Dave Barrow is offline Find More Posts by Dave Barrow
Old Aug 14, 2012, 09:11 PM
Jack the R is offline
Find More Posts by Jack the R
Jack the R's Avatar
Joined Aug 2009
I'm going to go out on a limb and suggest what you need is not necessarily the slowest slow flyer but an EPP 3D plane, able to change directions on a dime and bounce like a ball if you screw up. They also hover, so technically they are the slowest of the slow too.
RAcores 6mm Leadfeather Yak might be just what you're looking for - Link. I fly a heavier 9mm Yak under trees for fun. Since they can hover they are also infinitely slow, but the great thing is the manueverability. You can get out of almost anything with a Leadfeather Yak.
Some smaller planes that I haven't flown - Fancy Foam's mini and micro MX2, Phoenix, Skycart, Fire Fly, Flip flop; the Mini Breeze Pro, The Tech One Mini Piaget or Mini Yak. The Sumo 3D would also be a good choice.
Jack the R is offline Find More Posts by Jack the R
tonytiger20 is offline
Find More Posts by tonytiger20
tonytiger20's Avatar
USA, MS, Picayune
Joined Jan 2011
I know it is not a scratchbuilt but this would be my favorite slowflyer. The GWS Pico tigermoth. Enjoy
Pico Tiger Moth Front Yard Flying (3 min 36 sec)
tonytiger20 is offline Find More Posts by tonytiger20
Old Aug 14, 2012, 09:33 PM
john-doe is offline
Find More Posts by john-doe
quad lover
United States, MI, Ann Arbor
Joined May 2009
Yes the BYOB is slow, and that was with the small one. There are also plans for a 32" version of the BYOB right with the original, and if using something like 2mm depron, and everything else as light as possible, then it would probably one of the slowist out there, given it's huge wing area and low weight, and of course, lots of drag from the undercamber.
john-doe is offline Find More Posts by john-doe
Old Aug 14, 2012, 11:30 PM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
My slowest plane at the moment is The Slowly, it's made from 6mm EPP with a 1.00m / 40" wingspan.
Andy
Slowly (2 min 28 sec)
Thread http://www.rcgroups.com/forums/showthread.php?t=1686460
Aero Andy is offline Find More Posts by Aero Andy
Old Aug 15, 2012, 10:14 AM
danford1 is offline
Innovator
danford1's Avatar
Joined May 2011
Thank you very much for the recommendations.
The funny thing is i printed out the tiled version of the BYOB a long time ago. It is near my building board in a pile of other planes. Sounds like I should build it and fly it.
Thanks again.
Danford1
PS I also like the Tiger Moth and EPP YAK. I'll try the ultra cheap route and scratch build first. I have a lot of foam on hand ...
Old Aug 15, 2012, 11:17 AM
Wufnu is offline
Find More Posts by Wufnu
Pickin' an a Flyin'
Wufnu's Avatar
United States, TN, Knoxville
Joined Apr 2004
A really slow flyer is the Sig Antoinette. Martin Hunter made a great one, slowest I've seen, 8 years ago.
Build thread:
http://www.rcgroups.com/forums/showt...ight=antoinett
Video:
http://gvillette.rchomepage.com/antoinette.wmv
Wufnu is offline Find More Posts by Wufnu
Old Aug 15, 2012, 10:57 PM
danford1 is offline
Innovator
danford1's Avatar
Joined May 2011
Wow. I like it. I watched the video and read some of the thread.
I didn't read it all though. Do you know if someone has made one out of foam?
The stock one is Way to fragile for my yard flying...
Danford1
Old Aug 15, 2012, 11:42 PM
Wufnu is offline
Pickin' an a Flyin'
Wufnu's Avatar
Joined Apr 2004
Don't know but I haven't seen any. Don't see why you couldn't do it from scratch. The fuse/wings are pretty simple!
Old Aug 16, 2012, 12:50 AM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
Here's one of my favorite slow scratchbuilt EPS parkflyers.
Able to fly at a fast walk and in a decent amount of wind!
http://video.google.com/videoplay?do...13700398&hl=en
Butch777 is offline Find More Posts by Butch777
Old Aug 16, 2012, 02:35 AM
SpaceDrydock-22 is offline
Find More Posts by SpaceDrydock-22
"Use the foam, Luke!"
SpaceDrydock-22's Avatar
Finland, Kuopio
Joined Aug 2010
This is very slow.
http://www.rcmovie.de/video/de81c7e3...-Woche-spaeter
Bauplan Slowly V2 A0
SpaceDrydock-22 is offline Find More Posts by SpaceDrydock-22
Discussion Let's get APC to make a 13x4.7 slow flyer pusher! Mactadpole Multirotor Talk 6 Apr 24, 2012 09:55 PM
Sold Crashed E-flite S.E.5a Slow Flyer 250 $40 shipped haines74 Aircraft - Electric - Airplanes (FS/W) 2 Mar 30, 2012 12:46 AM
Sold e-fLITE S.E.5a Slow Flyer 250 ARF vcaruso Aircraft - Electric - Airplanes (FS/W) 2 Feb 25, 2012 08:32 AM
Discussion Slowest Slow Flyer? Anyone surpassed the Gym-E? Tram Parkflyers 5 Sep 15, 2006 08:03 PM
slowest, cheapest slow flyer rcboy Parkflyers 40 May 15, 2006 08:29 PM
