Old Apr 05, 2012, 11:20 AM
amartolos is offline
Find More Posts by amartolos
Heli addicted.
amartolos's Avatar
Joined Jan 2012
airy servo spare gears
yes i ve fixed 3 stripped servos i had in 3 minutes..althought airy gears are different in size as you can see in photos , the fit is perfect in the plastic body
I dont know if airy gears are more durable than stock thought as helipal claims .
i ve also bought some servo gears from oomodel, so i ll compare both sets
Edit
Airy gear set gives a more tight feeling when you move the horn up and down >i would say the movement of the stock set is more smooth.
amartolos is offline Find More Posts by amartolos
Old Apr 05, 2012, 07:47 PM
Torch8 is offline
Find More Posts by Torch8
Torch8's Avatar
NYC
Joined Aug 2010
Throttle Curve and Wind
The FBL system in V120d02s flies very good in strong winds, but I like to make it handle gust better. So far heli being push down/up which is natural, using collective management. Thinking of tweaking throttle curve to make it stronger. Using stock motor. I don't fly 3D, just FFF, nose-in and circuits. Any recommended Idle-up throttle curve? Using wk-2801 Pro.
Normal = 0,40,70,90,100
Idleup1 = 100, 90,85,90,100
Idleup2 = 0 flat (this is my throttle hold use on right side)
Gryosens = 80%
Thinking of trying 100 Flat curve for idle-up, but won't that cut down my flight time and may be too much headspeed or harder to handle?
Torch8 is offline Find More Posts by Torch8
Old Apr 05, 2012, 07:56 PM
Slimshamis is offline
Find More Posts by Slimshamis
Slimshamis's Avatar
United States, IN, Merrillville
Joined Feb 2011
A brushless motor is more efficient when maxed out
Slimshamis is offline Find More Posts by Slimshamis
Old Apr 05, 2012, 07:58 PM
Slimshamis's Avatar
Joined Feb 2011
I use 100% across the board when windy 80% in normal weather
Old Apr 05, 2012, 08:05 PM
Torch8 is offline
Torch8's Avatar
NYC
Joined Aug 2010
Then I'm going to try 100% flat, my flying area are always windy.
Old Apr 05, 2012, 08:13 PM
Slimshamis's Avatar
Joined Feb 2011
Yeh my are is pretty windy also when I lift off I'm in normal and the heli is all over the place then I flip it to st1 which is 100% and the tail holds solid it's a night and day difference
Old Apr 05, 2012, 08:17 PM
Torch8 is offline
Torch8's Avatar
NYC
Joined Aug 2010
Same here, take-off in normal and immediately go idle-up. Fly and land in idle-up. Otherwise heli moving around too much. Can't wait to try 100% flat curve.
Old Apr 05, 2012, 09:24 PM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
The difference you have between flat and what you already have in ST1 will make no significant difference to your flight time. I also run 80% in ST1 and 100% in ST2 - there's not a huge difference in power but my PIT curves are -80% --- +80% and -100% --- +100% and that does make a difference. (I use TRADJ to limit the travel not PIT curve - It's down around 60% on my semi-S 120).
thwaitm is offline Find More Posts by thwaitm
Old Apr 05, 2012, 09:28 PM
BHChieftain is offline
Find More Posts by BHChieftain
Joined Apr 2010
Originally Posted by amartolos View Post
1st time inverted.
http://www.youtube.com/watch?v=WOEmk...ature=youtu.be
Pitch ~ -11.5/+11.5
Settings 2801pro
TX
Travadj
Pit. H 38 L 37
DR/expo
Aler/elev 90% expo 25
Rudder 100 linear
Throttle
Idle 2 100 95 91 95 100
Pitch
0-25-50-75-100
Rx
Aler/Elev gain 11 o clock
Aler/Elev exten ~ 9 o clock
Rudder exten 4 o clock
this week i am going to order my 2d 6ch helii am .very excited.
Yahoo!!! Nice job.
Chief
BHChieftain is offline Find More Posts by BHChieftain
Old Apr 06, 2012, 11:40 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Hey guys long time no post lol since I've been back in the states I've been super busy with my new planes and multirotors. Today I felt like taking my v120 to the field today just to see how I fly heli's still. Man it flew amazing as usual in 10-15 mph wind it was nuts I need to turn the gain down a tad but I even flew a little inverted with the crazy wind my friend couldn't believe it, heck I couldn't believe it lol. I was just starting to think maybe I should sell all my heli's and just fly my multirotors and planes. Then I flew a ill 3d with this heli and I quickly remembered why I first got into rc heli's before planes.
flohio117 is offline Find More Posts by flohio117
Old Apr 07, 2012, 04:32 AM
Atomic Skull is online now
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
I just did a bad thing, I ordered a 450 when I promised myself I wouldn't till the end of the year.
HK450GT Full Alloy - $46 (unlike the other HK helis that are made by Skyra this is actually a color swapped CopterX CX450SE V2)
Turnigy Typhoon 450 2215H brushless outrunner - $13
Plush 40 amp ESC- $19
4x Towerpro MG90's - $8 each (one extra just in case)
Fitec 9357 digital tail servo - $12
Walkera RX802 reciever - $34
Assan GA-250 MEMS gyro - $19 (hobbyking was out so I got it from a US shop)
Whole bunch of spares and other stuff like a set of fixed links for the upper head blade balancer swashplate leveler etc.
Total price for the helicopter itself not including spares and equipment $133.
Atomic Skull is online now Find More Posts by Atomic Skull
Old Apr 07, 2012, 04:36 AM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
My v120do2s flew a million times better than my belt cp v2 carbon edition. Good luck with your heli though.
Old Apr 07, 2012, 11:34 AM
fabric8 is offline
Find More Posts by fabric8
Fixed and rotary wing flyer
United States, NV, Las Vegas
Joined Sep 2011
That's identical as well to the EXI 450 Pro which I have and it's a very sweet heli. The only issue I had with it was the tail control slider ball was a bit too small for the control arm so there was slop and my tail kept wagging. Kept thinking it was my gyro/vibration I had a spare tail assembly and as soon as I swapped it out and the slop was gone, the tail held solid. I also have a 2215h motor btw.
I'm not doing any 3d yet, just sport flying, but this heli flies and tracks likes it's on rails (compared to my kds450). This and my v120d02s are my favorite flyers. You'll like it!
fabric8 is offline Find More Posts by fabric8
Old Apr 07, 2012, 11:53 AM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
ewww flybar
edit; they have flybarless kit
http://www.hobbyking.com/hobbyking/s...x_Compat_.html
scub is offline Find More Posts by scub
Old Apr 07, 2012, 12:22 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
Originally Posted by scub View Post
ewww flybar
I was thinking the same thing about the flybar lmao I only have 1 fly barred heli and I only kept it because it has to much money into it and I figured heck I'll keep 1 flybar red to remember where I came from.
Discussion new heli from walkera HIKO400? xyzy2 Micro Helis 15 Jan 12, 2012 11:16 AM
Sold Align 70A ESC W/BEC from 500/550 class Heli NEW! HD Hucker Aircraft - Electric - Helis (FS/W) 3 Oct 13, 2011 12:37 PM
Discussion Ultra Durable Diamond Mini Gyro 3 Channel Indoor Ready to Fly RC Remote Control Heli LittleG Coaxial Helicopters 32 Jan 14, 2011 12:55 PM
Discussion Walker 4#3 throttle problem Ė new heli Ronon Micro Helis 2 Jan 24, 2009 04:22 PM
