Old Dec 17, 2006, 07:10 AM
Mike61920 is offline
Find More Posts by Mike61920
Joined Mar 2006
Glass Filled Propellers
I need a little advice about how to make glassfilled propellers not come loose from the spinner so often. I think this caused my recent crash.
Mike61920 is offline Find More Posts by Mike61920
Old Dec 17, 2006, 08:21 AM
downunder is offline
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
If they come loose it's because of too little friction between the prop and spinner. Most glass filled props are quite hard so they tend to be a bit slippery. The spinner surface should have grooves in it much the same as a prop driver does to grip the prop. If the spinner surface is smooth then you can make a washer out of some wet and dry paper to go between the prop and the spinner to add friction.
downunder is offline Find More Posts by downunder
Old Dec 17, 2006, 01:03 PM
Joined Mar 2006
Thank you
Glass Filled and Carbon Fiber Props neonbutterfly Electric Sailplanes 5 Jan 24, 2003 10:19 AM
