Old Apr 14, 2002, 02:04 AM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
problems with servo reversing
Om i have a delta wing likje a pibros. Now i had to reverse my servos so that up and down were right But now my left and right are wrong How do i reverse these?? I have a Hitec flash 5...if this helps any
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Apr 14, 2002, 02:47 AM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
I had the same problem. The solution was to change the sides of the aircraft that the servos were on. I was quite annoyed to find I had to physically swap them, but it worked out anyways.
Mikey-flies is offline Find More Posts by Mikey-flies
Old Apr 14, 2002, 03:20 AM
kushal_22's Avatar
Kamloops
Joined Dec 2001
Why did i know that was going to be the answer??
Old Apr 15, 2002, 12:51 AM
peter_jensen is offline
Find More Posts by peter_jensen
peter_jensen's Avatar
USA, MD, Columbia
Joined Feb 2002
Can't you just swap the connectors on the RX?
I know it's nice to keep things standard (I finally got it right building my new Zagi THL today), but I had the same problem on a delta wing and all I did was reverse the servos in the radio and swap the connectors.
-Peter
peter_jensen is offline Find More Posts by peter_jensen
Old Apr 15, 2002, 11:48 AM
kushal_22's Avatar
Kamloops
Joined Dec 2001
I think i will try swaping connectors first
Old Apr 15, 2002, 02:06 PM
Dauntae is offline
Find More Posts by Dauntae
Dauntae's Avatar
New Bedford, Ma. USA
Joined May 2001
Thats all I did, Swap them in the rx and all will be good.
Dauntae is offline Find More Posts by Dauntae
Old Apr 15, 2002, 02:13 PM
rmasonjr is offline
Find More Posts by rmasonjr
<burp>
rmasonjr's Avatar
Brookhaven, Mississippi, United States
Joined Mar 2002
Yep - switch the connectors.
I had them backwards on my Zagi
rmasonjr is offline Find More Posts by rmasonjr
Old Apr 15, 2002, 05:51 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
FIXED I had to un reverse them as well
Old Apr 15, 2002, 07:12 PM
Alberta, Canada
Joined Sep 2001
LOL that would be easier. I hadn't unreversed after the receiver switch :/
Help! Problems with servo centering ajreynolds 3D Flying 18 Jun 25, 2006 04:25 AM
Discussion Problems with new tail servo, major hunting SkyCaptian Mini Helis 14 Mar 05, 2006 09:59 AM
Problems with Reversing Graupner Stein0s Radios 0 Jun 06, 2005 11:12 AM
Please help with servo reversing issues Emission Radios 1 Mar 09, 2003 07:35 AM
Will I have problems with interference? pullin-gs Electric Plane Talk 2 Jun 02, 2001 06:38 PM
