Old May 16, 2015, 12:04 AM
mth is online now
mth
Find More Posts by mth
mth
United States, IL, Poplar Grove
Joined Jan 2012
hitec sevos
Building my first dlg and was thinking of using the hitec hs 45hb in the wing and the hs 35hd for elevator, no rudder. Will these provide enough torque and durability? Any advice is appriciated.
mth is online now Find More Posts by mth
Old May 16, 2015, 12:24 AM
MattN is online now
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
hs45's work fine -- for while. I used them on a couple DLGs (3-4 years back), and they worked great for about a year, then the pots starting going wonky. it happened on several of them, so despite their good qualities, I won't use them any more.
Maybe Hitec has gotten a better source for potentiometers since then, so take my opinion with the appropriate number of grains of salt...
MattN is online now Find More Posts by MattN
Old May 16, 2015, 05:50 AM
mth is online now
mth
mth
Joined Jan 2012
What type of servo do you use now?
Old May 16, 2015, 07:05 AM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
I think Hitec did get a new pot for both. They were both unavailable for some time but recently returned to the market.
Al M is offline Find More Posts by Al M
Old May 16, 2015, 07:22 AM
mth is online now
mth
mth
Joined Jan 2012
Would 11oz of torque be enough for the wing or would I be asking for trouble?
Old May 16, 2015, 07:36 AM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
Now fortified with carbon
DLGjunkyard's Avatar
Canada, ON, Cambridge
Joined Apr 2010
IIRC the 45`s are a bit to thick for wing servos [10mm]
Otherwise pretty good.
Specs can never be trusted, Heck, they claim 20 oz for the Dymond d47
If they fit, use them. Hitec`s stuff is usually quite reasonable. I know they center we;ll for example and the gear trains are excellent
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old May 16, 2015, 07:43 AM
mth is online now
mth
mth
Joined Jan 2012
That could be a problem, my new wing is in transit so I don't know exactly how thick it is. The hs 35 would fit but I'm concerned about the torque.
Old May 16, 2015, 08:15 AM
MattN is online now
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
I've had good luck with the airtronics 94802 for wings, and JR285 for the pod. Kinda "old school" these days, but they work. the '802 can be a little thick for some wings, but they can usually be shoe-horned in. The JR Sport SM22 is the analog version of the DS285, and also works fine if you want to save a little money.
The Hyperion DS09-SCD looks exactly like the '802, but I personally have had issues with them failing. Other folks use them w/out issue. What can you do...
I've recently been using the KST X08. Seems to be a great servo, and is smaller than any of the above.
the Hitec HS35 is a nice servo, but I'll only use it in mini DLGs (e.g. the Elf).
Other than the pot issues I had with the HS45, I really liked it - PLENTY of torque for DLG. In general, most any >6g servo will have ample torque.
Old May 16, 2015, 08:44 AM
mth is online now
mth
mth
Joined Jan 2012
I was looking into the KTS, just want to research all the options first. $35 per servo plus shipping is a little more than I wanted to spend but might have to.
Old May 16, 2015, 08:53 AM
GreggB is offline
Find More Posts by GreggB
GreggB's Avatar
Temecula
Joined Dec 2007
Other than the pot issues I had with the HS45, I really liked it - PLENTY of torque for DLG. In general, most any >6g servo will have ample torque.[/QUOTE]
+1. I have used the 35 in a minifireworks and they work great. I would not use them on full size dlg. Paul and I have been using HS 45's for tails on pull spring for years now.
Gregg
GreggB is offline Find More Posts by GreggB
Old May 16, 2015, 09:21 AM
mth is online now
mth
mth
Joined Jan 2012
Seems like KTS for the wing and Hs45 for pull spring is going to be the best option for me. Is it still ok to cut the tabs off the KTS? Thanks for advise
Old May 17, 2015, 09:47 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
I have had huge failure rates on the KST 245s and x08s... like four bad in the 12 I have purchased. Had another fail this weekend after abut 2 hours of use... very disappointed with these.
If you spend that much, get Hyperions or Airtronics 802s
tom43004 is offline Find More Posts by tom43004
Old May 17, 2015, 10:41 AM
mth is online now
mth
mth
Joined Jan 2012
Thats alot of bad servos, I was just going to look on where to buy them, but that chaged my mind. What hyperions are you using? Would airtronics have any problems being used with a futaba tx if I change the servo connector?
Old May 17, 2015, 10:45 AM
mth is online now
mth
mth
Joined Jan 2012
It seems what might work well for one person someone else has had problems with.
Old May 17, 2015, 06:20 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
All of the servos now have the same connector style. They are very much interchangeable.
DLGs typically use the DS09 SCD from Hyperion's line.
I think all servos over the past couple of years have had some QC issues. I like the KSTs but I can't seem to keep them working. I've also had a few of the Hyperions bad out of the box to be fair, but a much smaller percentage. I buy a LOT of servos.
Sold 4 Hitec HS-225MG sevos hursto75 Aircraft - General - Radio Equipment (FS/W) 1 Apr 25, 2015 06:52 PM
Sold Hitec HS-475HB Sevos x4 ton2di Aircraft - General - Radio Equipment (FS/W) 1 Nov 14, 2014 10:04 AM
Sold 3 NIB Hitec 7940TH Sevos Half Price!!! txshan130 Aircraft - General - Radio Equipment (FS/W) 3 Jul 17, 2014 08:12 AM
Question is there some website to order both hitec and jr sevo gears? txfly Electric Plane Talk 5 Apr 14, 2005 08:54 AM
do JR sevos fit Hitec? thor4944 Electric Plane Talk 7 Apr 22, 2004 02:33 AM
