Old Jun 05, 2012, 09:46 PM
Rogue.insight is offline
Find More Posts by Rogue.insight
Joined Jun 2012
RCTigerMotor MT3506 erroneous advertised data
I'm writing this to warn others, express my dissatisfaction, and publicize the poor laboratory practices of Rc Tiger Motor.
I had my eye on their MT3506 for a while because they published crazy awesome static lift efficiency. Here's the data they publish:
http://www.rctigermotor.com/uploadfi...0080440884.jpg
Look at the 13x4.5 prop section. For 730 g of thrust, they're saying it's getting 15.66 g/W! This is unbelievable! Well it's too good to be true as the old addage suggests.
I acquired a few of these for my own purposes. I put them on a thurst stand to see if I could duplicate these readings. The best I achieve was about 10-11 g/W at 500 g of thrust. This is quite a bit different, and actually sub par. I was disappointed. Curiously, they put another plot on their website from some other user on rcgroups. This plot itself disagrees with their tabular data, and agrees with my data! Either they're publishing false data in the table, or their measurements are wrong. After working in an engineering laboratory environment for about 12 years, the biggest lesson I've learned is, "always question the instrumentation." A colleague of mine has his own mantra, "all sensors suck." It turns out this is true in this case.
I corresponded with RC Tiger Motor to acquire the precise details of how they made their measurements. I found that it was identical to my thrust stand except they were using a DC power supply instead of a battery.
This is where the fault lies. My suspicion is they're using the voltage and current readout of the DC power supply to calculate power. This is poor laboratory practice. Doing so is not in any way an accurate measurement of power, which is required to calculate static thrust efficiency, g/W. I found that they are using a Mastech power supply. I have one of these myself, b/c the price is so low. On my unit, I've noticed first hand the garbage reported by the current readout. In one case I was actually pulling 6 amps and it read 0.3! If I were to use this readout to calculate power, I'd be completely wrong.
Lesson learned I suppose.
Rogue.insight is offline Find More Posts by Rogue.insight
Old Jun 06, 2012, 12:08 AM
BayAreaCrasher is online now
Find More Posts by BayAreaCrasher
BayAreaCrasher's Avatar
Joined Feb 2011
interesting data. any video of the tests that we can see to prove it out? cheers
BayAreaCrasher is online now Find More Posts by BayAreaCrasher
Old Jun 06, 2012, 12:21 AM
milo12 is offline
Find More Posts by milo12
Joined Feb 2011
I've always thought the volts in those tables looked odd. The motor is 2-4S so they should just use 2, 3 and 4S voltage. Hopefully they will listen to you and redo those tests.
milo12 is offline Find More Posts by milo12
Discussion BAD experience with RCTIGERMOTOR.COM zaguruinzasky Vendor Talk 7 Jan 16, 2013 04:47 PM
For Sale RCTigerMotors AUSTRALIAN Stock available NOW ! jetbootz Aircraft - Electric - Multirotor (FS/W) 5 Jun 20, 2012 08:09 AM
Discussion RCTIGERMOTOR experience? Connexxion Multirotor Talk 5 Mar 21, 2012 05:57 AM
Discussion study finds 33% of same day voter registrations erroneous D B Cooper Life, The Universe, and Politics 10 Jan 12, 2012 05:00 PM
Discussion T-Motors from rctigermotor.com ross_badger Hoverfly Technologies 9 Oct 31, 2011 04:50 AM
