Old Mar 02, 2012, 08:59 PM
ilium007 is offline
Find More Posts by ilium007
ilium007's Avatar
Australia, QLD, Brisbane
Joined Jan 2009
Help making replacement Stryker Ailerons
Hi - I have seen a few threads on balsa ailerons for the PZ Stryker F27C. Is there a preferred size of balsa stock people are using ? What about Depron ? I want to resurrect my Stryker but need ailerons ! Cheers
ilium007 is offline Find More Posts by ilium007
Old Mar 02, 2012, 11:28 PM
elfwreck is offline
Find More Posts by elfwreck
elfwreck's Avatar
United States, CA, Oakland
Joined Dec 2002
Hey now,
Unless you're only doing slow flight and mild aerobatics stay away from Depron ailerons. If you go with balsa I'd suggest 3/16 sheet balsa. Sand a taper into the aft end and round or angle the leading edge and then cover them with packing tape. That hold up and last a good long time.
A lot of folks will suggest 1/8 balsa but I find that to be a bit thin and fluttery for high throws and higher speeds.
RobII
elfwreck is offline Find More Posts by elfwreck
Old Mar 02, 2012, 11:34 PM
ilium007 is offline
ilium007's Avatar
Joined Jan 2009
So I don't need to try and find proper aileron shaped balsa stock ? The stuff I have found is 10mm thick which I think is too big.
Old Mar 02, 2012, 11:42 PM
Stone1295 is online now
Find More Posts by Stone1295
AMA 937634
United States, AK, Anchorage
Joined Jan 2010
You can either buy aileron stock or do a bit of sanding.
http://www3.towerhobbies.com/cgi-bin...?&I=LXJD24&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXJD25&P=7
-Mike
Stone1295 is online now Find More Posts by Stone1295
Old Mar 02, 2012, 11:48 PM
ilium007 is offline
ilium007's Avatar
Joined Jan 2009
So 3/8" is 9.5mm - you dont think thats too thick ? Thats basically what I already have and the ones I made hang down lower than the TE of the wing.
Old Mar 02, 2012, 11:56 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
The Stryker doesn't use regular aileron stock.
It uses flat stock, so you could build it out of any thickness that feels thick enough.
From 1/8 to 3/16 would be close to the original.
Butch777 is offline Find More Posts by Butch777
Old Mar 03, 2012, 12:03 AM
ilium007 is offline
ilium007's Avatar
Joined Jan 2009
OK cool. I'll post pics when I'm done !
Old Mar 03, 2012, 01:05 AM
AMA 937634
Joined Jan 2010
Damn, sorry about that. Wrong thickness.
I meant the 1/4" and then sanding down. Sounds like you've got it worked out though.
-Mike
Old Mar 03, 2012, 01:06 AM
ilium007 is offline
ilium007's Avatar
Joined Jan 2009
I found some 5mm sheet that I am cutting now - seems pretty close to what I need. Cheers
Old Mar 03, 2012, 03:26 AM
ilium007 is offline
ilium007's Avatar
Joined Jan 2009
Done !
Discussion Help in making a rhino mold thebaconbits CAD/CAM 7 Feb 27, 2012 01:14 PM
Found custom ailerons for stryker f27q rcwarrior Aircraft - Electric - Jets (FS/W) 0 Oct 12, 2011 03:02 AM
Discussion Noob making funjet ailerons better maynardr6 Foamies (Kits) 1 Aug 21, 2010 12:24 PM
Help find link to making sonic combat module work from parts stryker. Sheriff Foamies (Kits) 3 Jul 25, 2009 09:40 AM
Discussion Making tapered ailerons... GDR The Builders Workshop 6 Apr 22, 2008 12:41 PM
