Old Mar 14, 2015, 07:22 PM
cmdl is offline
Find More Posts by cmdl
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
I think the plane is pretty reinforced as it is. But I fly mine indoors (will eventually fly it outside) and hit a lot of walls trying to practice hover. It hasn't had an issue yet. Plus, you want to keep it light. I am very wary of adding any additional weight on a 3D profile foamie. Given the kinetic energy, the force of impact isn't much.
cmdl is offline Find More Posts by cmdl
Old Mar 14, 2015, 07:36 PM
Pilot Fatigue is offline
Find More Posts by Pilot Fatigue
Joined Jan 2012
Mine has been durable and also have the esc built into motor. Don't know if they still do that but I'm shocked it still works. It's a fun plane indoor and out when it's calm.
Pilot Fatigue is offline Find More Posts by Pilot Fatigue
Old Mar 15, 2015, 05:40 AM
GoAround is offline
Find More Posts by GoAround
Can't fly 3D for toffee ...
GoAround's Avatar
United Kingdom, Taunton
Joined Dec 2012
I like to blenderm reinforce where the leading edge of the wing joins the fuselage. Otherwise, I just blenderm reinforce where the build video suggests: Hinges and motor mount.
GoAround is offline Find More Posts by GoAround
Old Apr 10, 2015, 01:43 PM
bladefan is online now
Find More Posts by bladefan
bladefan's Avatar
United States, OR, Portland
Joined Jun 2006
Hi Guys. My rudder servo sticks sometimes at both the end points. is it dying and needs to be re eplaced?
bladefan is online now Find More Posts by bladefan
Old Apr 10, 2015, 10:19 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
Usually they make a ratchet kinda sound when they are stripping. Check for friction everywhere, along the rod guides, in the hinges, control horns etc....
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Old Apr 14, 2015, 11:25 AM
bladefan's Avatar
Joined Jun 2006
Thank you! I had already tried reducing endpoints which didn't work. So i worked the push rod a bunch and tried to get it a little straighter through the pushrod guides. It was sticking even when I was working it by hand. When I was done, it seemed not to stick any more and it has worked fine. I think getting it to line up better and and somehow reducing friction did the trick. Thanks!
Old Apr 14, 2015, 05:56 PM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Had another fly of the CYM, flew great, no camera, so heres the last flight
Sunset at the Point (4 min 10 sec)
jimbo320 is offline Find More Posts by jimbo320
Old May 06, 2015, 12:52 PM
nordby is offline
Find More Posts by nordby
United States, NC, Greensboro
Joined Sep 2009
Hey Guys - Anyone try the Hitec HS-40 servos? They look pretty similar to the CS-35D & CS-40D (I did a search on the thread but didn't see anything. I know they're not digital but otherwise appear similar).
http://www3.towerhobbies.com/cgi-bin...QamhoCwkXw_wcB
HS-40 SPECIFICATIONS
4.8V
Speed: 0.09 sec/60
Output Torque: 0.6kg/cm (8.4oz/in)
Weight: 4.8g (0.17oz)
Size: 0.79 x 0.34 x 0.67" (20 x 8.6 x 17mm)
CS-35D SPECIFICATIONS
Operating Voltage: 4.8-6.0 Volts
Operating Speed (4.8V): 0.09sec/60
Torque: (5.6oz) 0.4kg.cm/4.8V
Torque: (6.9oz) 0.5kg.cm/6.0V
Dimensions: 19.0 x 19.2 x 7.8mm
Bearing Type: Top Ball Bearing
Weight: 3.7g
CS-40D SPECIFICATIONS
Torque: (9.5oz) 0.7kg.cm/4.8V
Torque: (11.oz) 0.8kg.cm/6.0V
Dimensions: 19.0 x 19.7 x 8mm
Weight: 4.5g
nordby is offline Find More Posts by nordby
Old Jun 03, 2015, 04:55 PM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
Crack Yak Mini in the Garden (3 min 2 sec)
Old Jun 03, 2015, 08:49 PM
TEAM TWISTED
Joined Dec 2011
Whoa baby... Jimbo. What's next? Disco Inferno
Cool spot in the little garden there. Super nice quality to the video.
Old Jun 20, 2015, 11:06 PM
Dermensch is online now
Find More Posts by Dermensch
Dermensch's Avatar
Joined May 2014
Also have a Crack Yak mini now. My first mini and a real cute one
Mini Crack Yak - First flights (3 min 10 sec)
Dermensch is online now Find More Posts by Dermensch
Discussion Twisted Hobbys Crack Pitts 12 Build and Info Thread! cwojcik 3D Foamies 3356 Jun 27, 2015 10:10 AM
Discussion Twisted Hobbys - Crack Yak Lite - Build Thread hercdriver7777 3D Foamies 1149 Jun 27, 2015 03:07 AM
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6567 Apr 24, 2015 01:50 PM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
