Old Oct 12, 2013, 10:21 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
PhilLin,
Scroll down the page to All flying stabilizers part 1
http://www.ultimate-jets.net/blogs/f...ols-on-rc-jets
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 13, 2013, 10:40 AM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
CTBL, thanks for the link. It looks like it has a spreadsheet for convenient calc of air load. I'll check it out at a later date.
I did a rough calc on the tail plane load. Each tail plane is ca. 107 sq-in. At 120 mph & a max CL of 1.0, each panel would give ca. 27.5 lbs.
Assuming air load CP @30% chord & pivot spindle at 13%, I can expect about 60 oz-in of torque. So 100 oz-in max?
I posted my episode of a tail spindle slipping on my JHH F-4; the test I did to proof the fix, where I static loaded the tail plane to ca. 150 ozs-in w/out fail. I think I can safely use a similar pivot brg design & servo link. It is a fairly simple & inexpensive route (thank you, Larry Wolfe).
Phil
PhilLin is offline Find More Posts by PhilLin
Old Oct 13, 2013, 03:33 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
I think P901 did some calc's in my blog. I am going to use I believe they are 1501 turnigy servo's They are strong around a couple hundred inch oz. I have a set on my FW190 but have not maiden it yet. Maybe in 2014 as I took a year off from the club. I was playing a round holding the servo trying to force it back the other way was impossible it just sat there quite as could be never even buzzed.
unclecrash is offline Find More Posts by unclecrash
Old Oct 13, 2013, 04:37 PM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
@unclecrash, IMHO 200 oz-ins is a sensible servo w/ a positive margin. Current servos are designed & built stronger; but I have a couple of these older servos I can use.
You should hav seen the amount of distortion I put on the tail plane while static testing them to ca. 150 oz-ins. Too bad I did not take photos.
Phil
Old Oct 13, 2013, 08:49 PM
unclecrash's Avatar
white lake michigan
are they standard size or the old 1/4 scale one's
Old Oct 14, 2013, 12:46 PM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
U/C, they're std size digital.
You realize I'm out of sync with the build/fly seasons right now
Weather in WI has been good since end of Jun. Hope you got some flying in.
Phil
Old Oct 18, 2013, 11:49 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Originally Posted by p901P901 View Post
Looks like the tail post is at max camber of root airfoil.
man those planes have some sexy lines ...i got to work on that one for a day ...well both of them .they were awsome builds for prototypes just a crying shame they never got picked.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Oct 19, 2013, 10:28 AM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
I'm envious of your involvement with the prototypes. Yeah, the prototype looks sleek from certain angles, A/S. It did prove to be faster & more sleek than the F-22!. But there are angles where it does not look as nice. Perhaps the F-23A version will correct that. I might drop in & look at the one at W-P again.
Gone are the days when they would build both F-23 & F-22. Else might have kept the F-22 in better cost control.
I've been off my project for a few days trying to get ready for the seasonal migration. I'm dreading it in a way, as I don't have a drill press, scroll saw & many accessories I have up north. Was thinking if some one will let me use theirs for pay down there? Saves from having 2 of things I need.
Phil
Old Oct 22, 2013, 05:21 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
where are you nesting for the winter?
Old Oct 26, 2013, 05:21 PM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
A/S, I'll be setting up south of SRQ. I my be not far from Invermast, but I may be mistaken.
Phil
Old Dec 20, 2013, 08:57 PM
jetpilotrich is offline
Find More Posts by jetpilotrich
jetpilotrich's Avatar
Orlando, FL
Joined Sep 2008
The YF-23 Lives! Enjoy!
Banana Hobby / LX Models YF-23 ATF FLIGHT DEMO Part 3 of 3 in HD By: RCINFORMER (10 min 25 sec)
jetpilotrich is offline Find More Posts by jetpilotrich
Old Dec 24, 2013, 02:32 AM
Clickety is offline
Find More Posts by Clickety
Isaiah 40:31
Clickety's Avatar
United Kingdom, England, Hamble-le-Rice
Joined Sep 2012
Hey Phil! How's your bird progressing?
Clickety is offline Find More Posts by Clickety
Old Dec 24, 2013, 09:09 AM
PhilLin is offline
Oshkosh, WI
Joined Nov 2002
Sorry for no updates.
I've been in FL for month+. Been occupied with acquiring 5k+ additional furniture, TV, furnishing into almost empty dwelling after $4k already; & still more needed (plus X'mas) in prep of a surge of visitors for x'mas & soon after new year.
Have not had much time to get a drill press & saw, plus work bench. Also left some stuff in rush to start trip (f/g, tubings...), so will need to reorder those.
Hope to get some CAD work in early Jan.
Weather has been in mid 70s to 80 mid day w/ no rain for last 3 weeks. Caught a pix of 3+ft alligator stalking a snakebird below my window, a white morphed blue heron pecking at lizards in the shrubs a couple of doors down; & got involved with trying to rescue a young sandhill crane with a broken leg at the knee the other day. Too much distraction.
Pls keep posting your own F-23, clickety. What are your dimensions & weight (of the EDF version)?
Phil
Old Dec 24, 2013, 05:02 PM
Clickety is offline
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
Sounds like a lot of things keeping you busy! I'm impressed for your dr Doolittle work well done! My edf yf23 needs painting but it is exactly the same dimensions as my pusher version. It's quite a bit smaller than yours at 1110mm long. I'll upload pics and spec after Christmas when I return home. Have a great Christmas, Craig.
Old Jan 31, 2014, 05:11 PM
Clickety is offline
Isaiah 40:31
Clickety's Avatar
Joined Sep 2012
Hi Phil,
Haven't heard from you for a while, how is the build going on?
Just wanted to let you know that I've got my YF-23 Parkjet to a place where I am happy with it's handling etc. I had made some wrong assumptions on the CG position, that stopped me taking it aft, but once I tried it, the bird came alive.
I've now built 3 YF-23 models now, the original proto, grey ghost pusher and black widow EDF. The Grey ghost Pusher flew beautifully on its maiden :-
YF-23 Grey Ghost Parkjet (4 min 15 sec)
My EDF version, had a technical problem (EDF exploded on tests), so I've just ordered two Wicked Wemotec EDF units which I'm hoping will give it a real zip!
I'm playing with the Prototype with Gyro's to try and push its manoeverability to the limits.
I don't know what you could learn from my endeavours, but if they are any help I've uploaded a full set of plans, video, guides etc. - they are all on my blog - just click on 'Clickety' on the right and on my blog homepage click 'Continue reading' which will reveal all my plans.
I look forward to seeing your progress
Cheers
Craig
For Sale twin 70 mm 2150 kv motor and 50 amp esc. for twin engine jets jryanwilliams Aircraft - Electric - Power Systems (FS/W) 0 Feb 22, 2013 11:56 PM
Poll DA-70 twin in a 3DHS 90+ inch Edge 540??? Buzzed 3D Flying 7 Apr 17, 2012 02:29 PM
Discussion SmartModel.com.HK New F-5 in 70 and 90 size sam51401 Electric Ducted Fan Jet Talk 3 Jan 11, 2012 05:15 PM
Discussion twin 70 mm sapac f 22 Raptor maxhshv Foamy EDFs 7 May 16, 2009 12:24 PM
Gallery YF-23A and F-35C Hawker Your Plane Photos 0 Aug 22, 2005 07:44 AM
