Old Jul 23, 2013, 10:02 PM
lacrossj is offline
Find More Posts by lacrossj
Joined Jul 2013
Fy30a Camera Gimbal Stabalizer
I'm using a Tarot 5D2 camera gimbal. I've mounted the FY30a on top of the camera. I'm currently having 2 main issues and I'm hoping someone can help
First scenario:
I've place the dip switches as the instruction manual states for camera gimbal (1-off, 2-on, 3-on, 4-off). With the switches in this config, all 3 mode switches seem to have about the same affect. The blue LED flashes differently, but even in manual mode, the gimbal acts as if its in Auto Stabilize.
Second Scenario:
I read on some other forum that some people were getting better results by putting the dip switches in standard, fixed wing mode (all off). I tried this and now the mode switch now does exactly what it should. Yay... However whenever I put it in auto stabilize mode it shakes like crazy. The only way I can get it to stop doing that, is by turning all the gains to zero, which basically make auto stabilize not work.
Any help would be greatly appreciated.
On a side note, hopefully I can save someone the pain I recently went through with the firmware. The versioning is a little weird, normally when a company releases new firmware, they add a note about what that firmware addresses. and different uses may be listed under different headings. So when the website said "v1.20 muti rotor" "v1.16 fixed wing" I didn't realize that I wasn't supposed to grab the latest version. My throttle was acting as a gain on my gimbal and drove me crazy. All my other channels were mixed as well. Eventually I figured it out and flashed v1.16 instead. My fault, but the site probably should have been a littler clearer for us idiots out there.
lacrossj is offline Find More Posts by lacrossj
New Product FY30A Stabilizer with upgradable firmware,camera mount stabilization feiyudz FPV Equipment 487 Oct 23, 2014 06:46 PM
Discussion A Camera Gimbal Test Gimbal Irv Multirotor Electronics 0 Mar 25, 2013 04:28 PM
Wanted FY30A for Camera/Gimbal stabilizer Techcoder FPV Equipment (FS/W) 1 May 04, 2012 06:25 PM
Discussion FY30A camera stabilization experiences? Aerial Photography 8 Mar 12, 2012 02:31 PM
Discussion Best Camera gimbal for quad - gyro stabalized? dustinash Multirotor Talk 8 Apr 15, 2011 02:54 AM
