Old Yesterday, 10:37 AM
westphill24 is online now
Find More Posts by westphill24
Joined Dec 2007
Fpvsummit how did you strip the paint off your body? I've seen people use liquid paint stripper but was wondering if that's necessary. Nice paint job also.
westphill24 is online now Find More Posts by westphill24
Old Yesterday, 10:49 AM
FPVsummituk is offline
Find More Posts by FPVsummituk
FPVRockApe on YouTube.
FPVsummituk's Avatar
United Kingdom, Rayleigh
Joined Jan 2012
Thanks, glad you liked it......I used a paint stripper......."Nitromores", here in the UK. Then rubbed it down, coated the rust with "Curerust", which stops the rusting process, then added 3 coats of primer filler, rubbing down between each coat, followed by 5 coats of yellow enamel and after, lightly, rubbing down, 4 coats of lacquer. Took a while but I didn't want to have to keep touching in the scratches.
FPVsummituk is offline Find More Posts by FPVsummituk
Old Yesterday, 11:14 AM
Joined Dec 2007
that's a lot of work but it definitely paid off. When you say rubbed it down you mean sanding?
Old Yesterday, 12:41 PM
Joined Jan 2012
Yes.......just very fine wet and dry sheets.........and lightly with very worn out abrasive paper with lots of water for the final rub down, then a fine rubbing down compound and polish for the final lacquer coat.
Old Yesterday, 01:39 PM
Deves is offline
Find More Posts by Deves
Deves's Avatar
Sunny So Cal.
Joined Oct 2005
Originally Posted by FPVsummituk View Post
Good to hear......I found a few photos of my drivers surgery.......you can see his left arm rigged for steering and the right arm for waving........also the passenger/navigator setup to turn his head, linked to the steering.
Plus a short video showing the driver and passenger animation.......... https://vimeo.com/132088076
Thanks Brian!
Deves is offline Find More Posts by Deves
Old Yesterday, 01:41 PM
Deves is offline
Deves's Avatar
Sunny So Cal.
Joined Oct 2005
That sure is a lot of work and the paint job looks great!
Old Yesterday, 01:47 PM
Joined Jan 2012
Originally Posted by Deves View Post
Thanks Brian!
Any photos of the victim........ummm.........patient?
Old Yesterday, 01:52 PM
Deves is offline
Deves's Avatar
Sunny So Cal.
Joined Oct 2005
I'll have to go back and review the tapes of the surgery for some still photos.
