Old Mar 09, 2015, 09:11 PM
swimmer is offline
Find More Posts by swimmer
AMA 1042906
swimmer's Avatar
United States, KS, Derby
Joined Mar 2008
Eflite Mini Ultra Stick Tailwheel Mod
Got a question for those of you that have installed a Dubro 375 tailwheel assembly on your MUS. Just got mine last Friday and have been reading/looking how to accomplish this mod. Does the bracket wire go between the elevator and stabilizer? Looks to me like relieving the elevator at its weakest point is not the best idea. Would extending the bracket bolt hole allowing the bracket to slide forward be a better idea? This would allow the bracket wire to be more in the stabilizer away from the elevator/stabilizer joint. Any info appreciated.
swimmer is offline Find More Posts by swimmer
Old Mar 10, 2015, 03:59 PM
Vrated is offline
Find More Posts by Vrated
Vrated's Avatar
United States, UT, Marysvale
Joined Aug 2004
Maybe this will help.......
http://www.rcgroups.com/forums/showt...l#post19415485
Post number 5051
Vrated is offline Find More Posts by Vrated
Old Mar 10, 2015, 05:15 PM
swimmer is offline
AMA 1042906
swimmer's Avatar
Joined Mar 2008
Post number 5051
Saw that and thanks. Going to try making the horizontal bend below the elevator instead of above eliminating the need weakening the elevator joiner. Making the bend at the right place will not impede elevator movement.
Wanted Eflite Ultra Mini Stick rwalbroehl Aircraft - Electric - Airplanes (FS/W) 1 Dec 12, 2014 05:07 AM
Wanted WTB : eflite mini ultra stick Kevinfred Aircraft - Electric - Airplanes (FS/W) 1 May 15, 2014 03:36 PM
Wanted Eflite Mini Ultra Stick JCMorgan Aircraft - Electric - Airplanes (FS/W) 15 Mar 03, 2014 07:48 PM
Sold Eflite Mini Ultra Stick EDFPILOT Aircraft - Electric - Airplanes (FS/W) 6 Jan 18, 2014 12:00 PM
Sold Mini Ultra Stick airframe w/steerable tailwheel $55 D/FW pickup dawnron1 Aircraft - Electric - Airplanes (FS/W) 1 Jun 23, 2006 11:36 AM
